Not starting again, electrical help...
Old Feb 10, 2001 | 05:18 PM
RenoLB8's Avatar
I had to jump it last night, and it started up, ran it for a while, then turned it off and started it again just to make sure it was alright, kept it running for a bit, but then today, once again, the voltmeter is bottomed out. Can anybody possibly tell me what's causing this? No accessories were on, I checked all my wiring for extras (fan switch, amp, disc changer, etc) and nothing's grounding out. This is easily the most frustrating problem I've ever had. HELP!
-Reno
Old Feb 10, 2001 | 08:41 PM
Vortex_89rs's Avatar
Maybe time for a new battery?
Vman
1969 Camaro Sport Coupe
383, 700R4, leather, everything black but the lights
Previous owner of an 89 RS Camaro
2.8L V6, 700R4
Old Feb 10, 2001 | 10:43 PM
RenoLB8's Avatar
Nope, the one in there is about 2 months old.
-Reno
Old Feb 11, 2001 | 12:02 AM
Sincat_23's Avatar
Try all your grounds!! the engine ground and battery ground. Stuff like that can cause it to sometimes not start.
92 Camaro 3.1 V6 (Red)
-Hypertech Chip
-Dynomax Exhaust
-Taylor Spiral Spark Plug Wires
-2.5 Harwood Lift-Off Cowl Hood
-B&M Megashifter
-B&M Shift Improver
-15x8 Crager 5-Star Chrome Rims
-JSP Apache Wing
-Yellow Weapons-R Intake Filter
-KYB Shocks & Struts
-Borla Exhaust Tips
Old Feb 11, 2001 | 07:55 AM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
I had the same problem, caused by a bad relay at the pulldown motor in the trunk.
www.marion-becker-nidda.de
91 Firebird 3.1
Modsynomax ultra flow stainless steel
Old Feb 11, 2001 | 01:45 PM
1989v6bird's Avatar
try taking your car to a shop and have them test your alternator. This sounds like the alt isn't charging your battery and it's dying because of it. Do it soon or your battery will be toast.
Old Feb 11, 2001 | 02:14 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Reno remeber i had the same problem this week so far it hasent done it again the battery had volts but some how lost all the amps in it it was werid. i think it has to do something twith the alternator pully
Old Feb 11, 2001 | 02:22 PM
KNTRDR's Avatar
I HAD A SIMIULAR PROBLEM. AS HORST SAYS, THE PULL DOWN MOTOR WAS BAD. TRY THAT.
Orr89RocZ
Apr 25, 2016 08:28 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
TheExaminer
Aug 19, 2015 10:07 PM
mizz0313
Aug 12, 2015 06:45 AM
