Mod: Computer chip prices...
Old Sep 30, 2001 | 09:45 PM
c-5invalid's Avatar
hey i called summit racing and they have a hypertech chip: 3.1 v6 #122312 its $160.95
is that worth it? what are some prices you guys payed...
will i realy get 10+ more HP off of it?
also i thing i am getting a new muffler mabie a flowmaster 80 any comments of mufflers?
what about getting new high pressure pistons + angled headers? is that worth it?
_ _ _ _____________ _ _ _
Mods:
-K&N Filter
-modified air box
dress up:
-Tail light + headlight blackouts(GTS)
-Borla tips
-chrome anodized shifter ball
-alloy pedals
-new High performance floor matts(guarenteed 12 hp)
-nice sound system
[This message has been edited by c-5invalid (edited September 30, 2001).]
Old Oct 1, 2001 | 06:21 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Ok, I've never messed with computer chips before, so I don't know about the gains they provide..but I'd put money saying that one would not give you a 10 HP + increase on only a 3.1 liter.. And about mufflers. Flowmasters work great on V-8's, but I've heard many nasty things about them for V-6's. I believe the general consensus in the v-6 board is to use a Dynomax muffler.. They have a good sound, they don't break up as quickly, and they're a hell of a lot cheaper. Hope that helps.
Old Oct 1, 2001 | 06:22 AM
Nixon1's Avatar
Old Oct 1, 2001 | 09:00 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You could better put that $160 towards another mod... save the chip for something you do when you're running out of other mods. Sure high pressure pistons and angled (?) headers are worth it; but are you ready to do that stuff after only doing a K&N? There's plenty more (and cheaper) things to do besides jumping on a "buzz-word"...
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Oct 1, 2001 | 03:43 PM
c-5invalid's Avatar
i was told that if you increase the pressure in the chambers that that would boost the hp tremendously... and angle heads could give me like 20 hp
Old Oct 1, 2001 | 06:48 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I got a fast Chip Stage 2 for 40 Bucks . I have a Flowmaster 80 series it sounds really good but at higher RPM's like 4k and up it sounds deacent but kinda *****
Old Oct 1, 2001 | 10:16 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
My Hypertech chip was $99 at Auto Zone when Summit wanted $125...
Old Oct 2, 2001 | 07:59 AM
SAEspinz80's Avatar
i am yet to do a chip...ideally next spring with a random tech cat. but as for exhaust i am running a 2.5" hooker aero-chamber. it was 80 for the muffler...250 for stainless steel custom work and welds on the exhaust piping. i also hear that dynomax is a great buy at about 180 for a full cat-back and it sounds nice from what i hear too..
heres the sound clip:
http://uhawab.hartford.edu/rblanchar/hooker.mp3
1990 Firebird 3.1
- Auto Trans, TA Body Kit
- Home Made C.A.I. (KNN-RE-0810)
- ASP Underdrive Pulleys
- MSD 8.5mm Superconducter Wires (custom-cut)
- MSD GM Blaster Coil (8226)
- AC Delco Cap & Rotor
- Bosh Platinum +4 plugs
- Mobil 1 Synthetic Fluids
- 2.5" Hooker Aero-Chamber Cat-back (27121)
- 2.5" Hooker Elite Stainless Extension Tips (31503)
- GTS Blackouts (stickers removed - #GT034)
- TB Bypass
KILLS = Dodge Daytona, 2000 Toyota 4 Runner 4WD,
1999ish Explorer XLT, "older" Jeep Cherokee, 68ish Mustang (died completely when the light went green )
LOSSES = 300zx (took me in 2nd )
"The racing dice added 5hp...I SWEAR!"
Old Oct 2, 2001 | 08:01 AM
Brian K's Avatar
For 160 buy a dynomax cat back instead or a crane 2030 cam. Don't waste your money on a chip until you have a few better mods like cam or roller rockers or double roller chain. I had the hypertech chip and it was not worth it. It only removed the speed limiter and did nothing else for me. I would not recommend it, I would recommend a jet chip or fastchip instead. GET THE CRANE 2030 cam instead.
Old Oct 5, 2001 | 11:36 PM
Camaro_hunter_d's Avatar
umm well no one makes headers... as for the chip do yourself a favor and spend it on something better. After a while spend the money for the chip to buying Prom burning equip to make your own chip and be alot happier with the performance gains. I have the BIN for the 3.1 if anyoone wants to look at it. Just email Emerald_iles@yahoo.com for it. You can remove the speed limiter, increase the "power enrichment" mode, raise the richness of the fuel system, even set the "shift" light to certain RPMs, so it will actually be like a free 50 buck aftermarket shift light. Heck you can even change your speedometer readings with different tires and gears!. If its controlled by the comp you can change it!.
Old Oct 6, 2001 | 04:18 PM
Brian K's Avatar
Do the Crane 2030 cam before you toss money away on a chip... Search down for 3.1 mods and read it..
Old Oct 6, 2001 | 05:21 PM
FAST RS's Avatar
I paied 40 bucks for my FastChip Stage 2 hehe thanks 3.1firebird i love that chip
Old Oct 6, 2001 | 09:07 PM
Brian K's Avatar
My fastchip seemed ot help too, but if I had it to do all over again I would never waste my money on Pulley, Chips, or high performance plugs till I have the valve train done.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
