Injector stuck open??
Old Oct 10, 2011 | 11:28 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I installed cheap reman injectors just over a year ago. Engine started and ran fine until the last month. Cold start seems ok but when hot not so much. The engine fires but has trouble finding a stable idle. Sometimes it will just dies. If I open the throttle some it seems to help get the engine running and then it will idle and run ok. When it starts hot though the revs shoot up to 3k then drop back to normal. It also seems to be using way more gas than it did. It's raining so I can't pull the plugs or check the injector resistance. Do the symptoms suggest at least one injector stuck open at least some of the time?
Old Oct 10, 2011 | 05:51 PM
87 transam's Avatar
Re: Injector stuck open??
have you ever replaced your F P R i would check that out frist any ses light on
Old Oct 10, 2011 | 06:05 PM
ex-x-fire's Avatar
Do a fuel pressure leak down test. It should over 30psi for awhile,test after the engine is off.
Old Oct 11, 2011 | 08:56 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Sounds like a vacuum leak. Check all your lines and maybe even spray some brake cleaner around the gaskets and seals, see if you get any bubbling.
Old Oct 11, 2011 | 11:49 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Rain has stopped so I do some checking. Thanks for the suggestions.
Old Oct 12, 2011 | 07:58 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
I have to hold the gas pedal 1/4 to 1/2 throttle for a good minute or two for mine to stay running when i first start it up. then idles rough, and eventually runs kinda ok half an hour later with a bit of hesitation off the line lol.. maybe we have a similar problem?? im curious.
Old Oct 13, 2011 | 12:58 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Yours is worse by the sound of it. With a computer controlled engine you should just need to turn the key. Mine was that way. I've pulled the injectors and the resistances look ok. Cap and rotor needed replaced and new air filter plus standard thermostat. I'd been using a 160 and it's been running rich. I've got a replacement set of injectors coming even if the ones in the car now are OK. I just don't have any peace of mind with them. If I've still got a problem after this I'll do some more diagnosis. Sounds like you need to as well.
Old Mar 29, 2012 | 02:35 AM
thunder69n's Avatar
Car: 87 Firebird Auto V6 2.8l
I have been having same issues, and my O2 sensors die, ( have headers ) I still have the single wire 02
I was pulling my plugs other day and noticed that 5 out of 6 look fairly clean like they been burning Fuel. 1 is covered in unburnt fuel?
I went through the pita of switching injectors around, and seeing if same cylinder fouls or if it follows my injector
I messed up in the Vid, but left spark plug is what all but 1 look like
http://youtu.be/IT2yRme7Kkk
Old Mar 29, 2012 | 10:00 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
The problem turned out to be a leaking fuel pressure regulator diaphragm. I put in a new one and back to normal starting (key only) hot or cold.
Cameeeero
Sep 18, 2015 04:00 PM
ramicio
Sep 6, 2015 11:25 AM
Jae992
Aug 27, 2015 09:07 AM
mdtoren
Aug 23, 2015 12:52 PM
