Air intakes... interchangeable?..
Old Apr 1, 2001 | 02:22 PM
XxMoLexX's Avatar
I didnt really know how to word that 2 well, anyways, i have a 91 3.1 and i have that piece o crap air intake buried in the corner. Can those dual snorkel intakes be swapped into the car?... so that i can set up a ram air? or am i better off doin the ram air with the intake i have now?
i was thinkin bout gettin a cold air intake, but i dot think its worth the money if i can do a cheaper ram air ... right?.. lemme know what u guys have seen or know
thanks
91 3.1 RS.
T-Tops
12" tube in the "trunk" (That hole they call a trunk anyways)
16x8" ROH Rims
Firehawks all Around
New BOSCH plugs and wires.
Itchin for a SLP Cold Air and new catback.
Dynomax or American Thunder... dunno yet.. suggestions?
Old Apr 1, 2001 | 05:26 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
yes, it can be done. i did it. $12 for the filter housing(junkyard) and $2 for a used MAF sensor(also junkyard).
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
Old Apr 1, 2001 | 05:28 PM
PimpRide92's Avatar
Is the MAF just to fill the gap?? And do you cut out the rectangle holes on that plastic piece in front of the radiator.
1992 RS 3.1L
Trans-Go Shift Kit
B&M MegaShifter
2 12" - Kicker XPL
Eclipse 2-Channel Amp
Sony Head Unit
Window Tint 20%
Kill's:
80's Stang 4-Cyl, A few Ricers, Ford Tempo(Weak)
'91 OR '92 Z28(Dont Ask Me How) All On A Mesh Up Tranny!
Old Apr 1, 2001 | 09:41 PM
Engine: LH0 3.1L
yes, i used the MAF to fill the lil' gap. i gutted it first. as for the plastic in front of the radiator...it has to be removed. the 2 filter setup is actually 2 pieces: the Y shaped piece and another piece that sits "in" the bumper.
Dan
1990 3.1L RS
Old Apr 1, 2001 | 10:57 PM
steven's Avatar
just run a pipe down the fender wall from the air filter metal holder and , face it forward bolt it to the bottom of the car, and instant ram air, helps, i did it. i used air intake 3" hose.
------------------[*]191(3.1)V6 1992 Pontiac Firebird[*]K&N fiter with custom Ram air[*]bosch patinum spark plugs[*]Flowmaster Exhaust w/ 3" tips[*]Pioneer reciver[*]kenwood 4x6's[*]sony xplod 6x9's[*]1 kenwood 12" powered by a 300 watt jenson amp[*]-----------[*]Future Engine Mods[*] CCS Custom Computer Chip[*]Underdrive Pulleys[*]Free Flow Cat[*] Crane Camshaft,Roller Rockers, and Valve Springs[*]------------[*]Furture Body Interior Mods[*]4th Gen Trans AM Seats[*]4th Gen Trans AM Wing[*]Ram Air hood[*]1 1/2 Din Pioneer Reciver[*]Alpine 6 1/2 Componets[*]Infinity 6x9's[*]Alpine 120x4 V12 amp[*]1 JL Audio 12w6[*] Rockford 500a2 www.geocities.com/my_92firebird
Old Apr 1, 2001 | 11:05 PM
XxMoLexX's Avatar
Seems that maybe i should jus stick with the intake i have and adapt the ram air 2 it?... Unless there is a substantial gain by doing it the other way.. seems it would be since i could route 2 air ducts into instead of just one. this make sense 2 any one?
91 3.1 RS.
T-Tops
16x8" ROH Rims
Old Apr 1, 2001 | 11:47 PM
FORD Rustangs -R- Us's Avatar
what about running one 3 inch pipe down into the left side of the wall and another into the right and connecting them into a "Y" thingy and make a really cool dual setup like he wants, the way everyone else is saying to do it
Old Apr 2, 2001 | 12:05 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
the y will create turbulence and cancel the effects of a "ram air"
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
Old Apr 4, 2001 | 06:56 PM
v6camaroguy's Avatar
i have the "duel snorkel" and make a kick *** ram air system a while ago check out the 10 dollar ram air post above
Old Apr 5, 2001 | 09:57 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If the yard wants too much for a MAF, you can always use a short length of 3 inch O.D. exhaust tubing.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
