Odd noise when car first starts
Subscribe
Nov 3, 2011 | 09:40 PM
So i posted a video in this tread about the noise when I start up my car, it only happens when the vehicle first starts up never happened before, it only happens for about 5 seconds then goes away and it only happens when its cold
http://www.youtube.com/watch?v=AyhBT...=youtube_gdata
Reply 0
Nov 3, 2011 | 09:48 PM
Re: Odd noise when car first starts
hard to hear fuel pump?
Reply 0
Nov 3, 2011 | 09:49 PM
its not the fuel pump im sure of it, its the whine noise when the car is running thats bothering me but it only happens for 5 seconds then goes away and only comes back when i cold start the car again...
Reply 0
Nov 3, 2011 | 10:45 PM
Guesses ..
It's some sort of bearing that is giving out due to age. Once it gets moving and warms up, it's ok, for now
Things it could be, let your ears guide you toward the direction
Tensioner pully
Water pump
ac compressor
radiator fan motor
blower motor
power steering pump
Air pump
When it gets worse it will be easier to find. That's the good news
Reply 0
Nov 4, 2011 | 06:42 AM
Remove the belt & start it when its cold. Does it do it?
Reply 0
Nov 4, 2011 | 02:34 PM
Quote: Remove the belt & start it when its cold. Does it do it?
The Camaro will still run fine with it off?
Reply 0
Nov 4, 2011 | 02:39 PM
You won't have a water pump, so don't run it for very long
Reply 0
Nov 4, 2011 | 02:44 PM
Ill run it for about 10 seconds
Reply 0
Nov 4, 2011 | 02:47 PM
That will tell you what you need to know.
When you have the belt off, spin each of the bearing by hand to see if they make noise
Reply 0
Nov 4, 2011 | 02:49 PM
Okay, thanks for you help ill probably respond around 3 or 4 im on my lunch break atm
Reply 0
Nov 4, 2011 | 07:46 PM
Well ran it without the belt, still make the same noise i put the belt back on the noise lasted for a minute then it went away
Reply 0
Nov 4, 2011 | 07:50 PM
Good elimination work. Next step is to see if it's the radiator fan. Turn off your AC, confirm it's not running, and see if the noise is still there.
Reply 0
Nov 4, 2011 | 08:42 PM
I know it isn't the Radiator fan, fan is only on when car reaches 105 degrees, and my car isn't equipped with A/C
Reply 0
Nov 4, 2011 | 08:44 PM
blower motor on? I'm starting to run out of ideas....
Reply 0
Nov 4, 2011 | 10:24 PM
blower motor is off too :/
Reply 0
Nov 4, 2011 | 10:56 PM
Im out of ideas, unless the crank or cam is worn and you are getting a grinding until oil hits it.
Reply 0
Nov 4, 2011 | 11:50 PM
Get under the hood and have someone start the car while you're in a position to localize the sound. Pay attention to the front of the engine, and the starter area. Sometimes it's easier to hear where a noise is coming from, while laying next to the car on the ground.
Reply 0
Nov 5, 2011 | 07:19 AM
well when i had the car running i heard it coming from the back of the engine block, drivers side
Reply 0
Subscribe
