92-95 3.4 question
Old Feb 28, 2001 | 02:56 PM
Mrfixit's Avatar
92-95 3.4 question
For those of you who have a 3.4 in your Camaro, could you take a look and see if you think the upper portion of the plenum is reversible (i.e., to move the throttle body to the other side of the motor).
Thanks,
Roy
Old Feb 28, 2001 | 03:06 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
if i'm not mistaken, i believe most people HERE with the 3.4 used the 2.8 plenum. are you referring to the stock 3.4 plenum????
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
Old Feb 28, 2001 | 04:23 PM
Mrfixit's Avatar
Yes. I am thinking of buying a complete 3.4 for a car project of mine (transverse confuration) but I need to run the throttle body out - what is now - the back of the motor.
Roy
Old Feb 28, 2001 | 04:52 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Don't forget, the motor mounts are different. I also think the thermostat housing is also in the wrong spot, and the bellhousing won't bolt up to a rear-wheel-drive trans.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 28, 2001 | 05:09 PM
Ovrclck350's Avatar
mail Ked85. He'll tell you that it pulls like a freight train, then tell you what to do....LOL
See pics @ Billy's Firebird
92 Bird 3.1L Auto
Best $750 I ever spent....
DRIVE IT LIKE YOU STOLE IT!
Kills:
93 Mustang LX (Before Mods)
98 or 99 Dodge Stratus (tough one, edged out at 40)
92 Camaro RS 305 TPI
97+ Honda somethin or another...modded....kept at my door the entire way
Close Calls
94 Grand Am 3.1 V6
92 Cavalier 3.1 V6
01 Porsche 911 Turbo (Had em till first gear)
Mods-Jet Stage 2 Performance Chip, Accel Cap/Rotor, Accel 8.8 MM Wires, Accell Coil, AC Delco Rapidfire Plugs, Dynomax Catback, K&N
AIM name OVRCLCK350
Old Mar 1, 2001 | 12:01 AM
Engine: LH0 3.1L
TomP, after some research, i found that that a RWD trans WILL bolt to a FWD engine (as far as chevy 60*/V6's are concerned). BUT i STILL am not sure if a FWD can be converted to RWD. GMPP has some cylinder heads that specifically say "for transverse mounted engines" which leads me to believe that the heads are not interchangeable. so, i dunno, my head hurts
Dan
1990 3.1L RS
Old Mar 1, 2001 | 06:47 AM
Mrfixit's Avatar
All the 3.4 bell housing bolt patterns are the same as 2.8 and 3.1 regardless of which configuration the motor was used (i.e., longitudinal or transverse) so I know it'll bolt to the transmission. I will have to relocate the starter to the opposite side of the block. I may also have to change the timing cover, oil pan, pulleys and brackets. I would really like to use the 3.4 aluminum heads and the intake system if possible. If any of the three (?) intake pieces are reversible, it'd make my project a little easier.
Roy
Old Mar 1, 2001 | 09:49 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
I'm completely unsure on the intake issue.. however, if you can get it to work, go fer it.. the performance numbers of those grand ams and whatnot are a hell of alot better than ours from what I've seen.. also, if you can get this to work I think there are some superchargers from 60* transverse engines now that I think about it... but I haven't really researched the transverse variants..
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4 /w special 2nd gear delete option
In search of new v8 engine & transmission, now contemplating t5 swap to get me out of this mess.
MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers
[This message has been edited by TechSmurf (edited March 01, 2001).]
Old Mar 1, 2001 | 10:37 AM
KED85's Avatar
Roy,
NO they are not reversible.
They are specific application units.
I discovered that.
I also sent ya an email
Hope it helps ya
Ovrclk, Man, you are a good guy!
Thanks for alerting me to Roy's aid!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Mar 1, 2001 | 10:38 AM
Ovrclck350's Avatar
No problem. In my opinion, you're the 3.4 guy.
Old Mar 1, 2001 | 04:43 PM
KED85's Avatar
THANKS Ovrclck
You're a good buddy!
Hope MrFixit responds to my email, cause I have his answer.
Chat Soon,
KED85
Karl
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
92projectcamaro
Aug 6, 2015 01:20 PM
