need reply quick..
Old Sep 4, 2001 | 09:40 PM
nothingssafe's Avatar
Car: 86 TA
need reply quick..
k im doing my $150 tranny mount tonight(ugh) and i need to know the torque specs for the crossmember bolts, the mount to crossmember bolts, and the mount to tranny bolts. i plan on doing it in an hour so any replay would be great.
thanks
sean
1988 Camaro
2.8 with T5
K&N
Soon to be CAI or Ram Air...
http://www.nothingssafe.com
Old Sep 4, 2001 | 09:41 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
$150 dollar tranny mount?!?!
1989 Firebird. Modded.
700r4-->t5 w/ram clutch
Cold air, 1.6 rockers, 21lb injectors, 3" y-pipe, random tech cat, 3" ipipe, flowmaster 80 series 3" in 3" out hand made stainless tips, Lakewood LCA's, Msd 6a, Msd coil, Wonder Bar, 180* stat,
Coming Soon: T/a hood, Painted,Spohn Panhard Bar, 4thgen Front Seats, Cam!, Msd 8.5 wires, Posi (ACCEL IS CRAP)
"I'd rather run last in a full out race, than to NOT have run at all"
See my car Here!
In Memory of #3 Dale Earnhardt
Old Sep 4, 2001 | 09:46 PM
Drew's Avatar
40 Ft lbs.
Old Sep 4, 2001 | 10:33 PM
Car: 86 TA
the tranny mount for a 2.8 with the special crossmemeber for a manual is 150. dealer only item. i couldnt find a crossmemebr for a regualr auto or another amual, and i needed the mount quick. yeah i know this suclks, but my last one totally went out. its my daily driver and i needed it because i dont want to dish out the money if i were to screw up my driveshaft or worse...
Old Sep 4, 2001 | 10:38 PM
CHVYPWR's Avatar
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
Whats this "special" crossmember your talking about My '87 2.8 5-spd 'Bird took a $10 Autozone mount!
And as for torqueing the mount/crossmember bolts, I just tighten them up as hard as they'll go. Never had a problem with them coming loose.
Ya can't have too many fast Chevys!
[This message has been edited by CHVYPWR (edited September 04, 2001).]
Old Sep 5, 2001 | 12:36 AM
AntiVTEC's Avatar
Holy crap! 150 for a tranny mount? Serious driving can easily break a stock tranny mount. Return that thing and get a ES polly tranny mount from jegs, 22 bucks! Lasts a lifetime too!
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro.
Old Sep 5, 2001 | 01:46 AM
Car: 86 TA
k, well ijust got doen with the job. i will be posting pics i took of the crossmember and the mount. im telling you, this is the only one i cna use with this crossmember. i will post th GM part # as son as i find the receipt. its a liquid filled design. i think it might have been only in 88 with a 2.8 and manual.
Old Sep 5, 2001 | 02:50 AM
Car: 86 TA
gm part number # 14106633
cost 156 and goes to 88 camaro with RPO# MM5. sux to have a 5-speed sometimes...
Old Sep 5, 2001 | 04:50 AM
CHVYPWR's Avatar
SEARCH
SIGN IN |MY VEHICLES|VIEW CART| 877-927-7427 7am-8:30pm Mon-Fri CST
Keyword
Part Number
Browse Parts
Replacement
Accessories
Performance
Chilton's
Manuals
Brands
Partners
Tires - Tire Rack
About Us
Customer Service
Community
1988 Chevrolet Camaro Coupe 2D V6-2.8L 173cid F/I VIN S
Replacement
Manual - Mounting - Hardware, Gaskets and Seals
Page 1 of 1
Component: MOUNT, TRANSMISSION
Description glossary Manufacturer Part Number List Price Your Price Core Price Qty Add to Cart
Transmission Mount
• Usually ships in 3 - 5 business days. ANCHOR 2394 $10.26 $10.26 $0.00
Page 1 of 1
Hows this differnt from yours, I think you got took. How about some pics of this $150 mount! It just don't sound right.
(I copied this page from carparts.com)
[This message has been edited by CHVYPWR (edited September 05, 2001).]
Old Sep 5, 2001 | 10:10 AM
Brian K's Avatar
Sounds a little shady......
Old Sep 5, 2001 | 02:25 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
C'mon now, Drew posted a useful message on this before. You don't need the $150 mount. You need the $10 mount, and a junkyard crossmember (probably $30). Even if the junkyard crossmember is $100, (which it won't), you're still ahead of the game.
Here's a message (on the trans board) where we help a guy who did a V6-to-V8 swap, and blew his $150 trans mount. Keep in mind- he has a V8 trans in the car, using the V6 mount. https://www.thirdgen.org/messgboard/...ML/004482.html
Here's the original message, with Drew's picture. https://www.thirdgen.org/messgboard/...ML/002493.html The top pic is for the "normal" $10 (or $30 for poly) trans mount for V8's (all) and V6 automatics and some lucky V6 5-speeds.
The bottom pic shows mounts for a manual transmission. The left side is for the "LHO" motor- the 3.1 V6. The right side is for non-LH0 motors; as in, V8's. That's what you can make your car look like.
Therefore, with the correct junkyard crossmember, you can use the "common" GM mount instead of that special order one. C'mon guys, why spend $150 for this thing? The V8's use the common mount- and they're stronger than our V6's- we dont need a fluid filled one.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Sep 5, 2001 | 04:52 PM
Hey, just for FYI, i had a liquid filled mount on this and put a regular old mount on with no trouble, and fit the regular old 700r4 crossmember.
See my car Here!
Lbibb
May 5, 2016 12:00 AM
jbates346
Oct 21, 2015 01:50 PM
kkirch15
Interior Parts Wanted
Oct 15, 2015 02:21 PM
mattcanty
Oct 12, 2015 11:08 AM
Mdenz3
Sep 17, 2015 08:36 AM
