No Power
Old Nov 6, 2000 | 11:20 AM
KNGHTRYDR's Avatar
No Power
I recently put in a new alternator, the car will not start without a boost, and when I boost it the battery does not hold a charge. While running after the boost, the car idles at 35 when it normally idles at 5-15. When I put my foot on the gas prior to trying to start, I turn the key and get a low choking sound. What can I do to fix this?
'89 Camaro RS Black
2.8L Fuel Injected V6 Engine
Automatic
"Love the car, learning more about it"
[This message has been edited by KNGHTRYDR (edited November 06, 2000).]
Old Nov 6, 2000 | 10:32 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Go have your battery checked take it to sears or autozone they will love to chek it for u
Old Nov 6, 2000 | 10:33 PM
FAST RS's Avatar
Old Nov 7, 2000 | 01:01 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Put a voltmeter on the battery before you start the car. It should be around 12 volts.
Put a voltmeter on the battery after you start the car. If the alternator's charging, you should get 13.8 (14) volts.
Are the battery terminals clean & tight?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 7, 2000 | 11:17 PM
KNGHTRYDR's Avatar
I going to try and clean the terminals first thing in the morning... It was cold here in Brooklyn last week, could there have been a condensation build up in the tanks, and if so would a container of dry gas help with the possible water build up??
'89 Camaro RS Black
Automatic
Old Nov 8, 2000 | 09:36 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It might, in fact I'm leaning towards moisture in the gas as what caused me to break at the racetrack:
https://www.thirdgen.org/messgboard/...ML/002635.html
However what gets me is that you need to get a jumpstart to start the car... maybe give that battery a full charge after removing it from the car?
OH- Hey, wait a sec- when you changed the alterantor (and disconnected the battery), you also reset the computer! Driveability will be crap for a while until the computer re-learns itself. Try your dry gas (**make sure it's okay for fuel injected engines!), charge the battery up again, start the car, and go for a 1/2 hour ride away from your house at highway speeds. That way it'll take you a 1/2 hour to come back.. after an hour, the computer should have re-learned your car.
Old Nov 16, 2000 | 09:59 PM
KNGHTRYDR's Avatar
Boosted the car, got it started, turned on the lights, car cut off, what up with that??
Cleaned terminals, battery charged, alternator 3 months old. Any suggestions?
'89 Camaro RS Black
Automatic
[This message has been edited by KNGHTRYDR (edited November 18, 2000).]
Old Nov 18, 2000 | 06:40 PM
KNGHTRYDR's Avatar
Old Nov 20, 2000 | 12:32 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Bad alternator?
Get a voltage meter. Voltage with the car off should be about 12. Voltage with the car running should be 13.8, or 14.
Old Nov 20, 2000 | 12:57 PM
Brian K's Avatar
Is hte charging wire stuck back in the alternator?
Old Nov 20, 2000 | 02:47 PM
FAST RS's Avatar
Check all tou connextions from the ALT to the battery. or just pull your alternator and battery goo to a parts stoe and they will test it for you.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
