Does an exhaust leak rob power?
Old Oct 22, 2001 | 10:10 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
I've had one for about 2 years now...noticeable at cold start-up, goes away more as it gets warmer, but is always there. My uncle checked it when he checked the tranny and said 2 studs on the RH manifold are broken.
Could this cause a power loss??
Jason E
'89 Camaro RS
-Medium Grey Metallic
-2.8, A4, T-tops, 94k miles
-Hypertech chip, Accel wires/coil/K&Ns
-Alpine 60x4 and Bostons
'97 Z28
-30th Anniversary package (white with orange stripes)
-LT1, M6, t-tops, 45k miles
-Eclipse CD and 10" Aluminum sub in JL Audio Stealth box, Boston RM speakers, Xtant 403a amp
Speed Kills...Wanna live forever? Drive a Ford.
Long Live #3...
Old Oct 22, 2001 | 10:12 PM
WaynesRS's Avatar
Yes , I had one over the summer .Annoying ticking when i accelerated . After I got it fixed , faster ....Wayne
Old Oct 22, 2001 | 10:32 PM
87_Camaro's Avatar
well check my exaust out, my cat is gutted but it isn't connected correctly so it's really loose, when i put it in drive it starts shaking terribly and making my car sound so SH!TY it's unimaginable, it makes a "ting ting ting ting" noise but fast and loud, then my muffler is rusted and full of so many holes you can call it swiss cheese muffler, my tail pipes are so rusted if you were to grab them in your bare hands they would crumble...SERIOUSLY.. is htis robbing my car of power, if so how much?
byt he end of this month "within the next 2 weeks im due for my emissions test, so im getting:
1.power for performance cat "heard these are made by dynomax, and 2. my dynomax cat back exaust system.
i should have them hooked up and ready ready for action within 2-3 weeks, since my exaust is well pure ****, how much of a power gain will i get? and will i be able to actually feel it?
Old Oct 22, 2001 | 11:08 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
well the tip on my muffler came out...
took the pipe inside the muff and all
would that make me lose power?
ICQ 4116192
AIM RXspeed87
Got rotary?
header, intake, ported TB
soon to have 4.30 rear, ported intake(just need to intall)new catback,ported motor and lighter triangle
Old Oct 23, 2001 | 12:26 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Jason, are the bolts snapped flush with the head, or flush with the manifold?
I've seen two heads with that problem. My spare "junkyard" set, and the set for my friend's 2.8 (that we swapped). Both bolts had been broken flush with the manifold. When the manifold was removed, the broken bolt was sticking out.
All I did was squirt some Liquid Wrench on them, and, without waiting/heating/tapping the bolt, I put vise-grips on it (super-tight). I then proceeeded to unscrew the bolt from the head with light hand pressure!! I thought my junkyard heads were a one-in-a-million with that operation until I worked on my friend's heads.
I think the broken head of the bolt is because the shoulder of the bolt rusts to the manifold... the mech then twists the head of the bolt off. I don't think the bolt rusts to the head.
So... this long post means if there's enough bolt sticking out of the head to grab with vise-grips, you probably don't need to remove your heads to drill out the broken bolt.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Oct 23, 2001 | 10:31 PM
Jason E's Avatar
Tom,
You said "..you probably don't need to remove your heads to drill out the broken bolt."
Don't mean to sound ignorant here, but why would the heads need to be removed to fix 2 broken manifold studs??
This is exactly what my uncle said: "Its a common problem on 2.8s F bodies, the heads on the studs get ripped off, and you gotta really get in there to fix it..."
Obviously, I don't know what "in there" means, I just go with him Can you elaborate Tom? Is this gonna be a major PITA for him to do?? Its cool he only charges $25 an hour if it is
Old Oct 24, 2001 | 12:53 AM
3.1 firebird's Avatar
oh ell yes it can rob power. I hit a dip on a country road and busted a hole in the bottom of the y-pipe, alot of my power was lost. Just tonight I took it to the shop and had them weld a piece over the hole and now my power is back
Old Oct 24, 2001 | 09:46 PM
Jason E's Avatar
btt...Oh Tom P, where are thou??
Old Oct 25, 2001 | 10:27 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
(Busy with college crap)
It's just hard to get in there with a drill... there's a lot of stuff in the way. I'm sure someone can get there without pulling the head... maybe with a 90-degree adapter or something... are the studs snapped flush with the engine head or are they just missing the bolt head?
Old Oct 25, 2001 | 10:56 PM
BitchinRS's Avatar
There is a bit you can buy for your drill called a "skew driver". They sell both a 90 degree and 45 degree skew drivers. This also comes in handy when you want to replace your front speakers and have to remove the dash pad sence it can use both drill bits and screw driver bits.
Vintageracer
Jan 10, 2020 05:33 PM
bamaboy0323
Sep 3, 2015 06:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
drathaar907
Aug 6, 2015 04:20 PM
