Could someone answer this right quick?
Old Sep 26, 2001 | 11:29 AM
Monkie's Avatar
In a 90-92 Camaro what is that round canister that sits next to the air filter housing? And can it be moved so you could put a intake in the fender?
Old Sep 26, 2001 | 11:43 AM
Black 86 'bird's Avatar
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
If it's anything like an 86 firebird, I think it's called a charcoal canister. Something to do with the fuel. Haven't figured out why we have it though....
2.8 mpfi
My only mod: Flowmaster 40 series
check my home page for pics
Old Sep 26, 2001 | 11:53 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
It's to fiter/store fuel vapors, instead of having them vent to the outside air. there should also ba a black cotton like filter unneath it. change it.
85 Firebird. $150.00
2.8 Auto.
Blown Head Gasket.
turbo has arrived,
this close /\ to getting parts to fix it.
Old Sep 26, 2001 | 12:24 PM
SAEspinz80's Avatar
i think i have heard of people moving it before. its is right in the way. as long as you leave it connected there shouldn't be a problem, i just can't figure out where to move it to
1990 Firebird 3.1
- Auto Trans, TA Body Kit
- Home Made C.A.I. (KNN-RE-0810)
- ASP Underdrive Pulleys
- MSD 8.5mm Superconducter Wires (custom-cut)
- MSD GM Blaster Coil (8226)
- AC Delco Cap & Rotor
- Bosh Platinum +4 plugs
- Mobil 1 Synthetic Fluids
- 2.5" Hooker Aero-Chamber Cat-back (27121)
- 2.5" Hooker Elite Stainless Extension Tips (31503)
- GTS Blackouts (stickers removed - #GT034)
- TB Bypass
KILLS = Dodge Daytona, 2000 Toyota 4 Runner 4WD,
1999ish Explorer XLT, "older" Jeep Cherokee, 68ish Mustang (died completely when the light went green )
LOSSES = 300zx (took me in 2nd )
"The racing dice added 5hp...I SWEAR!"
Old Sep 26, 2001 | 02:47 PM
Monkie's Avatar
Anyone else? Would love to know what I should do with it...
Old Sep 26, 2001 | 03:48 PM
Engine: 5.7 / 7.4
see if any empty canned good can will fit over it. like those "coffe can" vaccum resovoirs on old fords. I'v seen some painted up like foldgers.
Old Sep 26, 2001 | 03:53 PM
86Chicken's Avatar
It is a fuel evaporation canister. It collects fuel vapor and injects it into the engine. It can be moved but the hoses and wires have to follow. It can also be removed but that will probably do more harm than good.
Dale
Old Sep 26, 2001 | 04:22 PM
wataru's Avatar
you should be able to remove it without a prblem. I have had mine off since i bought the car 2 years ago and no problems yet. That is if you wanna just get rid of it.
'89 firebird formula tpi
custom cold air,gutted maf(just screens),52mm tb,ported plenum,edelbrock runners and base,headers with 3" catback,tb coolant bypass,afpr@44 psi,msd 6a w\blasterII coil,3.73 posi,sf connectors and corvette servo
Old Sep 26, 2001 | 04:23 PM
nothingssafe's Avatar
Car: 86 TA
that canister is what traps all fuel vapors. if you remove it, you wont pass emissions. thats part of equipment check. also, there is no reason to remove it. just relocate it.
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
