V6 Engine Questions (again about 2.8L & 3.4L)
Old Jan 5, 2001 | 05:38 PM
Mike Harvey's Avatar
What are the main differences between these 2? I know the similarities like the same block & everything but what are the stock numbers (like HP) on the 3.4L? Since there are so many screwed up F-bodies at this one wrecking yard that doesn't allow self pickers to come in, in my town I was thinking about purchasing a 3.4L & bore & stroke the $hit out of it & really supping it up. Then I would swap all the stuff that is on my 2.8L onto the new 3.4L, since I know this will work.
Also would my headers made for the 2.8L work on this 3.4L?
Would this be my best bet to do this swap? Later guys
- Mike Harvey -
1986 Firebird S/E
Old Jan 5, 2001 | 06:25 PM
Monkie's Avatar
The 2.8 is a 60 degree block and the 3.4 is a 90 degree block...
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
8.5mm MSD Ignition wires
TB Coolant bypass
Soon to be a 3.8L turbo RS
AIM screen name - Stopsign696
Kills:
95 (****) Probe GT,94 Mustang GT,91 CRX (dont ask me why he raced me),2nd Gen Z28 (350) haha to you V8 guys!,1992 RS 305 TBI (good race),First Gen Integra, Old Escort LX
More to come
Old Jan 5, 2001 | 06:42 PM
No they aren't. They are both 60 degree blocks. The 3.8L is a 90 degree block.
- Mike Harvey -
1986 Firebird S/E
Old Jan 5, 2001 | 07:28 PM
Monkie's Avatar
Damn, sorry I was thinking about the 3.8L. I knew one of the 4th gen blocks were a 90 degree. I was only .4 away tho
Old Jan 5, 2001 | 08:03 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
hey mike where u going to grab a 3.4? rancho chevy recycling? if so lemme know what they have
89 Firebird
2.8 V6 w/ t5 tranny (383 tpi t56 w/ ati 12/01)
Flowmaster 80 series, 3" Intermediate, SS Tips, Random Tech Cat, Msd Coil, MSD 6a, Accel 8.8 wires, Cold Air Intake w/ K&N, Lakewood LCA's, Brushed aluminum Hood pins ETC...
My Site:
www.geocities.com/firebird89white
" I'd rather run last in a full out race, than to NOT run at all ".
Old Jan 5, 2001 | 08:07 PM
oh mike... 2.8 135 hp 170 tq and 3.4 170 hp and 200 tq
89 Firebird
My Site:
Nope, a place called Kennedy's Wrecking Yard. They have so many 4th gen F-bodies, it's not even funny. They've got so many engines that's it's unbeleive so after we move out of this house in about 4-5 months, then I will buy that engine.
Which is good for me b/c that gives time for me to save money for it & to finish my KITT conversion as well. I don't imagine more than $350 at my dealer cost for that engine & then I'll go completely through it.
Should larger size injectors go on something like that?
- Mike Harvey -
1986 Firebird S/E
Old Jan 5, 2001 | 08:15 PM
hey they have a website? looking for a few different engines
89 Firebird
My Site:
Old Jan 5, 2001 | 08:36 PM
No sorry bro.
- Mike Harvey -
1986 Firebird S/E
Old Jan 5, 2001 | 10:00 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
wow, i've NEVER seen a 4th gen in a boneyard. where is that kennedys place at, mike???
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
Old Jan 5, 2001 | 11:44 PM
Stockton, CA about 50 yards away from Pick N' Pull. Stockton is about 45 south of Sacramento.
- Mike Harvey -
1986 Firebird S/E
Old Jan 7, 2001 | 11:39 AM
KED85's Avatar
That sounds about right.
If you're looking for some 4th gen engines, Try So Cal Auto Wrecking on Alameda, in LA.
Ask for Marty.
He has 4, 3.4 engines for me available.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jan 8, 2001 | 11:12 AM
psigourney's Avatar
The 3.4 was Chevy's replacement engine for the 2.8 primarily because the 2.8's reliability is crap. This swap was popular in the early 90s S10s. The 3.1 is also a 60deg engine, with the same bore as the 2.8, but the stroke of the 3.4. Either one would be a good drop in replacement for a 2.8, I think the main difference would be price. The 3.1s are more prevelant in scrapyards because (I think) the 3.4 was only available in crate form. (might be wrong here).
I found this board while looking for 3.1 info. I am looking for a 3.1 as a replacement for my Jeep Cherokee's 2.5 4-cyl. (2.8 was the optional engine from 84-86)
All the heads, intakes, etc. will bolt up to any of the 3 engines.
-Patrick
85 Cherokee 2.5L
213,000 miles
Old Jan 8, 2001 | 11:39 PM
pods8's Avatar
You'll want to use the 3.4L injectors they are 19lb, or some other 19lb injectors. I'm running ford 19lbs cause they don't lock up if you ever run higher pressure with nitrous or something. Don't think you can bore or stroke the 3.4 cause I think its about maxed in that area.
-pods
88' Sport Coupe W/ T's
2.8->3.4 5-speed, accel coil-8.8 wires w/ bosch platinums
black and silver, grey interior, w/ 95' cloth seats, 3way power driver
Old Jan 26, 2001 | 06:20 PM
KED85's Avatar
I am about finished w/my 2.8-in-disguise swap (3.4 long block under 2.8 stuff).
Everything fits!
Can't wait to finish & turn key tomorrow!
DO IT!
Chat Soon,
KED85
Karl
Old Jan 26, 2001 | 07:37 PM
I have definetly go to see you ride when it is done. I will drive all the way down to So Cal from Nor Cal to check it out.
- Mike Harvey -
1986 Firebird S/E
Old Jan 30, 2001 | 11:09 AM
FBODY-ADDICT's Avatar
Yeah ked, when youre done post some pics so we can get a better look at your "stealth" 3.4
Old Feb 2, 2001 | 12:45 AM
KED85's Avatar
Hi ALL,
Read the reply about the 2.8 3.4 swap made easy! I finally made it home with this car!
I'm VERY PLEASED I DID THIS!
I WISH I could post pics!
Email me, tho for any questions.
IF you want to see what this thing looks like, just open your 2.8 hood.
THAT IS EXACTLY WHAT IT LOOKS LIKE! He-he!
I only used the 3.4 exhaust manifolds with the heat shields on it to keep engine bay cooler.
I even made a stud set up for distributor hold down! Ever try to get that bolt back in the hole, with the engine in there? I gave up and made teh stud set up.
Buy the bolt, that fits, cut off head, file threads, stick in the 3.4 block and drop in distributor. Then put the distributor hold down over the stud, add nut. Done!
Ask any questions happy to pass along the tails of encouragement!
I can;t wait to make wait to smog test, now!
And 14 sec 1/4 miles, I hope!
Chat Soon,
KED85
Karl
Old Feb 2, 2001 | 06:42 PM
KED85's Avatar
I just got my Firebird dialed in.
I needed to replace the Mass Air Flow Sensor and tweak the distributor.
ALL THE PROBLEMS ARE GONE, SOLID PURE POWER & THE FRONT END LEAPS!!!!!!
I am so excited!
DO THIS SWAP!!
Honest, it looks just like the old 2.8, he-he!
Chat Soon,
KED85
Karl
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
