How to tell if thermostatis bad?
Old Oct 21, 2001 | 08:13 PM
Setzer's Avatar
How can I? The car was doing this wierd thing today. It was showing 220* so I checked the anti-freeze level. I needed to add a bit. So I kept going and it stayed at 220* and the began rising up too like 240. The strange thing is that the fan never came on. Also, I put my hand on the intake and it didnt even feel that hot. I could keep my hand on it all day. I tryed to put the heat on and no hot aiir came out just cool air. Could this be my thermostat or maybe my temp. gauge just going bad? Any info would be awesome. THANKS
~Josh~
1992 Firebird
3.1 Liter V6
K&N Filter, everything else stock, for now!!!
[This message has been edited by Setzer (edited October 21, 2001).]
Old Oct 21, 2001 | 08:38 PM
Camaro_hunter_d's Avatar
do you have heat reletively soon? like within 15 minutes. If so then its fine. If you have NO heat even after 40 minutes then its stuck open. If you temp sky rockets no matter what your car is doing its stuck closed.
Old Oct 22, 2001 | 08:20 AM
WideOpenVTwin's Avatar
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
It kinda sounds like the sending unit.
Old Oct 22, 2001 | 08:26 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
no heat, also check the divertor valve. This is what sends hot water to the heater core. check for disconected/broken vaccum lines or broken connectors.
$150.00 2.8 Auto.
Blown Head Gasket.
turbo has arrived, but put on hold (4 now)
working on getting a better engine
Old Oct 22, 2001 | 10:13 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You can also put your hand on the upper radiator hose...
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Oct 22, 2001 | 12:41 PM
mvftw's Avatar
Does a '86 Camaro 2.8L have a divertor valve? I have an overheating problem also. I put a new top end on a 2.8L MPFI, it runs Ok, but after 5 mins the Temp lite comes dim then bright, I replaced the thermostat and checked the water pump. I do Not see the coolant flowing in the rad. I'm stumped...
Old Oct 22, 2001 | 07:19 PM
You may have a bad temp or fan switch/relay. As for the diverter valve thing yeah I forgot about that. I had no heat for a while and I had just rep[lced the thermo. Found the damn thing was bad. Stuck internally so I dissed the Vaccum hose and I have heat again.
Old Oct 23, 2001 | 10:59 AM
mvftw's Avatar
A bad switch or relay would not cause the coolant Not to flow.
Old Oct 23, 2001 | 02:15 PM
87RS402's Avatar
If you want to check a thermostat it's easy. Put it in a pan of water on the stove, set the burner to hi and watch. You should notice the thermo start to open before the water boils. If it doesn't, it's bad.
Old Oct 23, 2001 | 02:55 PM
mvftw's Avatar
I know, I put a new one in. But it still doesn't flow.
Old Oct 23, 2001 | 04:06 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You might have a large air bubble underneath the thermostat. This gives the same effect as doing what 87RS402 said, except you would be holding the thermostat above the pot of boiling water.
Before you physically put the new stat into the intake manifold, did you have it so coolant was "filled to the top" of the intake manifold? Or was the thermostat pocket "empty" of coolant?
What I do on my 'stats is drill two small holes on the edge of the lip- one "north", and one "south". This is an old hot rodder's trick that allows any air to go "upward" and not form a pocket under the t-stat. I think I use an 1/8" drill bit. If you pull the water neck off again, you might want to give this a shot. Hey, I did a little internet search, and came up with a picture for you! It's of an SLP thermostat... if the pic doesn't show, go to http://www.slpeng.com , go to performance parts, and search for thermostats, and pull up the SBC V8 one.
[edit] My holes are drilled much closer to the edge of the flange, since the V6 'stat is much smaller than a V8 one- there's not that much room, but it still works. According to my gauge, the temp runs 5-10 degrees cooler than the thermostat, probably because of these holes.
[This message has been edited by TomP (edited October 23, 2001).]
Old Oct 23, 2001 | 04:26 PM
87RS402's Avatar
Tom, I don't know what thermos you use but the last few I've bought have had the hole in them already.
Another old hotrodder trick: I always boil a new thermo and measure the water temp when it starts to open. Maybe I'm just paranoid and I should always trust what the package says. It's not like it could be wrong or anything....
Old Oct 23, 2001 | 04:47 PM
mvftw's Avatar
I going to take out the thermostat and see what happens. If it still doesn't flow it should be the rad.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
