Mechanical/Electrical Oil Pressure Gauge
Old Sep 9, 2001 | 12:43 AM
Setzer's Avatar
I am going to order a AutoMeter Oil Pressure Gauge next week but I dont know whether to go with a mechanical or electrical gauge. Which is better/worse? Which is prefered? Any help would be awesome. Also does anyone here have AutoMeters LED Air/Fuel gauge, how do you like it and was it easy to install? Thanks dudes, you guys are awesome!
~Josh~
1992 Firebird
3.1 Liter V6
K&N Filter, everything else stock, for now!!!
Old Sep 9, 2001 | 12:58 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
What's wrong with your stock gauge?
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-Currently collecting parts for T5 swap
Old Sep 9, 2001 | 12:59 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
call me old skool "old skool", but i prefere the mechanical gauges, you can install it when you change youre oil, looks cool when the line fills with oil, and lets you know if the pump has died.
Flashback alert....I put one these in my 77T/A before I got rid of it. Was interesting to see wheen I first started it it had bout 40-50psi, when it warmed up, it had bout 0, I sold it shortly after going in the air force about a month later.
85 Firebird. $150.00
2.8 Auto.
Blown Head Gasket.
turbo has arrived,
Old Sep 9, 2001 | 01:17 AM
Setzer's Avatar
Since I have had the car, about a year now, the oil pressure gauge never worked. When I start the car it goes all the way up and stays there. It never moves, ever, until I turn the car off the it goes all the way down. Is there an easier way to fix it? Thanks
~Josh~
Old Sep 9, 2001 | 01:44 AM
CHVYPWR's Avatar
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
<font face="Verdana, Arial" size="2">Originally posted by Project: 85 2.8 bird:
</font>
Same thought here!
Ya can't have too many fast Chevys!
Old Sep 9, 2001 | 02:09 AM
Engine: 5.7 / 7.4
Setzer, replace the sending unit first, that way at least you will know if the stock gauge works properly
2.8 Auto.
Blown Head Gasket.
turbo has arrived,
Old Sep 9, 2001 | 07:06 AM
Setzer's Avatar
Thanks Project:85... About how much do they cost? I mean I will probably go and ask today. I can just go to the Autozone or Discount, right? Thanks a lot a dudes, your awesome!
~Josh~
Old Sep 9, 2001 | 08:34 AM
KED85's Avatar
You have a bad sender.
WHY?
The resistance in the sender "reads" the oil pressure.
NO RESISTANCE in the sender=the reading you see in your gauge (zero or swings to the end!)
COLD EVEN BE A BAD CONNECTION!!
Find the sender (at the oil filter), and clean the wire to the sender. Scuff sand the connection, etc, any thing you can try. Plug it back in & see what happens.
IT MAY WORK!!!!
Would not be the first time this has happened!!!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Sep 10, 2001 | 10:53 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The racers prefer mechanical gauges. They're more accurate, and supposedly will respond quicker to changes. The bonus of electrical gauges is that they're easier to connect. With a mechanical, you're leading tubing (or a thermometer line) through the firewall. With electrical, you're just leading a thin wire, and you can have that wire take tight corners, etc...
I have Summit mechanical gauges (2 1/6", oil pressure & water temp) in a dual gauge pod on the driver's side of the windsheild. The oil pressure tap for our 2.8's is above the oil filter. However, due to a difference in years, you only have one pressure tap up there. I have two. My car uses separate senders for "oil pressure, dash" and "oil pressure, fuel pump backup switch". Your car combines the two units into one. This means that you'd need a "Y" fitting to adapt your one sensor hole into a dual. The size of the hole is 1/8" NPT.
The gauge would probably come with clear plastic tubing; you can order copper tubing separately.
-Tom P (Hot rodded 1986 Firebird 2.8l)
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
