2.8 throttle body vac lines.
Old Feb 26, 2011 | 01:31 PM
coon88's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
i was wondering if anyone could tell me what it is? its where vac lines run into the top of the throttle body? i took it off while rebuild the engine and was going to repair the vac lines but it is no where to be found.... i was wondering if it is a junk yard item or a parts store item and what is it and what it does? thank for you for everything.
Old Feb 26, 2011 | 05:45 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: 2.8 throttle body vac lines.
one of them is the FPR vac line, the other is EGR and also ties in to the evap canister I believe. If you're missing the rubber block you are probably SOL, if you just need the vacuum line, you can get that at pretty much any parts store, you will just have to figure out what size and length..
Old Feb 27, 2011 | 01:17 PM
coon88's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
yeah i cant find the rubber.............ugh idk what i am gonna do. that will put having it run to a complete stand still............gahh idk what i will do....
Old Feb 27, 2011 | 01:25 PM
coon88's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
if anyone honestly has one and would send it to me i would love them forever. i would give you money if i could!!!!! i would truely honestly appreciate it!
Old Jul 1, 2011 | 08:22 PM
dustierdog's Avatar
i have no clue what its called, but it definitely sounds like a junk yard item to me. they probably wouldnt even charge you for something that small. good luck! wow didnt realize how old this post was
Old Jul 1, 2011 | 08:26 PM
Engine: 3.8, 3.4
Talking about the rubber vacuum block for the TB right? I MIGHT be able to part with mine, I am doing a plenum swap to 3.4, but I have to check if it has some other spot for me to route the FPR too(I think it does if I recall correctly, but have to double check) also depends on which TB I use, I'll let you know once I figure it out.
Old Aug 2, 2011 | 11:45 AM
MFlove68's Avatar
Car: 1985 Camaro sports coupe
Engine: 2.8l v6
what are the side effects of the vac line being snapped ihave an 85 and the damn line snapped like a twig and now the check engine light is on i dnt wanna drive it and mess it up because of some cheap plastic
Old Aug 2, 2011 | 11:54 AM
dustierdog's Avatar
A broken vacuum line is going to allow unmetered air in to the engine. In other words the air flow meter does not see this extra air, therefore throwing off the air/fuel mixture. Your engine will not run right, and an oxygen sensor will see this as the engine running lean probably causing your check engine light. Vacuum lines are usually an easy cheap fix. Mine all broke on me without me even touching them. Good luck
Old Aug 2, 2011 | 03:40 PM
Engine: 3.8, 3.4
What he said, tho non essential ones can simply be plugged in a pinch.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
