Timing problem
Old Jun 25, 2011 | 04:23 PM
amarkew's Avatar
Car: 89 RS
Engine: 2.8
Timing problem
After replacing timing chain and gears I set the timing to 10 deg with the tan/blk wire unplugged, it will idle ther but lags when given gas. I plugged the wire back in and cleared the codes, now it wont idle but revs up good? Its an 89 RS with a 2.8 it was running very good before the chain broke.
Old Jun 25, 2011 | 08:03 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: Timing problem
have to do an idle relearn. search for it its been talked about alot.
Old Jun 26, 2011 | 05:55 PM
amarkew's Avatar
Car: 89 RS
Engine: 2.8
Re: Timing problem
Replaced pickup coil and she's up and running. Found a good video on youtube for replacing it. Why didn't they use more manly wires on these things?
Old Jun 28, 2011 | 10:45 AM
amarkew's Avatar
Car: 89 RS
Engine: 2.8
Re: Timing problem
http://youtu.be/K5QRK9VZwcM is the pickup coil replacement video part 1, dont really need part 2 its just the reverse order reassemble.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
