Turbo Install
Old Apr 18, 2012 | 02:36 PM
  #1351
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Turbo Install
Originally Posted by 34blazer
well you need to calculate your pressure ratio using variables such as, engine airflow in CFM(CID*est VE), elevation, projected boost pressure, humidity, etc. then you need to calculate the total projected airflow(depending on boost). there should be plenty of documentation on the web, do a google search and you should find exactly what you need.
there may be an output in your datastream that plots the airflow in gms/sec, should help compare your calculations too.
HTH
Ok I'll look at the logs and see what I find.
Old Apr 18, 2012 | 07:17 PM
  #1352
project89's Avatar
Re: Turbo Install
Originally Posted by fasteddi
As I add boost the cfm or lbs/min goes up doesnt it because of the added hp?
yeah i suspect 4 more psi will put u up around 300hp or about 30#'s of air per min
every pound of boost will be around 9-13 hp per pound of boost
at 250 hp u are making 110 more hp then stock and well with 10 psi that is roughly 10hp per pound of boost
be aware thoughas the gains from boost are not linear u might gain more hp going from 14-15 psi then u do from going from 7-10 psi
Old Apr 18, 2012 | 07:22 PM
  #1353
project89's Avatar
Re: Turbo Install
btw post some datalogs from ur track passes
Old Apr 18, 2012 | 07:26 PM
  #1354
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
Heres the map I was using as a reference its a 57 trim to4e. Isnt that the comp I have?? If this is correct then 26-28 #/min and 1.68 press ratio does toss me out of eff a little at WOT 5k+rpms. Thats the psi im running now. Its arround 70% But is there a better more accurate way to find the pressure ratio then just 14.7+my current psi/14.7? Or is that the way to do it?
Old Apr 18, 2012 | 07:31 PM
  #1355
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
The one I took isnt good. Still dealing with KR but I had pure Vp 100 in the tank also just to make sure it wouldnt get hurt. I can not figure out how to get rid of the kr and its really inoying!!
File Type: zip
Old Apr 18, 2012 | 07:39 PM
  #1356
project89's Avatar
Re: Turbo Install
the turbo u have has dosent match any garret maps, but the gt3076 is the closest, so use the map i posted
14.7psi = a pr of 2.0
21psi is roughly 2.5 pr
etc etc
the knock is prolly somethign rattling around im going to take a look at the log here in a few mins
Old Apr 18, 2012 | 07:41 PM
  #1357
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
Re: Turbo Install
back in 2006 i calc'd my pressure ratio at 2.2 with my 3.4
Old Apr 18, 2012 | 08:16 PM
  #1358
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
@dave ill use that map, the log has KR scattered in it. Its not a lot but its there. I just cant figure out whats rattleing
The more I look at that map, the more sence it makes on why it was very slow at say 6-8psi compared to the 10.5 or so im running now. I remember it was really a let down the first times I ran it with boost and the tune was good. But as soon as I got the controler and set it up to 11psi it was a new feeling.
If I get to take it to the track on saturday its suppose to be 50degrees out, thats 35degrees less then last week so Ill have nice low intake temps. I really just want to make a 13sec pass have less of that innoying KR. And im still looking into getting some alky in the near future.
@34blazer
Old Apr 18, 2012 | 10:23 PM
  #1359
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Turbo Install
when i calc'd 2.2 pr for the 3.4 it was with 20psi boost. your turbo is barely working and begging for more lol
Old Apr 19, 2012 | 01:21 PM
  #1360
project89's Avatar
Re: Turbo Install
thats deffinatly false kr, the only issue i see so far is ur getting close to being out of injector so only raise boost 1 psi at a time and keep an eye on afrs, u may have enough injector left to get 4 more psi of boost out of them, all depends if u want to push them past 80% duty cycle, i personally will run an injector upto 95% if im not turning the motor more then 6,500 rpms
Old Apr 19, 2012 | 02:15 PM
  #1361
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
How the $%^& am i suppose to get rid the the False KR..lol??
Im tuneing right now and im up to 13psi with safe 11.7-12 afr and 86 max injector cycle but averaging 75 WOT DC %. Its running fine but I find my self looking at the plugs every tune as the KR is there, its about 1-4 degrees here and there. Its takeing the power away from me and I spent another hour trying to find anything loose? Could a ex. leak cause it??? There a slight one at the bottom of my downpipe, its barly noticable though.
This is driving me crazy its hard to adjust timing because if I raise it or lower it, the KR is still there. Im at 19.5 * of timing at this boost level...to much??
Old Apr 19, 2012 | 02:21 PM
  #1362
project89's Avatar
Re: Turbo Install
this is why i dont like knock sensors, make sure the connector on the knock sensor is also on tight and not loose.
are u sure the downpipe or the under k member pipe isnt touching when there is loa don the motor.
also make sure the trans mount isnt torn or worn out as the trans mouncing around can cause false knock.
a loose heat shield can cause false knock, same with suspension compnents
hows it running at 13 psi ? any new videos
Old Apr 19, 2012 | 02:24 PM
  #1363
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
Its running good, just worries me about the KR an its taking my timing away so its rich sometimes from the timing it takes away. And I just dont want some real KR to be mixed in with that false stuff. Although there is still about 3 gallons of Vp100 in the tank with 3 gal of 93 octane. So the gas is good in there.
