Turbo Install
Re: Turbo Install
sound sliek u have a coupler partailly blown off, check them all out,
do the boost level drop more each run ?
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Turbo Install
Heres the 14.85 run all the others were 15.01-15.25...LOL
Car: 1991 Camaro RS
Re: Turbo Install
I checked all the couplers many times over, soon as I got in the car today the boost suxed. I knew that was gonna be a problem.
I even took the controler wire off, and the reference vac line and still couldnt push above 7psi for the most part
Re: Turbo Install
check the turbpo for excessive play or anything out of the ordinary, take the wastegate off and inspect it
it has to be something stupid
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Turbo Install
Originally Posted by fasteddi
Cars a POS!! Pisses me off, why is my turbo lag so so bad now? And actually on 2 runs tonight I could only manage 7-9psi. I checked all the couplers many times over, soon as I got in the car today the boost suxed. I knew that was gonna be a problem. I even took the controler wire off, and the reference vac line and still couldnt push above 7psi for the most part...
Car: 1991 Camaro RS
Re: Turbo Install
Ok checked the turbo, there is not much of any end play.
I took the wastegate off and took it apart again. But first I did notice that there was some black marks as if the gate was not sealed up well on the flang. Would that cause such a loss in boost? I can work on the car anymore tonight but this may be the problem??
Car: 1991 Camaro RS
Car: 1991 Camaro RS
Re: Turbo Install
You guys remember when I was saying a long while ago I could smell the wastegate open because it would flow into the hvac stuff... tonight now that I think of it, I could smell it as if the wastegate was open but yet this was when the car was barly under boost. So I guess that a ex leak is basically a boost leak. Thats the one thing I didnt check at the track, was for exhasut leaks.
I let you guys know if this was the problem. It probly was since I took off the wastegate a few time and that gasket probly just got brittle and blew. As it was rough looking. Black marks on both the long sides of the flange.
Car: 1991 Camaro RS
Re: Turbo Install
Yup thanks for the heads up dave and rob. Dammm car better be right by saturday. For the points race.
Car: 1991 Camaro RS
Re: Turbo Install
I Think i was just dealing with a few problems that I basically caused.
First I put the WG back on and sealed it up super tight!
Then I wanted to boost check it again on the charge pipe. Wow man was there leaks, basically where I was messing with the couplers, I think I made them worse last night at the race track. But I did find one leak that wasnt there the last time I boost checked it, as it was on a welded 90* bend basicaly right off the turbo before the IC.
So I took the car out attempting to seal up the little hole but failed as you can see in the log it took forever to make boost, but it did make command 12.5psi just took longer then usual. Normally by 40mph I will have 11.5psi by the top of 1st gear(39mph) And in this log I had about 8.5 psi.
So I will remove the pipe fix it right then try it again hopefully tommorow if I get time.
Re: Turbo Install
told u u more then likley had a coupler partially blown off.
when u presur etest the pipes test them at like 30-40 psi and spray windex or some dish soap and water mix on them just be sure at no time do u let either endcap of the presure tester point at any part of ur body, one of those with 30-40 psi behind it can be deadly
hell they can injure u pretty badly at 10-15psi depending on the volume of the pipe
Car: 1991 Camaro RS
Re: Turbo Install
Well man I must still have a leak..its ticking me off. I went out and drove it and its still not right, so much to the fact that I blew the coupler off at the trubo at WOT and 12.5psi of boost. So loud I though I just killed the car. I didnt over rev the turbo as I let off and eased my way home.
My duty cycle on the datalogg says 99.61% for a good part of the log. So theres still a huge leak somewhere that is pissing me off. IDK I dont want to keep over reving the turbo if I have a leak so I hope I get time tommorow to work on it or im not hitting the track on saturday...sad face here.
Re: Turbo Install
what kind of clamps are u using?
standard hose clamps?
or tbolt clamps
or tbolt clamps
Car: 1991 Camaro RS
Re: Turbo Install
Some are t bands some arent. I re boost checked the charge piping and found yet another 2 pin holes. Man they look like there somewhat fresh as the black paint was not on the piping where the hole was at.
One important question though. There is a slight black residue in the turbo outlet. Its not much of anything but there was enough that if you put your finger in there you would get some black out, BUT my charge piping does NOT have this black residue in it or does my throttle body. So is that normal from not always running a filter...exc?? Or oil seal blow by?
