timing
Old Nov 21, 2011 | 12:25 PM
emerald91fbird's Avatar
Car: 1991 firebird
Engine: 3.1 l v6 mpi
Transmission: auto
timing
hey i had a mechanic set my timing he set it at either 12 or 13 degrees i know timing should be set at ten but will having the car that far off be a issue?
Old Nov 21, 2011 | 01:57 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: timing
^ how does it run?
Old Nov 21, 2011 | 03:44 PM
Car: 1991 firebird
Transmission: auto
Re: timing
at start it runs rough but steadies out it also is at between a steady 1000 or 1400-1500 rmps once it steadies he adjusted the torx screw on the trottle body were plate is that conects to the gas petal
Old Nov 21, 2011 | 03:53 PM
midias's Avatar
Re: timing
Any idea why he did it? If it starts hard that usually means there is to much timing advance.
Old Nov 21, 2011 | 04:00 PM
Car: 1991 firebird
Transmission: auto
Re: timing
he said u can get away with a few degrees but the trottle was adjusted cause it seemed like the car was gonna stall
Old Nov 21, 2011 | 04:05 PM
Car: 1991 firebird
Transmission: auto
Re: timing
the car will start but it will crank crank crank start rev then die then it wil turn right or and run sightly rough
midias's Avatar
Re: timing
You can and you might gain a few ponies at the expense of premium fuel. If you don't mind how it runs live with it otherwise have him put it back. If it knocks then you will have other problems.
Old Nov 21, 2011 | 04:09 PM
midias's Avatar
Re: timing
Sounds like you need to get the timing set correctly. If you are in a real bind mark the distributor with a sharpie in a few places then retard the timing a little.
Old Nov 21, 2011 | 04:11 PM
Car: 1991 firebird
Transmission: auto
Re: timing
i dont think it will knock we had it at 7 cause when i got the car no had tighten the distrib and the timing had kept changeing n i got it close but he set it with the gun
Old Nov 25, 2011 | 05:05 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: timing
12 or 13 aint gonna hurt it. adjusting that torx screw was the wrong thing to do, though. That's why the idle is high. sounds like the iac valve needs to be cleaned and reset. if you haven't changed your spark plugs, change them (and wires).
Old Nov 26, 2011 | 01:52 PM
Car: 1991 firebird
Transmission: auto
Re: timing
okay how do i got about cleaning and resetting it? ive adjusted the torx screw down and it has more get up and go now
Old Nov 26, 2011 | 02:34 PM
Car: 91 Camaro
Re: timing
take the iac out of the top of the tb and use some carb cleaner on it. you can take the top plate off of the tb, also to clean it out. you may need a new gasket if you take that off. I forget the proper process for resetting it...do some searching or maybe someone else will chime in on that one.
you aren't supposed to adjust that screw though. that tells the throttle position sensor that you have cracked the throttle blade open...it won't idle right.
Old Nov 27, 2011 | 01:49 PM
Car: 1991 firebird
Transmission: auto
Re: timing
on the tech page it has an article on resetting the idle i did that the car wouldnt start adjusted it forward ran steady at at 600 rpms ? im kinda confused
Old Nov 28, 2011 | 07:15 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: timing
You didn't reset the ECM before you tried anything else after your mechanic worked on the engine... The 1227730 uses set parameters to run the engine, and if you put new parts on or make adjustments to help things along, you need to start the ECM off at square one so it can learn which parts are actually working again the way they're supposed to.
I used to have to set my timing at around 18* BTDC (because the defective ignition module wouldn't allow 10*), and didn't have much trouble. On 87 octane pump gas.
Idle speed should be set with the engine HOT to 700 RPM with an auto trans and about 600 in Neutral for a manual. With the idle air control motor disconnected and closing off the throttle bypass air passage.
Old Dec 1, 2011 | 06:18 PM
Car: 1991 firebird
Transmission: auto
Re: timing
ok the iac i know about what / where is the throttle bypass air passage
Old Dec 1, 2011 | 06:22 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: timing
The air passage is what the working end of the IAC seats against to either open or close off additional flow of air into the intake. The air bypasses the throttle plate by going in a passage around it. You will need to jump the ALDL as though you're looking for trouble codes (the top 2 right hand terminals) and turn the key to the ON position, without starting the engine, for 30 seconds before unplugging the IAC and turning the key off. Pull the jumper from the ALDL and start the engine, allowing it to warm up before setting the idle speed (fan should come on and then go off again just to make sure).
All this is AFTER you disconnect the battery for a minute or so and then reconnect it to set the ECM to the base tables.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