I look back under the car where the down pipe and y pipe cross.
Ill get some videos and slips on saturday. Forcast is looking good. 50 and sunny. Im ready for a 13sec pass. I was just trying to dial in a 13psi chip if I get the chance to run it like that.
Old Apr 19, 2012 | 03:04 PM
  #1364
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Turbo Install
if you cant find anything loose, it may be a overtightened KS, causing it to be super sensitive. maybe try a OEM KS properly torqued unless you have replaced already? none of that autozone/advance garbage either. also keep in mind that race fuel will eventually contaminate O2 sensors due to lead in the fuel.
Old Apr 19, 2012 | 03:24 PM
  #1365
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
The gas is unleaded... just 100 octane.
You guys are really going to laugh but I think the false KR for the most part is gone now. I found a 9/16th socket laying right down by the radiator on the body that has the lip on it.
I went out and gave the car a good test and the only KR was when it shifted into 2 and 3rd but it went away fast and was very very little. A bit more (1-2*)when I was at about 90mph but I know that was real as the intake temps were getting up there. Its weird how hot out it is today..
0-60mph in 5.53 sec
0-95 in 12.51 sec
0-100 in 13.97 sec.
This was at 12.55psi
Ill have to dig up some stuff but I think thats faster then before.
Old Apr 19, 2012 | 03:39 PM
  #1366
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
Dug out some print outs and did the math comparing to my 14.37 run at the track the other day.
All the times (with the latest tune) were faster and in the long haul 0-100mph was .70 seconds faster. So I guess it did pick up speed. Its sad that my 0-60mph time was about .40 seconds faster on the street then on the track...Thats what a burn out will do I guess.
Old Apr 19, 2012 | 05:57 PM
  #1367
project89's Avatar
Re: Turbo Install
u need to get ur boost control fixed, u only build 10 psi in 1st gear then loose boost higher up in the rpms.
have u tried hooking the wastegate to manifold only yet and seeing if it does the same thing.
the boost drop off and slow boost building is costing u time at the track
Old Apr 19, 2012 | 06:00 PM
  #1368
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
I tried running the line up to the manifold before and still the boost was the same. It seems to always loose after I shift??
Old Apr 19, 2012 | 06:04 PM
  #1369
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
Look at this log dave. I seems to hold the boost but it just takes a little while to build. Bad intake temps again. I need to get that under control. Thankfully itll be about 35 degrees cooler on saturday Command boost was 12.55
I guess as looking at this latest log, I could just crank up the WG DC% a little at a time at the low MPH
File Type: zip
Old Apr 19, 2012 | 06:06 PM
  #1370
project89's Avatar
Re: Turbo Install
wastegate not closing fast enough will make that happen .when the rpms drop the wastegate valve shoudl close slightly since there is less volume of gas, as rpms climb there is more volume that needs to be bypassed so the valve opens further
and or ur bov could be leaking
for now pull the wastegate and put some graphite lube on the valve stem of the wastegate then use ur hands and move the valve up and down and make sure it isnt sticking
the only other way u will experiance ur symptoms is if the turbine housing or turbine wheel is to large, but i know this isnt the case since i run a much larger turbo with a bigger turbine housing and wheel then u are .84 t3 housing with a stage 5 wheel
urs is only a t3 .63 with a stage 3 wheel
Old Apr 19, 2012 | 09:13 PM
  #1371
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
I dont know why its still doing it. I took a video, its long, and you can hear it die off when I shift, im not sure why that is. The rlf BOV is on the car, I took off the wastegate and its lubed up and good to go. The only other thing I can think of is my WG duty cycle is just too low, as im not really spiking any higher then the commanded boost it.
But it from what I remember it always lost boost a little between gears but now with 12-12.5 psi a 2-3psi drop is a big difference, but like I said it only happens sometimes where I notice it??
The cars still runs great and no KR is really present except for a dash which youll see in the video. It seems as if it does it sometimes and other times it doesnt??
Ill link the video when its donw uploading as its like 4-5 minuets of riding in the car with my crappy comintary...LOL
edit: heres the vid. http://www.youtube.com/watch?v=OAsxq...ature=youtu.be
Old Apr 19, 2012 | 09:46 PM
  #1372
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
Re: Turbo Install
is there some sort of torque managment built into the binary to pull boost after a shift?
*edit* come to think of it, that may be saving your tranny right now. but id still be looking for that
Old Apr 19, 2012 | 09:53 PM
  #1373
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
Ok blazer Ill look at it. It probly is a nice thing as its taking it easy on my tranny durring the shifts now that you said something. The cars still fast as crap, but I just like to know why the car is doing it.