Re: Turbo Install
u will get a tiny bit of dirt and oil residue in there, its not a big deal.
its only a big deal when the oils is like dripping in there
Car: 1991 Camaro RS
Re: Turbo Install
na its not dripping in there. The more im looking through the recent datalogs, it seems like ever since I hit that 15psi of "accident" my spool up times are slower. Im just guessing that that amount of psi just blew some holes in my poor welding and showed its flaws, since I added so many coats of paint to the piping in hopes that it would hold tiny any pin hole leaks I may have. I know thats not the right way of doing it but i though it would be a good idea at the time but now I find myself fixing one leak after another.
Re: Turbo Install
i try not to weld any of the charge pipes unless i can tig weld them
might be worth it for u to buy a 2.5 inch piping kit off ebay
Car: 1991 Camaro RS
Re: Turbo Install
AFPR arrived. Hope to install that If I fix all the dammmm air leaks.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Turbo Install
hit walmart n get a $9 thingy of fiberglass resin, $5 for a big section of fiberglass matte and cut strips to re-enforce and build up your connections, then some 99cent paint
Re: Turbo Install
na its not dripping in there. The more im looking through the recent datalogs, it seems like ever since I hit that 15psi of "accident" my spool up times are slower...
Car: 1991 Camaro RS
Re: Turbo Install
I think I got it now. I went out and tested everything again 2 times over, let the car cool and went for a WOT pull to 110mph. I used a older bin file with 12psi command and a weak WG duty cycle. If you guys wana check it out and see what you think? My intake temp was 90* off the bat as I had to drive 3 miles to get to my 1/4 mile road. And they got all the way up to 160 degrees at the end(110mph). I didnt realize how fast I was going.
Car has less lag but still is about 1psi lower then it usually was at the top of 1st gear at the race track with open exhaust/slicks, but when I compare it to older log files before I had the exhaust cut out(since its not open header on my log today) and such you can see that the boost at the top of 1st gear is about the same....9 psi or so.
1st log is from today. gtech said 106mph@14.27 seconds, and the second log is just a older crappier one.
Re: Turbo Install
Your confusing the heck out of everyone, leak, no leak, leak, no leak...
Said it before pages ago, and I'll say it again, you got a 12 second car. You out did Dave.
Car: 1991 Camaro RS
Re: Turbo Install
Im sorry for the leak, no leak thing. I just welded the crap out of the joints again and let her rip. It works right now...I think, felt fast again. So i must of fixed it.
Ill go to the track tommorow and see if its back to the 14.00 area(im just going to run 12psi tommorow, if it makes those 14 sec passes normal again, ill go and install the AFPR I got today in the mail so that I can turn the boost up a tad (15psi) and then look for some fast track times.
I know some people probly think I write to much on here but it helps to think outloud sometimes.... still a newbe
Re: Turbo Install
Ill go to the track tommorow and see if its back to the 14.00 area...
Car: 1991 Camaro RS
Re: Turbo Install
Box them?? How do ya do that?
Car: 1991 Camaro RS
Re: Turbo Install
Ahh so you just literly weld in a bottom on them? I can do that, looks pretty simple.
Re: Turbo Install
Ahh so you just literly weld in a bottom on them? I can do that, looks pretty simple...
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Turbo Install
I think ya could use the standard 3:42s that came in the V6 cars.
That or I got one super fast V6, as your vid runs, I could hang easy up to 50-60 not going much over 4000rpm
faster I don't know as I don't have room on my daily runs but I get up to 50 plus like that without trying very hard.
now after that, you burry the needle awful quick
Re: Turbo Install
lol hes got a ways to go to outdo me
sounds likes it all fixed now get out there and give it hell i want to see 5 psi launches
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Turbo Install
Re: Turbo Install
umm until he does it on track it dont count
Re: Turbo Install
umm until he does it on track it dont count...
Car: 1991 Camaro RS
Re: Turbo Install
Give me a few weeks with the AFPR and Ill be flying in the car. If I just had more $$ for suspention and rear end items I would be moving alot faster at the track. But for now im relying on boost to get me some decent times.
Took it for a late night ride...its definitly fixed. 0-100 in the high 13's with alot of wheel spin, you can see in the log I had to let off the throttle basically to 50%TPS a few times..
Im off to the track tommorow so I will update ya on times. Hoping I can launch and make the first 13 sec pass, i really dont even care if its a 13.99.
Re: Turbo Install
Took it for a late night ride...its definitly fixed. 0-100 in the high 13's with alot of wheel spin, you can see in the log I had to let off the throttle basically all the way a few times..
Car: 1991 Camaro RS
Re: Turbo Install
Well Rob Im ahead of myself again, I just get a little excited with this little V6.Ill go get a 13.xx first then well go from there and see what shes made of.
