Starting my engine build.
Old Jun 10, 2011 | 10:35 AM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
I got a free 3.4 shortblock and 4l60 from my tech school, lock said to only have about 10 to 20 miles on them. The car was donated new then stripped to pieces. I plan for a 3.4/3400 hybrid motor. Im gonna keep the 3.4 pistons so its gonna be high compression.
The stuff I plan to use:
ARP main studs : http://wot-tech.com/shop/gm-60v6/mai...t/prod_91.html
ARP Rod bolts : http://wot-tech.com/shop/gm-60v6/arp...s/prod_31.html
ARP head studs : http://wot-tech.com/shop/gm-60v6/arp...t/prod_69.html
Chevite main bearing: http://wot-tech.com/shop/gm-60v6/tri.../prod_267.html
Chevite rod bearings : http://wot-tech.com/shop/gm-60v6/tri.../prod_266.html
272H cam
Now The stuff I need help with, What thickness head gasket should I use?
http://wot-tech.com/shop/gm-60v6/340.../prod_247.html
And also what size pushrods will I need?
Attached Thumbnails Starting my engine build.-picture-123.jpg   Starting my engine build.-picture-124.jpg
Old Jun 10, 2011 | 12:09 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Starting my engine build.
Don't waste your money on the ARP stuff... It's REALLY not needed.
I have a set of .039 compressed gaskets I can part with. This will work with the RWD pistons, since they stay in the block at TDC.
You're going to have to measure for the pushrod length once you get to that point. Changes in cam, head gasket thickness and rocker style all have an effect on the pushrod length. Most of the time custom length pushrods are needed.
Old Jun 10, 2011 | 01:29 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Really don't think the ARP stuff is needed? I was thinking at least the Rod bolts would be for spinning high revs.
Old Jun 10, 2011 | 01:40 PM
When's the last time you've heard of a rod bolt letting go in these engines?
Old Jun 10, 2011 | 01:46 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Fair enough, But I still need to find rod bolts. Someone took the motor apart before I got it and lost half of them. Same with main bolts, I only have 4.
Old Jun 10, 2011 | 03:45 PM
In that case, order up the ARP bolts, since you need to buy them anyway. They would likely end up being cheaper than the OEM bolts. lol
Old Aug 28, 2011 | 08:19 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
looks good already haha, hope this is yet another long involved and very technical v6 build thread
Old Aug 28, 2011 | 09:46 PM
project89's Avatar
line bore the block, and have the rods resized, rods have to be resized with the rodbolts anyways. but as far as the main caps u have no idea if somone mixed them up and they are not in the right places.and mains should really be align bored once u change the bolts or goto studs anyways
Old Sep 11, 2011 | 07:26 PM
backgammon7's Avatar
Car: '86 SC
Engine: 2.8
Subscribed
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
