92 Camaro 3.1L dies in drive at 25 mph when warm
Old Sep 7, 2001 | 05:16 PM
Rolando's Avatar
Just purchased a 92 Camaro 3.1L cheap. I knew there was an issue with the car when purchased, and this was it would die and flux between 5g and 0 and die. This is after the car is warm. Replaced the Computer, tuned up, changed plugs, and distrib. Still is happening..... What could be the issue. Could it be the Chip, or EGR? Anyone please help, TECH said that they cant find anything wrong!
Old Sep 7, 2001 | 05:21 PM
I Cant Drive 55's Avatar
I dont know what kind of set up that year has but it sounds like an ignition coil related problem
Old Sep 7, 2001 | 10:45 PM
Rolando's Avatar
Anyone with any ideas?
Old Sep 7, 2001 | 11:40 PM
KED85's Avatar
VACUUM LEAKS
Follow every plastic hose & repair cracked part or replace the rubber section.
You'll be amazed!!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Sep 8, 2001 | 10:22 AM
Setzer's Avatar
My car did that yesturday. I was leaving my neighborhood and was doing like 25-27 and it just died on me. I have know idea what it was. It was the first time that ever happened. It never did it again.
~Josh~
1992 Firebird
3.1 Liter V6
K&N Filter, everything else stock, for now!!!
Old Sep 8, 2001 | 03:55 PM
breathment's Avatar
im thinking EGR, are u getting a check engine light? and did u replace the ignition moduel when u replaced the dist.?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
Old Sep 8, 2001 | 09:47 PM
Rolando's Avatar
No check engine light.... Until it kills. As far as the Ignition module, I am not sure because I took it to the shop for the tune-up.
Old Sep 8, 2001 | 11:24 PM
Camaro_hunter_d's Avatar
Would say IAC but It'll pop a code(I know from experiance) Vacuum leak sounds like it... as you rev higher does it run fine? If so then yes theres a major leak somewhere. As you rev higher the vacuum goes away and gets closer to absolute Atmospheric pressure. SO it dies just under 25-27 but above that it's fine?. I would read the codes and double check just to be sure. Does it do it just under load?
Old Sep 11, 2001 | 12:23 AM
Rolando's Avatar
You were correct Camaro_hunter_d, it was the IAC. Had it replaced and BAM! not a problem any more. It just sucks that when you replace that you are required to place it back on the computer and get the idle set again. But its fixed and I can move on to some more items.
Thanks for the assistance.
92camaroJoe
Jul 29, 2023 07:57 PM
Andrew6.688
Dec 13, 2015 10:59 AM
92camaroJoe
Aug 13, 2015 06:07 AM
92projectcamaro
Aug 6, 2015 01:20 PM
