ATTN:Camaro_hunter_d & 20-PSI & other fast V6'rs!!
I was reading some replys you both made to the topic "Just curious about v6's" made by IROCThe5.7L. I was just wondering what all mods have you done to your V6 to make it run so good. I have a 3.1L V6 that I want to make run faster and better and I was just wondering what all I can do to make my RS run faster. If you could please list what I should do first then go from there. I have a million people wanting to race me and I don't wanna be embarrassed when I can't keep up lol. Thanks In Advance!
(orignally CDnAP48)
'91 Camaro RS (in readers rides)
Dark Metallic Blue
V6, 4th Gen Seats, Sony Xplod CD Player, Pioneer 3-Way 6x9's, Infinity 4x6 Plates, 2 RF Punch 12's, RF Punch Amp, Custom Made Black Carpeted Box, Kelly Charger Front Tires. Soon to come, New Rims, New Rear Tires, Carpet, Floor Mats, Paint Job, Interior Color Change.
E-mail me for any questions or comments.
AdidasPredator15@jam.rr.com
http://www.geocities.com/adidaspredator21/index.html
(orignally CDnAP48)
Dark Metallic Blue
well with mone right now does not have much. I have platnum plugs gaped to .50 Helps torque a little and I polished and slightly ported the upper and middle intake runners. I also have taken the air box off of the car, I just have the tube, the box top the screws into the body that revels a K&N. Mainly what has helped me is learning where to shift with the 5 speed. I typically shift arounf 52-5500 if I am racing.
EDIT I forgot I switched the air pump into a vacuum pump. And I am running a 160 thermo(but thats just to keep from getting too hot.
[This message has been edited by Camaro_hunter_d (edited September 03, 2001).]
From: First one out of liberty city, burn it to the ground
20 psi is a TTA..thats why hes fast as hell..
1989 Firebird. Modded.
700r4-->t5 w/ram clutch
Cold air, 1.6 rockers, 21lb injectors, 3" y-pipe, random tech cat, 3" ipipe, flowmaster 80 series 3" in 3" out hand made stainless tips, Lakewood LCA's, Msd 6a, Msd coil, Wonder Bar, 180* stat,
Coming Soon: T/a hood, Painted,Spohn Panhard Bar, 4thgen Front Seats, Cam!, Msd 8.5 wires, Posi (ACCEL IS CRAP)
"I'd rather run last in a full out race, than to NOT have run at all"
See my car Here!
In Memory of #3 Dale Earnhardt
See my car Here!
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
why did you switch it to a vac pump?
or is this for making vac in the crank case?
if so how much did you land doing that mod.
you can port the intake manifold, as well as the throttle body. replace the stock filter with either a cone filter and a cold air box, or get the dual snork from the Z28. a lower therm will help keep the car a little cooler and that should help it run a little better.
dont know how easy this would be on your cars but you can also wrap the intake in some sort of heat shield wrap to keep it as cool as you can.
you can always bump the fuel PSI up a tad though not always going to work if your car is not in need of that air.
one thing I would suggest to anyone is getting your injectors cleaned. a good company for doing so is http://www.rceng.com/index.htm. they will clean and balance your injectors for you
get a new muffler setup. the stock ones I am sure are restricting.
gut those Friggin cats if you dont need to pass smog.
those are a few of the mods you can do
you can always go in and have heads milled for higher comp. get a new cam. machine to pistons to make them lighter.
I have a new muffler with dual outlets and chrome tips (sounds great!) i did kinda mess it up when i backed up too far and hit something on a curb.... **brakes were messed up** but still sounds great... once i get my tranny rebuilt next week i will start doing some mods to the engine to make it run better and i will start buying little things to get my interior looking the way i want it. thanks a lot...and any more suggestions are welcome!!
<font face="Verdana, Arial" size="2">Originally posted by rx7speed:
.</font>
.</font>
Car: 2005 BMW 545i
Engine: 4.4L N62B44
that is one cheap mod
when I had my camaro I was thinking of buying on of those vac kits and it would have costed me 300 bucks though it was a 71 no smog pump.
sreZ28
Oct 22, 2015 08:21 AM
