1989 camaro wont start please help
Car: 1985 chevy camaro
Engine: 2.8 v6
Transmission: 700r4 w/ corvette servo
i have a 1989 camaro with the 2.8 multiport injection motor. for some reason i am not getting any injector pulse. i have replaced ignition coil, the module, the dizzy, the cap, the wires, the plugs, and the injectors. i have had the module test today and it was good i am getting spark and plenty of fuel to the fuel rail that injectors just aint pulsing and i dont know why i have test the injector connector and i have power to the two pink wires but when i checked the blue and green wires they are not grounding out please help open to any ideas thanks
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 1989 camaro wont start please help
You got the b@stard year... If you know how to pull codes, check for a code 46, which means you have a problem with the security module system. If there is a code 46, your engine isn't going to do anything until you fix it as the VATS disables the fuel injection.
Engine: 2.8 v6
oh i forgot the motor is 1989 but the car is a 1985 i dont think it has the vats
Engine: 2.7L V6
Axle/Gears: 4.41
If the engine has been swapped with the harness (ECM is part of the engine harness), and it's cranking and has spark and fuel at the rail but no fuel injection, check for the code. It's best to pull the codes anyways in case there's something else funky going on. At this point, it's one of a few things: Bad ECM, bad ECM ground, No VATS where there's supposed to be VATS, or there is a fault between the ignition module and the ECM and the ECM doesn't know the engine is turning over.
Engine: 2.8 v6
i swapped the motor in the car a few years back and didnt swap harnesses everything just fix right just one day went out side to start car and it started ran for a few minutes and after that it never started again it will start on starter fluid
Car: 89 Camaro RS
Engine: 3.2L V6
Transmission: 700R4 mega monster
Axle/Gears: Auburn LSD/3.73 Richmonds
will it start and die right away..with the starter fluid.... if so it might be your ecm...
Engine: 2.8 v6
yes but i just put brand new ecm in car and still doing the same problem
Engine: 2.7L V6
Axle/Gears: 4.41
Did you check for codes yet? Are you sure that both connectors at the bottom of the distributor are plugged in fully and have no broken wires or corrosion?
BTW, how did you check for an injector ground pulse at the harness, exactly?
Car: 89 Camaro RS
Engine: 3.2L V6
when you crank the motor without the starterfluid do you smell gas at all. cause one I do know is that our injectors poor gas into motor like crazy when cranking without a spark
Engine: 2.8 v6
the connectors are fully plugged in and i dont know if there is any broken wires there might be some wire under dash or something i just dont know where to start and i checked for the ground injector pulse with a test light by unplugging the injector harness and i found that i had power to both pink wires but when i checked to see if the green and blue grounded out there was nothing and i dont smell any gas at all but i have great psi to the fuel rail that the injector fit into
Car: 89 Camaro RS
Engine: 3.2L V6
yeah check the fuses and if they are good i would check the fuel pump relay. if u turn the key to the on position and dont here a click from the driver side of the motor its more then likely that
Engine: 2.8 v6
yeah i checked all the fusing under the dash and the two by the battery also the fuel pump is running
I have a 1987 camaro 2.8 it will run if I pour gas in the intake. It has a new fuel pump...all sensors (except egr, mas air, fuel pressure regulator)...new computer...new relays...fuses are good...injector wire harness replaced...fuel pump runs...noid light flashes when I turn the car over. the car ran real crappy before I changed the sensors, computer, and fuel pump. the old computer had a burnt spot on the board...car still ran, but I changed it out anyway. I have good pressure to the fuel rail. I have good spark. I ran the codes...all I get is code 12 over and over....the code for no codes... Any ideas ???? I have owned the car since around 1998...I have put 3 engines in it...2 transmissions. It has sat more than I have driven it since 2005
it runs now ..still has some issues....pumped all the old fuel...flushed the lines...put new fuel and it started. it gets poor mileage...pops and back fires...does not want to idle. I rechecked the t.p.s. its in spec...fuel pressure is great at the test port (42 lbs. with a gauge) , I put a timing light on it and discoed the wire under the hood to disable the electronic advance but it seems to still be working even with the wire off ??? I have seen posts that say to ground the diagnostic pin on the port and run the engine like that to time it. I have also seen warnings not to run the engine with the pin grounded. will it damage the ecc ??
If you are having problems with fuel delivery and the car has been sitting I would definitely start with pumping the old fuel out flushing the lines and putting good fuel in.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
