What is this ?
Old Dec 12, 2001 | 01:39 PM
WaynesRS's Avatar
What is this ?
I found what I think is a tool , still in the package .It says "Mini" Feeler Gauge"
16 top quality blades ,Etched in Thousandths and MMs . ...What the heck is this guys ? ...It kinda reminds me of a swiss army knife with all the blades excpet this thing is just a bunch of flat pieces of metal that swing out . Wayne
Old Dec 12, 2001 | 01:43 PM
89BlackBirdKid's Avatar
I could be totally wrong on this its just a guess but is it a guage for spark plugs?
Josh
1989 Firebird
Working the 2.8 to 3.4 swap with a 5 speed.
Kills: 2000 Silverado V6, 1995 v6 mustang, 1994 rodeo v6, 2001 Ford Sport trac, 1992 honda prelude riced out
Losses: 89 GTA, 95 Z28, 90 Camaro 305 TBI with mods
Old Dec 12, 2001 | 03:02 PM
Xenodrgn's Avatar
It's a flat feeler gage, as opposed to a wire feeler gage. Most everyone has one sitting in their tool boxes. Do a search at your favorite search engine for it, you'll come across a picture sooner or later.
1985 Camaro SC - 2.8L, auto.
C'mon, spin 'em for papa...
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Dec 12, 2001 | 03:12 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
hey wayne, since i am becoming a mechanic, i just got a whole lot of these with my Snap-On tool set..........they are tools used for measuring........per say to check things such as clearance and eveness........to check the clearance of something, you would simply slide the feeler gauge in between the two objects that you want to know the clearnace between, and keep sticking the gauges in until you can not fit anymore......the last one you will have stuck in will be the clearance......
or to check the trueness of a bellhousing......lay a flatedge across the opening and stick the feeler gauges inbeetweeen the flat edege and bellhousing surface............
capice?
Old Dec 12, 2001 | 04:15 PM
WaynesRS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 1991tealRSt-topGuy:
capice?
</font>
Thanx man ! ...Should have known you would know heh ? ...Interesting though . I should use it one day .Thanx ...Wayne
Old Dec 12, 2001 | 04:16 PM
WaynesRS's Avatar
Thanx to you other guys also
Wayne
Old Dec 12, 2001 | 04:38 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
the gauges are also used to check the warpage of the head/block surface. Get a machined straitedge (block of metal machined true/strait on all surfaces) put on the bottom of the heads/on top of the block where the heads would go. do 3 measurements 2-diagnal corner to corner & 1 straight across lengthwise. The usual acceptable clearance should be in the chilton book (haynes doesn't list it)
Old Dec 12, 2001 | 11:46 PM
KED85's Avatar
Also used for setting points gap.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
