anyone with hi-perf coil...
Old Jul 5, 2001 | 04:54 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
i got a accel coil the other day and i went to go put it on my car, but i couldnt find a way to get the coil bracket off, because the EGR valve was in the way of one of the bolts. anyone have any suggestions on taking the coil bracket off?
Old Jul 5, 2001 | 06:36 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
i had to completely take all that crap off, took off the alt bracket, removed the EGR..
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
Old Jul 5, 2001 | 10:00 PM
KED85's Avatar
Here's what I did.
I put the coil, on the firewall, by the distributor.
Mount it in that thing?
I threw mine away, when I did my swap.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jul 5, 2001 | 10:21 PM
ChevyGuy87's Avatar
Engine: 4.0
do i need to replace any gaskets if i take the EGR off?
Old Jul 5, 2001 | 11:11 PM
KED85's Avatar
IF you do not break the gasket, nope.
IF ya did, go to the parts store & just get exhaust gasket stuff, smear on the gasket.
Slap it back together.
I NEED THE ACCEL WEBSITE ADDRESS.
Does your packaging have it?
THANKS!
Chat Soon,
KED85
Karl
[This message has been edited by KED85 (edited July 05, 2001).]
Old Jul 5, 2001 | 11:52 PM
http://www.mrgasketco.com
1989 Firebird
Coming for my v6:
#3 Forever
[This message has been edited by Graeme'sFirebird (edited July 05, 2001).]
Old Jul 6, 2001 | 09:19 AM
KED85's Avatar
WAY COOL MANY THANKS!
Chat Soon,
KED85
Karl
Old Jul 6, 2001 | 10:58 AM
Kevin S's Avatar
Why don't you put the Accell coil inplace of the OEM coil?Thats what I did.I removed the rivits that held the OEM coil.The screw holes on your Accell coil will match perfectly to the holes on the coil bracket.
Kevin S
89 RS w/2.9
modded some but not heavily
SIMPLE SIMON met a Pieman Going to the fair, Said Simple Simon to the Pieman "What have you got there?" Said the Pieman unto Simon "Pies, you ********!"
Old Jul 6, 2001 | 05:55 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yea I did the same thing as kevin, the crane coil comes with 2 screws so you can mount it on the stock bracket.
BTW the coil does nothing for power.
pvt num 11
Brakes
Jan 21, 2005 11:43 PM
RSpeed
Dec 27, 2003 06:35 PM
RSpeed
Dec 6, 2001 01:41 AM
RSpeed
Dec 4, 2001 03:10 AM
RSpeed
Dec 3, 2001 06:20 AM
