Where can I get exhaust manifold bolts from?
Old Mar 16, 2011 | 11:50 AM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Is there anywhere I can get them from? Anyone have any used ones they would want to sell?
Old Mar 16, 2011 | 12:43 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Where can I get exhaust manifold bolts from?
I don't think there is anywhere you can't get them......try advance auto, autozone, napa, summitracing, any place that sells bolts....
And I may be wrong, but I believe exhaust manifold bolts have a universal thread size/type regardless of what car they are from or for.
Old Mar 16, 2011 | 03:47 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Go to a hardware store... They're an M8 bolt, don't remember the thread pitch. Just have to make sure they're hardened, and make sure to use anti-seize.
Old Mar 16, 2011 | 04:27 PM
Car: 1988 camaro
Engine: cammed 3.1
Thanks, I figure I should get them ahead of time since the bolts look pretty bad and I already snapped part of one off removing the alternator support. How many bolts are holding the tranny to the engine? I could only see 2 on each side since there isn't a whole lot of light and I know the v8 bell housing has like 3 on each side.
Old Mar 16, 2011 | 05:44 PM
Engine: 2.7L V6
Axle/Gears: 4.41
There's 6 bellhousing bolts... No need to do anything with those. Just get a wire wheel on a drill or something and clean them up.
Old Mar 16, 2011 | 07:25 PM
RT66DAVE's Avatar
They are not too pricey from the Gm dealer. I aslo got a good set form my local U Pull It yard
Old Mar 16, 2011 | 08:47 PM
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
I got new ones from a dealership. I got 6 manifold bolts and 2 y-pipe donuts for about $15 from them. Had to order them but it only took 3 days.
Old Aug 30, 2011 | 04:19 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Are the M8s the ones from the y-pipe to the manifold? My passenger decided it didn't want to be connected anymore. Now the y-pipe & manifold are almost an inch away from each other. Isn't there supposed to be a donut gasket? I checked with Autozone (i know, i know...) & they had no listing for one for a 3rd gen.
Old Aug 30, 2011 | 08:51 PM
ktmracerx009's Avatar
Car: 1987 Camaro
Engine: 2.8 tpi
Transmission: 5 speed
yeah i had the back passanger break on mine and im trying to find them. i got 8MM bolts but think they are too short since you just orderd them do you know the size and everything?
Old Aug 31, 2011 | 10:19 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Exhaust manifold stud kit.NAPA 600-1819 worked great on the donut conection for me.
AussiePr0nCar
Mar 6, 2020 04:04 PM
transaero
Aug 31, 2015 01:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
