Smog Check :(
Old Oct 25, 2001 | 05:08 PM
OneTireFire's Avatar
Smog Check :(
Hey I was wondering if any of you guyz have some tips or tricks on how 2 pass smog?
I've heard about people putting denatured alcohol in there gas......does this work?
I already know the obvious....such as tune up, new air filter, new fuel filter, new o2 sensor....etc
But I was wondering if anybody knew any thing, other that the ussual?
Thanks in advance for any help!!!
Bad A$$ Boys Drive Bad A$$ Toys
Old Oct 25, 2001 | 05:31 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
Oil change.. it lets the engine run smoother and easier with reduced emissions.. ONLY Unocal 76 premium gas, change the fuel filter, the other stuff u mentioned. Make sure the car is fully warmed up too.
1972 Chevy Chevelle "Malibu"
Hooker Headers, Flowmaster 40 series mufflers, accel 8.8 wires,Edelbrock performer intake Edelbrock Carb, Torque Thrust "D" wheels
Click here for my Malibu information
In Memory of #3 Dale Earnhardt
Old Oct 25, 2001 | 05:35 PM
Thanks!!!
Does anybody else have any tips?
(b)1986 Camaro SC(/b) (1989 Firebird 2.8 MPFI engine)
(b)Mods/b)
(list=1)
(*)Bored .40 over (*)Custom Ram Air
(*)Highflow Hermoff Catalytic Converter
(*)Relocated IAT
(*)Polished Plenum
(*)Ported and polished heads
(/list)
(b)Kills
1966 Mustang(/b) (289), (b)1991 Grand Am(/b)
(4 banger), (b)1991 CRX(/b) (without his NOS), (b)1986 Bronco(/b) (3.0) "haha" that was an easy kill, (b)1997 Taurus(/b) (V6), (b)1988 Camaro Z28(/b) (305 tpi), (b)1968-1972 Charger(/b) (no idea on the motor), (b)2 many Hodas 2 count(/b) (stop light racing ) (b)1996 Mustang(/b) (V6), (b)1986 Camaro SC(/b) (2.8 MPFI)
(b)LOSSES(/b)
(b)2000 Audi(/b) (don't know what it had) It hauled A$$ though. (b)2002 Viper(/b) (my best friend) I don't even think he took it out of 2nd gear :P
(b)My best 1/4 mile(/b) 15.82
Old Oct 25, 2001 | 05:41 PM
Has anybody ever heard of any other fuel additives that might work?
1986 Camaro SC (1989 Firebird 2.8 MPFI engine)
Mods:[list=1][*]Bored .40 over[*]Custom Ram Air [*]Highflow Hermoff Catalytic Converter[*]Relocated IAT[*]Polished Plenum[*]Ported and polished heads[/list=a]
Kills
1966 Mustang
(289), 1991 Grand Am
(4 banger), 1991 CRX (without his NOS), 1986 Bronco (3.0) "haha" that was an easy kill, 1997 Taurus (V6), 1988 Camaro Z28 (305 tpi), 1968-1972 Charger (no idea on the motor), 2 many Hodas 2 count (stop light racing ) 1996 Mustang (V6), 1986 Camaro SC (2.8 MPFI)
LOSSES
2000 Audi (don't know what it had) It hauled A$$ though.
2002 Viperp
My best 1/4 mile 15.82
Old Oct 25, 2001 | 07:46 PM
Xenodrgn's Avatar
You don't need them... I just got through NJ Dyno inspections with flying colors... I even had a tennis ball in my exhaust, and my car missing like mad...
Just do all the aformentioned, and you'll be fine...
Old Oct 25, 2001 | 10:30 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
if ya got the $, get one of those multiple spark ignitions, and if you got the gonads, run an oxygen tank line into the air intake, instead of nos, you get a lean thing going.
Old Oct 25, 2001 | 10:39 PM
BitchinRS's Avatar
Xenodrgn,
A tennis ball???? Why?
Old Oct 26, 2001 | 04:39 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Emission 104 works great used it in my moms car when we moved from WA to CA it owuldnt pass put that in passed perfect. it a a 79 Trans Am with a 403 in it.
Old Oct 26, 2001 | 09:20 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I used "guaranteed to pass", found it at Pep Boys. I passed with flying colors, so I guess it worked!
To pass NJ's dyno, I did the following a month before the test. Keep in mind I do a major tuneup every year, so I didn't need to worry about too much:
1. I put a cheap (but new) K-mart air filter in (aka the "emissions test only" filter
2. Pulled my 165 thermostat and stuck in a 190, pulled my ADS superchip and reinstalled the original GM chip
3. Made sure the timing was accurate to stock spec (10 deg adv), made sure the plugs were clean and gapped to stock spec (0.045")
4. I removed my dist cap and cleaned up the terminals of any carbon using a small, fine-toothed file
5. Used a piece of cardboard to cover 1/3 of the front of the radiator so the engine would be nice and hot by the time I took the test
6. Sprayed 1/2 can of "TB & intake cleaner" into the engine
Looks like this year, I'll have to remove my homemade cold-air intake, and reinstall the stock parts to pass the visual. I don't know if the mech would care (an air intake is an air intake!), but I've heard they're strict about that in California.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Oct 26, 2001 | 09:37 AM
Xenodrgn's Avatar
<font face="Verdana, Arial" size="2">Originally posted by BitchinRS:
Xenodrgn,
</font>
Lol, funny story...
A while back one of my two tailpipes rusted off at the muffler, and then worked loose and took the entire pipe with it... before I got back to the point where it fell off, it had been run over and ruined... So now my car is loud as all h*ll... well they won't pass you if you've got a hole in your exhaust, and they'd argue with me about it being street legal if I said it was... so I took a tennis ball held it up to a torch to make sure it wouldn't burn ( it didn't ) and then rubbed it in dirt so it didn't come into question if they mirrored in that area. Shoved it in and voila, silence. Drove to inspection, held it above idle while waiting to make sure it was good and hot and then had it inspected... passed easily... I can give you the numbers if you like...
The best part was driving home and I had turned out of the place, and was going to another road to lead me in the direction I needed to go home, and the tennis ball fell out! I just had to laugh... it would have sucked if it fell out during inspection...
But yea... I made it, you should be ok... although I'm not in Cali, so I -could- be wrong... Good luck, a good tuneup is a must though.
Old Oct 26, 2001 | 01:21 PM
Thanks again for the help guyz!!!
I'm gonna check for either "emmision 104" or that "guaranteed to pass" stuff. But we don't have a pep boys around my area, so i'm gonna have 2 try Autozone or Kragens.
I'm supposed 2 get it smog checked in about 5 days. So wish me luck!!!
Mods:[list=1][*]Bored .40 over [*]Custom Ram Air [*]Highflow Hermoff Catalytic Converter[*]Relocated IAT[*]Polished Plenum[*]Ported and polished heads[/list=a]
Kills
1966 Mustang
LOSSES
2002 Viperp
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
TBRays98
Sep 6, 2015 05:05 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
