SFI TO CARB
Old Apr 27, 2011 | 01:45 PM
JJs84Berlinetta's Avatar
SFI TO CARB
Hi as many people on here have done I want to do the 2.8 to 3.4 swap. I have found a 95 3.4 sfi engine. My question is can i change the SFI to carb. Has anyone done this and what would it consist of doing.
Old Apr 27, 2011 | 05:16 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: SFI TO CARB
I don't see any carb intakes available for a 3.4l engine - I looked at Jegs & Summit, as well as the Edelbrock site - so I'm guessing the answer is no, you can't. But the trick would be to find a manufacturer that makes a carb intake for that motor.
Old Apr 27, 2011 | 05:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's the same intake as a 2.8 or 3.1.
Old Apr 27, 2011 | 05:56 PM
Car: 1992 RS
Engine: Carbed 350
Re: SFI TO CARB
Well, there ya go!
Old Apr 27, 2011 | 08:30 PM
Re: SFI TO CARB
Thanks fornthe help guys so from whatmimunderstand I can just take the intakenfrom the 2.8 and goes straight on 3.4 and stays carbed
Old Apr 27, 2011 | 09:14 PM
five7kid's Avatar
You'd be better served getting your information from the V6 forum.
Old Apr 27, 2011 | 11:05 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: SFI TO CARB
Why would you want the old carb over EFI?
Old Apr 28, 2011 | 12:27 PM
Re: SFI TO CARB
Can i do that keep the 3.4 SFI. I would have to get an electric fuel pump anyway right to do this swap. Can i use the fuel rails from the 3.4 or do I need to find 2.8 fuel rails. Would the 2.8 computer throw a fit.
Old Apr 28, 2011 | 02:40 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: SFI TO CARB
for "3.4 swap" ... It's been covered over and over again. And yes, if you're currently carbed, you need a whole sending unit from a FI car since the fuel pump you have, even if it would swap over to the "new" engine (which it can't since the holes in the boss don't exist), it wouldn't flow anywhere near enough or produce enough pressure for the injection to work. And you can't just add the pump to your existing sending unit unless you go for a $$$ inline pump.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
