cruise control question
Old Apr 14, 2001 | 01:40 AM
HIX5000's Avatar
If my camaro is equiped with cruise control should I have two or three cables connected to the lever on the throttle body?
1988 Camaro RS
2.8L five speed
accel cap and rotor, crane cams 8.5mm wire
TB bypass
Old Apr 14, 2001 | 02:33 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
you should have the TV cable which is the one on top, a cable connected to the gas pedal(can't remember the name) this one is on the lower part, and a third cable for cruise, also at the bottom. if you think about it, the throttle plate MUST be open for the engine to run/accelerate. so if you hit cruise, your foot is not on the pedal....but something HAS to open the throttle, right?? it won't open magically. that's what the cable is doing. it's basically holding the throttle open for you.
EDIT: crap, i just realized you have a 5-speed. you don't have a TV cable then. i honestly don't think cruise is available with a manual trans.
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
[This message has been edited by CaliCamaroRS (edited April 14, 2001).]
Old Apr 14, 2001 | 03:06 AM
HIX5000's Avatar
My turn signal lever has the cruise control options on it, but it has never worked. I think the tb has two cables on it, I'll check tommorow.
Old Apr 14, 2001 | 11:19 AM
SUPER-SPORT-CHEVY's Avatar
<font face="Verdana, Arial" size="2">Originally posted by HIX5000:
My turn signal lever has the cruise control options on it, but it has never worked. I think the tb has two cables on it, I'll check tommorow. </font>
You might also check the modual its self. I found out last night that some one gutted the brass spring pice that actually runs the cruise on mine.
Old Apr 16, 2001 | 01:45 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Here's something that might've happened, too! The guy I just did the 2.8/2.8 swap with; his column has no cruise control lever on it. However, he has all the cruise control pieces under the hood! Someone switched his steering column and didn't bother to get one with cruise.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Street Lethal
Aug 12, 2015 11:33 AM
Bull86
Aug 10, 2015 05:43 PM
