CompuCam
Old Oct 21, 2001 | 01:46 PM
Setzer's Avatar
CompuCam
For those of you who have the CompuCam, is it a lopey cam? That is really all I want to know, THANKS
~Josh~
Old Oct 21, 2001 | 02:35 PM
Camaro_hunter_d's Avatar
Its the same cam as the GM Performance parts cam.... Just cheaper. Its not that lopey but has a little.
Old Oct 21, 2001 | 08:04 PM
Setzer's Avatar
I really wont a nice lopey cam. So that is the safest cam to use? What if it was going in a 3.4? I know there has been a lot of argument about the stock cam in the 3.4?
THANKS
~Josh~
Old Oct 21, 2001 | 08:36 PM
with the Fuel Injection no you do not want a lopey cam. It will play havoc with the comp. The compu cam and trhe 3.4 cam ARE the same one. They got the up grade.
Old Oct 21, 2001 | 08:56 PM
Setzer's Avatar
So how come a stock 3.4 doesnt sound lopey at all?
Old Oct 22, 2001 | 09:22 PM
thats the cam. It sounds a little more then the 3.1. I know I have heard it with an exhaust system and it sounds pretty good. Stock exhausts do everything they can to "hide and muffle" exhaust notes. Unless you got a Rustang or some High Perfromance car.
Old Oct 22, 2001 | 10:05 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Is the CompuCam smog legal?
Old Oct 23, 2001 | 12:22 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Nope; there's NO aftermarket performance 2.8/3.1/3.4 V6 cam that's been certified as smog-legal.
But... that doesn't mean the cam won't pass emissions. A few guys on the general tech board told me that a cam affects an engine the same; whether it be for V6 or V8. They seemed to think that if you took two cams, one for a V6 MPFI computer, and one for a V8 TPI computer, and if they had similar characteristics (lift @ 0.050, gross lift, lobe sep), and if they're both "computer friendly", and if the V8 TPI one is certified 50-state-legal, that this probably means the V6 MPFI one will pass emissions.
The reason for no certification seems simple: It's too costly (money, and time) to go thru all the bureaucratic red tape to certify a 2.8/3.1/3.4 cam as emissions legal for such a small market. The V8 market's huge; thats why the companies get the V8 cams certified.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Oct 23, 2001 | 12:59 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
add an aftermarket ignition. the msd & crane cams boxes use multiple sparks at idle to about 2500-3000rpm ( i believe, this should improve emissions, especialyy for those who do the dyno test at like 25-35 mph.
martyr
Aftermarket Product Review
Dec 14, 2001 09:36 PM
86iroctpi
Nov 29, 2001 08:37 PM
DUGMAZE
Jul 29, 2001 01:04 AM
85transamtpi
Sep 22, 2000 07:47 AM
86Z
Sep 12, 2000 11:22 PM
