Fan sensor
Old May 29, 2001 | 05:25 PM
Monkie's Avatar
Fan sensor
Bought the 92 RS back yesterday and I got a few problems . Guy ran in the back of someone so there is a crack in the front of the car (need a new nose). Clutch is slipping BADLY when you get on it hard. And the fan doesn't come on at all! So I got the temp sensor that tells the fan when to come on. I hope this is the problem. But I cant seem to find where it goes. Can anyone help me out??? Thanks alot!
Old May 29, 2001 | 09:20 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Not to sound stupid, but is your coolant full? If It isn't, the temp sensor for the fan wont even register....so maybe its not gone... but if its full of coolant...well, I'll see where it is tomorrow.
Old May 29, 2001 | 09:41 PM
Monkie's Avatar
Ok I noticed that the coolant in the reservoir (sp) was empty. But the coolant in the radiator was full. So I filled it up in the reservoir (sp) and in less than 3 days it was totally gone. I didnt notice any leaks in the radiator so what is up? And the fans aren't comming on damnit.
Old May 29, 2001 | 09:51 PM
Ovrclck350's Avatar
Monkie's Back!!!!
Old May 29, 2001 | 10:43 PM
KED85's Avatar
Pesky V-8ers come visit us & bitch!
Geeze!
One fan sensor is in the worst place possible, back of passenger side cylinder head.
Keep filling with water, until you find the leak.
May be head gaskets, too.
That's what it was/is on my S-10 Blazer.
BUT!!!
It could also be a bad fan motor!
Try hot wiring it first, to test it!
IF it's ONLY water, it's evaporating. Water boils like 210*
Fan kicks on at 220*
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old May 29, 2001 | 10:45 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
This may be a long shot, but check for water in the oil. Turn the engine on and look to see if water sprays from anywhere. The same thing happened to me when my TB bypass hose clamps loosened up.
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, Auto Meter Gauges (Water, Clock (needed one) Fuel Pressure, and 5" monster tach) 4th Gen Seats
--For Sale--
(Who says drumsets are cheap? selling my car to get a new one..) EMAIL ME!
" I'd rather run last in a full out race, than to NOT run at all ".
Old May 30, 2001 | 08:56 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I had an oddball leak like that once... one of my heater hoses cooked against the edge of my exhaust manifold. It made a pinhole leak that would spray onto the exhaust and "disappear"- no drips on the ground. I finally caught it by raising the hood to do an oil change, and I saw steam...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 30, 2001 | 05:43 PM
Joe_L's Avatar
Car: 1995 Z28
Well, I am not sure what is wrong with your car, but seeing how I am having Rad Troubles myself, I have a suggestion.
Run the car till its warmed up, then shut it off. Pop the hood, and look under. My car only leaks a small amount while driving. But once it is shut down, all the heat and pressure from the motor pushes the water back through to a hole on the passengers side plastic on my rad.
(Its only a pin hole, but when I shut it off, it will blow a couple of litres through it in a matter of a few minutes...)
[This message has been edited by Joe_L (edited May 30, 2001).]
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
FormulasOnly
Sep 10, 2015 09:07 PM
