Dont know if anything is wrong?
Old Oct 31, 2000 | 06:15 PM
Garmer's Avatar
On my way home from school today, I looked down at my oil guage and it showed it at 80 just like it always is. Then I let of the gas and the oil dipped down to 40! Everytime I would give it gas it would go up to 80, but once i let off, it would go right back to 40. I dont know if this has anything to do with it, but I also heard a thump every once and a while, like i was dragging or hitting something, when I got home I checked if anything was hanging and there wasnt! Does anyone have a clue what could be wrong?
91 RS Camaro
3.1L
Cat Back System, K&N filter,modified air box, Fastchip Stage 2, 160 thermo, Rapidfires and Bosch Wires, soon to come: Homemade Ram Air,and maybe power pulleys, 5 Air Horns
Old Oct 31, 2000 | 11:39 PM
Kevin S's Avatar
Nothing is wrong.When you let off the throttle the rpms drop.
when this happens your oil pump slows down.Which lowers your oil pressure.
http://www.camaroforum.com/
http://v6fbody.com/
http://nethirdgen.org/
http://clubs.yahoo.com/clubs/tristatecamaro
[This message has been edited by Kevin S (edited October 31, 2000).]
Old Nov 1, 2000 | 08:56 AM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
The only time mine reads 80 is when the engine is fairly cold. Kevin is right though...it fluctuates considerably with RPM, especially when the engine is warm.
Jason E
'89 Camaro RS 2.8
Hypertech chip/K&N filters/Accel 8.8 wires/RapidFires
Eclipse CD and 100x4 amp/Boston plates and 6x9s
Alpine Alarm w/ Keyless entry
IROC tailights/tinted windows
Old Nov 1, 2000 | 09:02 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hehe, my oil pressure gauge never gets that high. I hope it has something to do with air being in the gauge's supply tubing (it's a mechanical gauge)! Plus I have it stupidly in the wrong spot.. it's not where the oil pressure sensor should be, but instead, where the fuel pump safety switch should be. Oops. I'll fix that next spring.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Nov 1, 2000 | 03:33 PM
Garmer's Avatar
whoooooo.... That definitly relieves me! Oh and today the pressure was 60(it was warmer outside), so I guess it only reads almost 80 when it is cold!
91 RS Camaro
3.1L
Old Nov 1, 2000 | 03:57 PM
Kevin S's Avatar
Yeah Garmer,as the oil gets warm it thins out some.When my RS is at normal temp it reads 40lbs of oil pressure like when you stop for a red light(thats is "if"you do )the rpms drop down.
http://v6fbody.com/
[This message has been edited by Kevin S (edited November 01, 2000).]
Old Nov 1, 2000 | 04:38 PM
Jason E's Avatar
Depending on how warm it is outside, mine will be anywhere from 25-40 at a stoplight. I read a rebuild manual on 2.8s about this because I was concerned how low it was at idle, but down as low as 25 at 750RPM when fully warm is fine. Under a normal cruise once warm, I'm around 40.
One thing that's really cool?? When I floor it through 1st gear, it will go past 80PSI! I don't know if that is good, bad or a fluke, but it does it!
[This message has been edited by Jason E (edited November 01, 2000).]
Old Nov 1, 2000 | 07:45 PM
Garmer's Avatar
Just a thought how come our 88 Chevy C20 van doesnt (350)?
At a stop mine drops just below 40, and on the go it is between 60-80.
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