I just know the power I felt the other day at 15+psi was amazing!! Absolutly amazing and what really shocked me is the car acted like it really liked the boost.....
Re: Turbo Install
Re: Turbo Install
he is going to go over 15 psi though, so why bother running a version of code that he will just have to update form anyway
Car: 1991 Camaro RS
Re: Turbo Install
Go back to the first few pages of this thread, do you now see why I was encouraging you to run the $58 mask as opposed to the $59 mask w/its' less resolution? I encouraged the $58 mask because 15-psi is a lot of boost to be dealing with, and I can't see you wanting to push 20-psi and expect it to live. My Grand National buddies are running 30-psi, and I literally cringe when I am in the car with them because I am honestly waiting for the flywheel to come shooting through the floorpan, even with them running a blanket...
Honestly I like the $59 BUT I dont like the resolution as you told me along time ago. I should have listen to you because the VE table mainly is just too small for what I need to tune with. It makes it a little difficult at times. The main reason I just went $59 is because I already had the map 3 bar. AND I really had no idea what you ment by resolution a few months ago, dont forget I was a newbe at tuning. Thats a dumb excuse but its sorta in the past now. Im use to $59 so it will work for what I need out of the car for now. And I can see myself going a tad over 15psi in the future.
I dont know how anyone can run 30psi, thats ALOT. At the 15-16psi I went the other day I was praying the car wasent going to go BOOM even though all the data I was reading was ok, except the Injec. DC.
Re: Turbo Install
he is going to go over 15 psi though, so why bother running a version of code that he will just have to update form anyway...
Car: 1991 Camaro RS
Re: Turbo Install
He is going to go over 15-psi? Are you going to pay his bill when he grenades the stock cast parts? As for $58 not handling over 20-psi of boost, umm, yeah, tell that to the Syclone/Typhoon guys who are running upwards of 30-psi. If he has enough injector, then $58 will cover as much boost as he can throw at it. $58 is speed density, and the lookup tables are commanded to fuel as much as we tell it to at wide open throttle...
Hopefully I dont need 16psi or so to reach mid 13's if I can just launch the car somewhat ok. Then when more $$ is avalible, I can set the car up right with t-headers, rear end, exc...
Re: Turbo Install
I can't see myself running over 16-17psi at the absolute max on a stock bottom end. Thats just too much...
Car: check
Engine: check
Transmission: check
Re: Turbo Install
Yea no kidding.
The 3-bar sensor is only spec'd down to 40 KPa, and even at that the error band opens up starting at 71 KPa (and down). So drive-ability suffers.
Just putting a 2-bar MAP sensor on a N/A car for some testing the engine didn't run as smooth. It was a slight change, but non-the-less it was noticeable.
You can still go with a 2-bar MAP along with the $58 code. Easy enough to copy the main tables over.
> I don't know how anyone can run 30psi, that's ALOT.
Missed a word
, let me correct that for you:I don't know how anyone can run 30psi, that's ALOT OF FUN!
RBob.
Re: Turbo Install
what size is the ve table in 58$ and 59$??
with ms u can have 12x12 or 16x16 or 32x32 im currently using 16x16 on my iroc but ill be opening my tables upto 32x32 here shortly when i get my 4 bar map sensor
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Turbo Install
guy had an awesome website with great write ups as it was all sort of a backyard build but with sound science. [using a shop vac to test muffler flow dynamics n stuff.]
can't find the website but here is a old uboob vid.
http://www.youtube.com/watch_popup?v=F3Gdm_e_hxs
Car: '83 z/28
Axle/Gears: Stock?
Re: Turbo Install
fasteddi - How old are you? Haha sorry this is off-topic, But I was just watching American Pickers, and they are picking at a guys place, and his nick name is FastEddi!
On another note. I have been watching this thread for quite a while. I know I got flamed before for talking about exhaust size. I have done many 4cyl boosted cars, but no v6 or v8, and Even on my little 4 banger, I was running 3" all the way. I didn't need to uncork it at the track or change anything from the street to the strip.
I am not here to start a pissing match with any of these guys. But i'm just saying. My turbo spooled almost instantly when I went from stock exhaust to the full 3". Might be something worth considering.
Another thing, I had a 3" on my L98 Trans am, and I could feel a difference when I uncorked it. I would rather have the right size even for when i'm on the street just so I don't have to uncork it.
For anybody else, I don't want to hear it. This is my experience and my opinion.
Car: check
Engine: check
Transmission: check
Re: Turbo Install
RBob.
