important question...
Old Dec 28, 2000 | 08:53 PM
CamaroEFI's Avatar
i know you can modify the ECU to where you can control the top speed of your TBI Camaro by hooking up a switch and splicing the wire that goes to the VSS...can the same thing be done to the MPFI v6 or is 85mph my top speed??
--86 2.8 MPFI, 5-speed Camaro
Old Dec 28, 2000 | 09:18 PM
jason86/2.8's Avatar
Dude just b/c the speedo stops at 85 doesn't mean that is the top speed. Beleive me I've had mine past the 85 marker plenty of times. The needle just keeps going on around back to the 0. I don't think there is a speed limiter on the 2.8 MPFI's.
Red 1986 SC, 2.8L, newly rebuilt 700R4, 3.42 Posi, t-tops, 133K miles and counting, K&N air filters, hopefully more to come!
Old Dec 28, 2000 | 10:47 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
actually there is..well in Cali i know i do..supposedly from a dealer i heard 133 mph
Flowmaster 80 series, Random Technologies Cat, 3" intermediate pipe, SS
Hand Made Tips, 3 1/4" out, Accel 8.8 wires, MSD Coil, MSD Ignition Module,MSD 6A Box, Air Intake Temp Guage, Brushed Aluminum Hood Pins
Currently Working On:
T5 swap
Next to buy:
Slp dual cold air intake!
My Site:
www.geocities.com/firebird89white
" I'd rather run last in a full out race, than to NOT run at all ".
Old Dec 28, 2000 | 11:10 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
the governer on 2.8L's was set at 115mph, at that point the engine stops delievering fuel to the engine, and won't allow the motor to go any faster.So, if you hit 115, the car will start to sputter, and sound like it's going to die. You can splice the wire that goes to the VSS, and conect it to an on/off switch, make sure you connect it to a switch, because driving without the speed limiter on is bad on your transmission. But, once you're in 4th gear, I highly doubt it'll matter, so you could turn it off at say 100mph, and cruise on up the coastline at record breaking speeds. So yes there is a limiter, and yes you can get around it, and it's also considered by many to be an easy do mod, plus, on off switchs make cars look pimp. oh, and welcome to the board
Old Dec 29, 2000 | 03:09 PM
CamaroEFI's Avatar
85f-bird..thanks. i was getting tired of all those damn imports passing me on the interstate
Old Dec 29, 2000 | 11:48 PM
85f-bird's Avatar
Engine: 2.8L, LS1
you might want to know, don't know if you care or not, a while ago, (before the boards went down) we had a little discussion on v6 top speeds. WE know the 115 mph governer is there, but once disabled how fast can we go? Most people know that our cars will easily pass 115 mph, any day of the week, but i've heard that our 4th gear doesn't last long enough to get a top speed test or something. The highest i've seen was from Tom P with a 137mph or something. It seems really nice, and will destroy a lot of those hondas and TOYotas. Also because of our high rpm peak hp, it should help with a lot of pull towards yellow line, and give you a strong engine pull until redline.
Old Dec 30, 2000 | 12:38 AM
Monkie's Avatar
ummmm no, Ive taken mine up past 115 alittle. But then it started shaking. But it did go past 115! hmmmmm
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
8.5mm MSD Ignition wires
TB Coolant bypass
Soon to be a 3.8L turbo RS
AIM screen name - Stopsign696
Kills:
95 (****) Probe GT,94 Mustang GT,91 CRX (dont ask me why he raced me),2nd Gen Z28 (350) haha to you V8 guys!,1992 RS 305 TBI (good race),First Gen Integra, Old Escort LX
More to come
Old Dec 30, 2000 | 10:32 AM
RenoLB8's Avatar
Yeah, I've had mine to 118-120 before, thought I was gonna die, but done it. Maybe the limiter is a little sloppy?
-Reno
Old Dec 30, 2000 | 01:09 PM
85f-bird's Avatar
Engine: 2.8L, LS1
just going on what i've beeen told. Also, from what i've heard certain chips will eliminate the speed limiter. So if you have on of those, then you don't have the governer.
Old Dec 31, 2000 | 07:42 AM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
If your speedometer reads 1-2 MPH fast at 35-40 MPH, it could easily be 5 MPH off at higher speeds. You were probably doing 115, but the speedo showed higher.
Old Jan 8, 2001 | 01:43 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
About a month ago on my way home i hit 150 i used the formula on the claculations board and put in my gear ratio and it said somethin like 148 i was well into the redline tho and had some help going down a hill=) i know this is a way old post but im bored at work and reading all the old posts i missed
ZZ3Astro
Aug 13, 2019 12:57 AM
Jorlain
Oct 8, 2015 01:57 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
Ozz1967
Aug 16, 2015 10:23 PM
