how much boost can a stock 2.8 take?
Old May 17, 2011 | 11:11 PM
Benwlsn87RS's Avatar
Car: 1987 Camaro RS
Engine: 2.8l 60* v6
how much boost can a stock 2.8 take? , any tips? can stock handle 15-18 psi with a good tune?
Old May 17, 2011 | 11:16 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: how much boost can a stock 2.8 take?
i heard 10ish tops, if its a good starter motor though and a good tune i dont see it not lasting a little while atleast, if it blows up just do a rebuild. lol
Old May 18, 2011 | 12:26 AM
project89's Avatar
10-20-30 psi is all possble. its all in having the right turbo, the right tune
Old May 18, 2011 | 05:43 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Mine was happy with 15 psi and a little nitrous for quite a while.
Old May 18, 2011 | 07:00 PM
Car: 1987 Camaro RS
Engine: 2.8l 60* v6
alright. because i was thinking about a Rear Mount setup. i heard sts has a universal kit. or for that matter i can probably get the kit they sell for ls1s and it might fit.
Old May 18, 2011 | 10:16 PM
project89's Avatar
save urself lots and lots of money and ust build ur own tear mount kit.
the most expsensive part will be the oil return pump , the turbo and the oil lines.
any muffler shop can weld the turbo flange onto the end of the ex system were the muffler is
Old May 18, 2011 | 10:45 PM
Fallen2603's Avatar
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
I would highly, I repeat, HIGHLY RECOMMEND NOT doing that. I had this idea before, and asked STS about it. The turbocharger they said would be best for my the V6 was totally the wrong size and would have made boost at probably...10,000rpm. Okay, I'm exaggerating, but it still would have been a terrible turbocharger for a RMT set-up on a V6. The best way I've found to do the RMT set-up is like what project89 suggested. Or, get PaceSetter headers and DynoMaxx cat-back exhaust system, cut the cat-back exhaust pipe at a good place for the turbo, and have a flange welded there for the turbocharger. Also, having the piping ceramic coated should help with heat-retention, and, possibly, improve your spool-up time. I used to be in contact with a guy who had a RMT set-up on a 3400-swapped Cavalier. He was using a Blouch Performance turbocharger with a version of their Dominator 3.0 XTR billet compressor wheels in a TO4E housing, with a T3 Stage 3 .63A/R turbine section. He was making about 310WHP and 430lb-ft of torque with peak boost at 4,000rpm, peak torque at 4,100rpm, and peak horsepower at 4,600rpm. He was running 16-18psi. Hope this helps.
Old May 19, 2011 | 12:47 AM
project89's Avatar
speak with this seller on ebay , he builds these, the wastegate and turbo are ebay specials , but if u could snag a kit with the piping oil pump and lines without the turbo and wastegate for a cheap price u could score a pretty good deal on a bolt on system
the reson i say see if u can get it without the turbo and wastegate is u can get a wastegate for 50 bucks and a decent sized turbo for the v6 for about 125 bucks
so if he knocks the price down considerably without those items it would be worth it
http://cgi.ebay.com/ebaymotors/REAR-...item3367e2c086
Old May 22, 2011 | 10:11 PM
Car: 1987 Camaro RS
Engine: 2.8l 60* v6
alright, will do.
Cleotiz
Jan 6, 2018 08:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
1992Vortec
Aug 31, 2015 08:05 PM
86White_T/A305
Aug 17, 2015 12:16 AM
