Gas Mileage
Gas Mileage
Before Stat-16MPG
After Stat-20.5MPG
I still have to get a new O2 sensor. Just figured I'd share the difference between a 160 stat (before) and a 180 Stat (after).
Smile, you're in my rearview I'm joking, I have a v6.
Respect My Authoritaw {Cartman Voice}
See pics @ Billy's Firebird
92 Bird 3.1L Auto--Best $750 I ever spent....DRIVE IT LIKE YOU STOLE IT!
Kills:93 Mustang LX (Before Mods),98 or 99 Dodge Stratus (tough one, edged out at 40),92 Camaro RS 305 TBI-Not too fair, his fuel pump went out 2 days later. Nice car, but not running right. 97+ Honda somethin or another...modded....kept at my door the entire way
Close Calls-94 Grand Am 3.1 V6, 92 Cavalier 3.1 V6
01 Porsche 911 Turbo (Had em till first gear)
Mods-Jet Stage 2 Performance Chip, Accel Cap/Rotor, Accel 8.8 MM Wires, Accell Coil, AC Delco Rapidfire Plugs, Dynomax Catback, K&N
AIM name OVRCLCK350
Best LOUSY Run...17.263 @ 77.79MPH
In a Dog Eat Dog world, I STILL go after tha cat.
After Stat-20.5MPG
AIM name OVRCLCK350
how much was ur stat and where u get it?
1992 Firebird automatic, brand new engine/tranny/brakes/tires..paint is getting touched up- Medium blue
Mods that came w/car - New dual exhaust, maybe lowered cause the tailpipes (angled down 1 inch) scrape on driveway and so does front end..the accual fascia gets stuck if u go less than 2 mph! maybe new wires/plugs, and deff. a POSI unless the car came with the 2 wheel tire spin rear
"The 92 firebird..not the first to burn out..OR eat pavement, but does a D@MN good job at it! I got pics to prove it!"
"Never let a girl drive your car, unless ur looking to part it out"
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Uh, simple...it didn't. Yes, a warmer engine will lean out the fuel curve, but 4.5 MPG worth?? Uh, no. Coincidence. The only way to truly gague it is to run 5-6 tanks with each stat, then compare.
If you did do that, then my apologies...but that would tell me something was screwed up hardcore with the 160, 'cause you can't gain 4.5 MPG by a friggen stat...
Jason E
'89 Camaro RS 2.8
Medium Grey Metallic
2.8, A4, T-tops, 90k miles
'97 Z28 w/30th Anniversary package
LT1 (obviously), 6 speed, t-tops
White with orange stripes, killer system, 41k miles
Speed Kills...Wanna live forever? Drive a Ford.
Long Live #3...
Jason E
'89 Camaro RS 2.8
Long Live #3...
Sure it CAN.
How,
The engine is computing in a different mode, that's more fuel efficent.
Caused by hotter running engine, the way the factory designed the car to operate at, hot temps.
Your statement of several tankfuls is very correct, too.
Let's hear what happens.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
How,
Chat Soon,
KED85
Karl
Jason, I swear man, that much MPG worth. Reason why: If your car never reaches the point where your computer utilizes sensors, then you're in "Warmup" mode, where you're wasting fuel.
And get this: The 16MPG, was nothing but HWY, and the 20.5 is mixed City and HWY. I'm happy now....I mean with gas at $1.79 I need all the help I can get.
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
Also if your car is in warmup mode it will never lock the torque convertor which will really hurt fuel economy. I ran a 160 in my camaro and the tc still locked so I knew it was not in warmup mode. Modes cars won't run at 160 even if they have that stat. The rest of the cooling system usually can't keep the temp there.
92 Firebird 3.1 ~ MSD ignition, coil, 8.5mm wires, Exaust, cat, ram air, k&n, tbi bypass, new moog suspension, hotchkiss tie rod links, sfc's, kyb's, wonderbar, coils, ES poly bushings, lower control arms, panhard bar, 17" rims, 265/40/17 kumo tires. 86 Camaro 2.8, 1951 Chev 327, Four-wheeling hybrid with 40" tires, chevy engine, chevy tranny, jeep axles, pulls 1000 on 23 degree ramp.
Mine would stay right at 160 unless I was driving in the city, then it'd go on up a lil. I have a problem with sitting somewhere, looking down, and realizing I'm at 220....hope that 220 isn't too bad for the car.
No, it's operating correct.
I was just informed that:
Water boils at 218 degrees.
Our fans turn on at 220.
I recently was going thru water, alot.
NO leaks, etc.
NONE!
I asked radiator shop.
Was informed I was boiling water & it was evaporating.
So, last night, added 1 gallon of antifreeze.
Tomorrow (Sat) AM gonna see what happened.
I just took it for a long (from LA) drive with the family to Orange County for cameras & to say hi to my model to do photoshoots.
Milage was incredible about 20+. 70 mph most of the way.
Best milage is by "kissing" the gas pedal and keeping engine vacuum at about 15 inches.
Chat Soon,
KED85
Karl
NO leaks, etc.
NONE!
Chat Soon,
KED85
Karl
I wanna get one of those lil gauges that measures your fuel economy. I seem to be getting even BETTER gas mileage now. I finally figurd out my gauge too. At the F that means I've burned 1/3 tank, 1/2 means about 2/3 burned, and Empty, of course is all of it. I used to be hitting the F at like 70 miles, and last time (new stat) I hit it at 92.4, and this time (maybe getting better) I hit it at around 102.3.....so I dunno.
Glowsock
Sep 11, 2015 11:09 PM
MikkoV
Sep 9, 2015 04:25 PM
