went to the track, 60' times suck!
Old May 17, 2001 | 04:36 PM
3.1 firebird's Avatar
I could only manage a 16.5 . My 60 foots are killing me. Whats really weird is I;ve found out that .02 or .03 on my 60 foot times equates to about a tenth off a second from my 1/4 miles time.
for instance:
my best time last year was 16.09 with a 2.21 60'.
a week ago... 16.3 with a 2.26 60'
16.4 with a 2.27 60'
and last night a 2.29 60' going 16.5.
so it looks like all I need to do is get the 60' down in the 2.19-2.20 range and I will be doing 15's, but my 3.73's coupled with the open rear end and all my mods are really killing me off the line. oh well.<vent off>
Old May 17, 2001 | 06:17 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Get drag tires for the track or use the sticky compound stuff ive even seen people poor coke and sugar water on there tires and burn out with it so they iwll get stickey
Old May 17, 2001 | 07:49 PM
coke and sugar? I should try that one
Old May 17, 2001 | 08:37 PM
Red91Bird's Avatar
Man get slicks and you will be all over the 15 mark Try "street slicks" too like hooser or MT's. You are very close to the 15's that they will help ya. Also ya might wanna try playing with your rear springs. Airbags might do the trick, Traction/lift bars and even body bars might do it. There is .3 seconds in any of those if you haven't tuned the suspention yet
David
Old May 17, 2001 | 09:30 PM
Brian K's Avatar
Consider playing with your tire pressure... Overinflate the front and under-infalte the rear.... I think 30 or 28PSI rear, and 36 38 front I got my best times...
Old May 18, 2001 | 12:47 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
What about un-doing the front anti-sway bar end-links? Isn't that supposed to help with weight transfer (as long as the ends of the bar don't drag on the racetrack)?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 18, 2001 | 01:48 PM
Red91Bird's Avatar
Dumb question:
I have seen yer sig before and i am going off memory here...
Ya have a good cam, headers, shaved heads chip and posi....
I look at your times of 16 flat... Thats very respectable for our cars. If driven right you should be able to hold with a same year 305 to about 50 to 60. But when i see your sig i ask myself WHY are you not doing the next stuff to get ya into the low 15's NA
Port/gasket match the intakes. - easy weekend work.
Get a port and polish on the heads with the work going into the exhuast side, light pocket porting on the intake side. - can be done yerself over a week or get it done.
Get a old TB and get it reworked OR go to a 53mm TB from a 4th gen 350 motor like the LT1. - Can be done yerself or get it done
Get a custom chip programed - or do one yourself. - can be programed yerself or get it dynotuned.
Get a fuel/spark managment system - these are worth so HP and TQ - Holly commander series are awesome. They control EVERYTHING.
Go for a 50 to 75 shot of NOS on a dry system. - easy as pie.
Bro, you are close to having a real nice V6 runner, your just not matching parts. If i misread your sig please forgive me. I just REALLY wanna see a second person make it into the 13's on a 3.1L it can be done
David
Old May 18, 2001 | 09:01 PM
thanks man for the suggestions.
my mods are:
*crane 2030 cam
.020 shaved off heads
* 302 V8 springs
* 3.4 pacesetter headers
*2.5 inch catback with super turbo
*cold air intake
*hypertech pullies.
*acell 8mm/ high output coil
*B&M shiftkit
*3.73(open rear end)
My problem really isnt power its traction, the car is capable of AT LEAST 2.21 60 foots. and I;m doing 2.27-2.29's, which is making run several tenths slower.
Old May 20, 2001 | 09:29 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Get a Posi rear end. That will double the amount of rubber that you are getting traction from.
Old May 22, 2001 | 08:32 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
3.1 Firebird
<font face="Verdana, Arial" size="2">*crane 2030 cam</font>
I was wondering, how many horsepower do you get out of the crane cam, and what does it do to your gas milage...With all your mods what is your milage like?
Old May 22, 2001 | 11:55 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
i second glenns opinion (and also some fat rubber..im gonna run some bfgoodrice comp t/a z rated 275/50 17 in back and 230 (i think) 50 r16 in front and posi it
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, Auto Meter Gauges (Water, Clock (needed one) Fuel Pressure, and 5" monster tach) 4th Gen Seats
" I'd rather run last in a full out race, than to NOT run at all ".
Old May 23, 2001 | 09:08 PM
Brian K's Avatar
Don't overlook just getting a locker and 4.10's.....
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
BurlyChev
Aug 16, 2015 09:08 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
