58mark's 3.4 swap thread
Re: 58mark's 3.4 swap thread
http://www.ebay.com/itm/SBC-Chevy-43...fa29aa&vxp=mtr
on my 3.1 i have long slot non roller tips 1.6 rockers from a sbc, i just used the factory rocker ***** and lock nuts
if u want to buy a full roller rocker ur going to have to either buy the comp cams conversion studs metric to 3/8's or spend about 300 bucks for the comp cams full roller rockers for the 10mm stud
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I took this to the 2nd pic in a good 4-5hrs of assemblely. Takes time but if you just pay attention to detail, keep everything clean, and assembly lube the crap outta stuff you will be ok.
The part that was a PITA was cleaning up the block and painting everything as i didnt take it to a shop to acid dip/clean it. Cleaning and painting took about 6 hrs of time...lmao
Have to add if you are going with rockers and such might as well get a delta cam. Mine was 118 shipped to the door with lifters. Great deal in my mind.
they dont have an online catalog , u just call them up and order ur cam
ur either going to want the 260 grind or the 272 grind depending on the use of ur car
street driven mostly get the 260
if ur going to race it and have a high stall coverter and or 5 speed get the 272
cant use 1.6 rockers on the 272 grind cam though
Car: 1991 Camaro RS
Yea they only accept the phone calls. deltacam.com
Heres the paper work on the 260 grind
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
thanks. I'll give them a call. I'm so new to this, i feel like I don't know ANYTHING, like... If I get the different cam and rockers, do I have to get different pushrods too?
it makes me mad that I OWN this book, and I can't freaking FIND it anywhere.. It's been misplaced
http://www.amazon.com/Rebuild-Degree.../dp/0879388412
get ur cam before the rockers this way u dont run into issues with the valve lift numbers
what are ur intended use of the car?
are u going to port the heads/intake
or is this purley a stock rebuiild
and dont worry about that book, between all the members here there is a ton more knowledge then what is inside that book
it's going to be for a driver, but If there's mods that I should make at this point I'm going to do them before I put it together. If they don't happen now, they never will
It's NOT going to be for racing, but If mods can be made affordably and effectively, I'll do them
Not At all! I just had an opportunity to get an extra engine complete so I jumped on it
The 2.8 is running strong like brand new, which is why I'm hesitant to pull it at all. The 3.4 is like insurance for now.
def fport and polish the heads, its basically free hp, get the 260 grind cam this cam give much better midrange and lower upper rpm power
i really wouldnt worry about replacing the rockers roller tips might be worth 2-3 hp
if u want they also have a 252 grind cam wich gives the best low end boost with a lil bump in the midrange. i presonally even for a street only car would still do the 260.
even with street driving ur in the mid rpm range more then the bottom
With my 3:42 rear end and a manual transmission, It already jumps off the line respectably (for a 2.8)
I'd be more interested in mid range power and highway punch. Does that make sense?
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
^ agreed, its free if YOU do it lol machine shops around here charge out the *** though
ohwell this is cheap http://www.summitracing.com/parts/TFS-90001/
ohwell this is cheap http://www.summitracing.com/parts/TFS-90001/ Thread Starter
I'll put this an an aside... It's also in the back of my mind that I might add a turbo to the 3.4 later.... thought I would mention that in case it changes anything
it's a "might" and a "maybe" but it's worth thinking about
Transmission: 5spd
well if thats the case i'd definetly port then, and if anyone would know about a turbo 3.4 it'd be project89
the 260 cam is a great all around cam , and is a good mild turbo cam
if u have a stock clutch deff look into upgrading the clutch disk, the stock clutch will be iffy on the 3.4 with ported heads and cam, and prolly wont hold at all with a turbo
oh yeah. I forgot about the weak as water T5. ugggggg
the t5 will live with the power from a turbo engine as long a su dont put slicks on the car and do clutch dumps @ 4k rpms
for everyday street driving with a turbo it will last just fine
ok, heads need to be ported and polished.
Forget the rockers,, right?
get a 260 cam.
I'm looking at headers, but I'm slightly worried that I'll have to lose the air pump and not be able to pass the visible inspection and get the car tagged
get a 260 cam.
yeah forget the rockers, headers r no good if u need to pass a visual
Transmission: 5-speed/T-5
I don't know, I went through 2 in as many years, with my turbo 3.2L, I wasn't nice to it, but I didn't use slicks or high RPM launches, neither trans were toast by any means, but 2nd gear IIRC was howling after not long, which is why I will NEVER use a T5 again for anything more than stock applications.
got it on the stand tonight (no hoist, so it was tricky)
not sure how long it will stay there, I want to get it to a machine shop to get it checked out and cleaned.
it's a pretty clean engine, but I'm going to have it professionally cleaned before I paint it
i had a 87 iroc with a healthy 383 i never put slicks ont he car but i did abuse it badly ( was my street race car when i was younger) i powershifted it high rpm clutch dump launches and it never broke in the 2 years i had the car, though i did lose the syncros 1-2 shift would always grind
but it never failed me
on the other hand i have seen bone stock 305's destroy t5's
six by any chance were u the one who was big into nisian engines?
friend who owns the farm were my iroc is currently at is looking into turbocharging his pickup truck and it has a 2.4L 4 cyl in it
i know somone in the v6 section knows alot about nissian stuff and i have a few questions
Car: 1991 Camaro RS
Love this thread.
Port an polish those heads and a cam and youll love the power to be had. The 260 cam isnt to strong. I really didnt notice a difference till I puched the throttle and it would not die above 4krpms like before. It will definily make the driving experience much funner for ya. But on my blend the heads were ported so im sure that played a great deal with it.
Im not sure if anyone said it or if you allready know but definitly get a new timing set while your in there and a new o-ring for the dizzy.
Car: 1998 Camaro Z28
Engine: 6.0L
When I had my 3.4, I got a Melling MTC-5 cam/lifter set from Summit for around $100 and loved it. It's a nice budget cam to pick up and good quality. Also Comp Cams 1.52 roller tip rockers... you'll be happy.
Car: 1991 Camaro RS
58mark, What color are you planning on painting the block..exc?
Im not sure where you got a Melling Mtc-5 lifter and cam for 100 bucks. As its closer to 200 bucks from summit. All I see is the advertised data which is worthless compared to the test data in my mind on the net. Drdave do you have any paperwork on the test data of that cam? Id be interested to see the numbers compared to the sheet I linked up a few post back on this thread. IIRC that cam is basically the same as a delta 260 cam.
I'm thinking of a medium dark red, to match the stripes on the outside of the car. the car has a Grey/Black/red thing going on
I'm going to bright dip all the aluminum parts, and have the black brackets powdercoated. It should look very sharp, especially with my polished plenum
Engine: 6.0L
My bad, it was just the cam that was a lil over $100. Sorry it's been a while since I did mine (almost a decade). You can get the cam for under $120 from autozone. I dont have anything, but if you do a search on "MTC-5", there was a lot of posts regarding this cam back in 2003-2005 or so. A lot of us were looking into it/buying it (Doward, Dale, KED, Trek, myself, etc)
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you will need to keep the 2.8 timing cover, as a 3.4 doesn't have the timing marks (ecm keep timing)
Good info, thanks! I have a whole extra 2.8 engine, so the new one I put together will be made of parts from several places
Engine: 5.7 / 7.4
http://www.cardomain.com/ride/325040...ntiac-firebird found my old cardomain site w/lots of multiple swap pics.
Street Lethal
Apr 30, 2019 12:14 PM
