2.8 -> GN swap
Old Mar 12, 2001 | 11:35 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
2.8 -> GN swap
Ok, I've possibly found a very very nice donor car.. I've only got the following issues..
1) GN heads, it's been said they won't clear the strut towers, and it's also been said they will. Anyone got a definite answer on this? How high will 3.8 LeSabre heads bump the compression? I can't afford putting in new pistons...
2) 200-4R transmission, what kind of changes would be needed to put it in place of my 700r4?
3) Turbo downpipe, where the heck am I gonna get a TTA downpipe? And how much am I looking at spending?
4) Motor mounts, 305 motor mounts work or there special ones for the 3.8?
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4 /w special 2nd gear delete option
In search of new v8 engine & transmission, now contemplating t5 swap to get me out of this mess.
MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers, possible performance chip I don't know about.. gotta crack open the ECM and check sometime
Old Mar 12, 2001 | 12:04 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
1) 2004R SHOULD be a near bolt-up...don't quote me on it though, as I've never tried it.
2) The 3.8 heads WILL NOT clear. Anyone who says they will is on crack. If there is anyone who doesn't want to believe me, I have 3 period TTA road tests to prove that they are on crack
3) Things such as motor mounts you will need to get through a GM dealer. My bet is they're still lying around some warehouse, somewhere...a turbo downpipe should be the same deal. NO idea as to how much...then again, I don't wanna know
Exhaust stuff should be easy though. I gotta think some speed parts places should have stuff like that.
Jason E
Trying to sell the...
'89 Camaro RS 2.8
The future third gen...
'87-'92 IROC, GTA or Z28
or 4th gen T/A or Z28
Daily driver:
'95 Grand Am SE 3.1 Coupe
Long Live #3...
Old Mar 12, 2001 | 04:42 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
Talk to 20 psi..he sent me info...a lot of it.U need TTA heads and pistons to clear. use the 200r4. Use tta motor mounts and a aftermarket down pipe i believe he said...check with him
" I'd rather run last in a full out race, than to NOT run at all ".
Old Mar 13, 2001 | 10:38 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Didn't someone say that 3.8 heads from a front-wheel-drive V6 would clear the strut towers?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 13, 2001 | 03:32 PM
Garmer's Avatar
Yeah i was thinking the same, there was a post like this one before this site went down.
Old Mar 13, 2001 | 06:39 PM
20-psi's Avatar
I've priced a bare set of replacement heads for my TTA at $215.00 each. Then you have to buy everything else, valves springs retainer,etc. The compression ratio should be 8 to 1 for that application. The aftermarket downpipe can be bought many places, my were from ATR at $350.00 plus $250.00 for the wastergate plus $200.00 for the cat plus $600.00 for the cat back. Terry Houston has a setup for $450.00.
Check out GMHTP magazine for phone numbers for Cotton's Performance, Duttweiler Perf. ATR, Eastern Perf., Kirban Perf., Modern Musclecar. There are a lot of people that can help (and you will help).
Pete (20-psi)
Old Mar 16, 2001 | 07:54 PM
Monkie's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Jason E:
</font>
The 3.8 heads WILL clear. Dont listen to Jason E. If you put GNX heads on you will loose the A/C. If you use the TTA heads you will have no problem. If you want anymore info on the 3.8L swap either IM me on AIM or drop me an email.
later
Old Mar 16, 2001 | 08:07 PM
The GN heads will clear yes, but u will lose a/c. If you swap to tta heads, u also have to do pistons as the pistons with tta heads will raise compression which u dont want to do. Ud have to do TTA heads and pistons.
Cleotiz
Jan 6, 2018 08:56 PM
Digs_do_it89
Aug 30, 2015 10:24 AM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
86Base
Aug 8, 2015 01:34 PM
