Test for the Charcoal Canister Purge Valve?
Old 09-14-2011, 10:34 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
My 3.1 has been idling high on start up and wanting to die when put in gear until it is warmed up... found a comment on line that this might be because the purge valve was not working and it making the computer richen things up too much. Anyone have experience with this and no of a test or way to check the valve and solenoid?
Old 09-15-2011, 05:29 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Test for the Charcoal Canister Purge Valve?
I doubt its the EVAP can. The high idle on startup is fairly normal, especially if its cold out. If its almost dying, I would try cleaning out the TB a bit before anything else, carbon deposits can build up around the TB blade and IAC, making the engine stallout, esp. when load is applied, my lumina had issues with that, I would also check vacuum leaks, I say that all the time to issues on here, cause most of the time they are old and rotting away, and they can cause a host of problems, lol. Mine were so bad on my car that some of them literally crumbled in your hand.
Old 09-15-2011, 10:20 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Whatever it was is a mute point now- last night it stalled on the way home, caught fire and about burnt to the ground. I will post pictures when I have the heart to take some...
Old 09-15-2011, 10:32 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
woah... that's nuts.
Old 09-15-2011, 12:40 PM
Engine: 3.8, 3.4
Harsh...
Old 09-15-2011, 04:52 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Check out my posting under 'Disaster'...
Old 09-15-2011, 06:26 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I can tell you when it goes bad, it will fry a section of the ECM and not throw any codes.
Old 02-13-2012, 01:37 AM
89shane350's Avatar
Car: 1989 Chevy Camaro IROC-Z
Transmission: 700R-4
Axle/Gears: Borg-Warner rear axle 2.77
yikes terrible.
but is there a test for this valve?
Ghettobird52
12-29-2023 08:23 AM
1992 Trans Am
05-10-2023 07:19 PM
83 Crossfire TA
01-03-2016 01:26 PM
New2Chevy
09-28-2015 12:35 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Test for the Charcoal Canister Purge Valve?
