2.8 firebird small oil leak?
Old Nov 5, 2011 | 09:47 AM
FirebirdDude88's Avatar
Car: 88 Firebird formula clone
Engine: Yeah its in there
Transmission: Thats in there too
Axle/Gears: Yeah there in the back
hi fellas, i got an 88 firebird 2.8 v6, and it has a bit of an oil leak. not major, but a very small drip of oil every few minutes. its coming from like the end of the engine, and ive been told to change the distributor o ring gasket. should i take that approach and do that? will that fix my problem? any help is greatly appreciated.
Old Nov 5, 2011 | 11:38 AM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Re: 2.8 firebird small oil leak?
You can usually feel around near the distributors base and see if there's oil back there those o-rings are cheap hopefully that's your issue. There's two other possibilities. One is the Camshaft cover which is on the back side of the block and is a common place for leaking and the other would be the rear main seal. Both of these however, require removal of the transmission and flex plate to replace.
Old Nov 5, 2011 | 11:45 AM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
rear main tends to be the main culprit
Old Nov 5, 2011 | 10:17 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Is that why its called the rear main?
And yeah, it would be one of those 3 things. Assuming you mean the rear of the engine, kind of helps if you specify which end...if its at the front, it could be the TC or crank snout seal.
Old Nov 6, 2011 | 09:10 AM
ex-x-fire's Avatar
Intake gasket end seals (rtv) are a known problem. You have to replace the valve cover gaskets when you do the intake & pull the dist. to change the o ring. Add a dist. base gasket from a small block chevy to your dist. to seal it really good.
Old Nov 6, 2011 | 09:25 AM
Okay. I dont need to remove the engine or tranny right?
Old Nov 6, 2011 | 09:44 AM
ex-x-fire's Avatar
To do the intake , no.
To do the rear main, yes the tranny has to come out.
You need to determine where the leak is coming from. Get a light & a mirror & start looking at the top, front & back.
Old Nov 6, 2011 | 11:44 AM
Engine: 3.8, 3.4
Yeah, he kind of does or he might waste time/money replacing things he doesn't need to, but if its coming from the front or back its probably not the intake gaskets.
Old Nov 6, 2011 | 01:08 PM
ex-x-fire's Avatar
Thats why I said use a mirror & flash light, I don't believe in doing things that are ok. Make sure what is leaking first then buy the parts.
I don't know what "end of engine" means. Most guys say rear as in flywheel side.
Old Nov 6, 2011 | 05:14 PM
84beaut's Avatar
Car: 1984 Pontiac Firebird
Engine: 4th Gen 3.4 V6
Axle/Gears: Stock
I think the rear main is leaking on mine. It leaks down and drips off of the oil drain plug and that area.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
drathaar907
Aug 6, 2015 04:20 PM