Ill read up and see what I find.
Old Apr 20, 2012 | 07:35 AM
  #1374
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
I couldnt fine anything about torque managment in the $59.
Could this just be from me getting into the boost threshold?? As it has always done this since day one of the turbo, I just notice it more now since the boost is higher.
I need turbo headers dave!!
Tommorow Im off to the track so well see if I can squeeze off a 13 sec pass on the 12.5psi command.
Old Apr 20, 2012 | 07:37 AM
  #1375
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Turbo Install
There is only a 4th gear switch in the trans and a P/N switch on the shifter. So the ECM knows whether the shift selector is in park or neutral versus in-gear.
And with the 4th gear switch only knows if it is in 1, 2, or 3 versus 4th.
There is torque limiting code in $58. Although it appears to be more for foot braking and controlling boost. I don't know if any of that was changed with $59.
With enough knock retard the boost is lowered. The WG duty cycle is in the data stream, that would show what the ECM is doing for boost.
RBob.
Old Apr 20, 2012 | 02:39 PM
  #1376
project89's Avatar
Re: Turbo Install
how soon do u want a set of real turbo headers?, i could prolly start on a set on may 1st
Old Apr 20, 2012 | 05:27 PM
  #1377
project89's Avatar
Re: Turbo Install
my cars on the stands getting ready for the v8 to v6 swap
lmao just kidding got a really bad vibration at around 60mph i need to figure out, but if this thing does keep ending up on jackstands more then i drive it the v8 will come out for a v6 lmao
fast keep ur car away from jackstands once they get on them its a never ending thing lol
Old Apr 20, 2012 | 05:48 PM
  #1378
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
That suxs man, I hope you find the vibration.
I know all about the jackstands... the fuel pump problems one week, then addign a tq converter, then replacing that converter....LOL. I think it hasnt seen jack stands in about a week. Im on a roll so tommorow at the track I better do good!
Im aiming at those 13'sec passes tommorow, the consistancy thing can come on later down the road.
Let me know when your going to get into the turbo header thing. Id build my own but quite honestly I know it would take me forever to get it right. That is just past my skills on fabrication.
Old Apr 21, 2012 | 03:35 PM
  #1379
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
14.03@98.04Mph was the best for today. The track was so cold, as it was barly 40 degrees out wiith a 10mph head wind. So it was almost impossible to launch hard without loosing traction, unless I let more air out of the tires and then I wobble at the high end of the track(thats too scary to do). So im happy for the day.
Heres a video of a pass:
http://www.youtube.com/watch?v=ZwJOR...ature=youtu.be
Here is the best run 14.03:
Heres the best reaction time, and the slowest run when I was on it the whole way of the track..can you tell I spun on this pass?
Old Apr 21, 2012 | 04:34 PM
  #1380
project89's Avatar
Re: Turbo Install
man that thing has enough mph to go 13.3 ish, 12's are in ur future once u get that thing dialed in and are able to launch it properly
Old Apr 21, 2012 | 04:42 PM
  #1381
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
The track was just too cold to launch. I really tried but the only time I could launch there was 11psi of air in the tires and that thing wobbled like crazy down the track when over 70mph, it was a little scary so I would let off, I made that fastest pass with just holding the RPM's @ 2k...no boost. So I basically found a happy medium with the tire pressure (13.5psi) and ran 14.03- up to 14.22 times at the worst, the launch was not what I wanted but at least im getting a rythem on the slicks, as Its been years since I ever took a car down the track with slicks.
Old Apr 21, 2012 | 04:48 PM
  #1382
project89's Avatar
Re: Turbo Install
the wobble is normal, but i dont belive the dot drag radials should wobble as much as a full blown slick. usually ill run about 12 psi in my tires so u should be pretty close on air pressure at 13.5
id ivest in some ce or summit brand 3 way adjustable drag shocks next summit brand is like 25 bucks each shock and ce's are about 34bucks each iirc
Old Apr 21, 2012 | 05:11 PM
  #1383
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
I completly forgot about wobble, its weird as im use to street tires. Im more comfotable now, but I know the track was not hot enough at ALL. So I should be able to run 13-14psi and still hook if the track is warmer. It was less then 40 degrees all day and I measured the track temp at 55 degrees..lol
Old Apr 21, 2012 | 05:15 PM
  #1384
project89's Avatar
Re: Turbo Install
my first set of slicks i mounted with tubes, u know what was worse then the wobble??
the bounce i hated the bounciness more then anything
now i wont mount any slicks with tubes
Old Apr 21, 2012 | 05:53 PM
  #1385
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
Yea Im not running tubes either.
Heres the log from the 14.03 sec pass. Boost held good throughout the run. As you can see I jacked the boost a little, figured that would off set the larger tires. I take it that the larger tires make the spedometer off, as in lower? I finished alot higher then 95-96mph.
I think that is about as far as I can take those injectors. I need a adj.fuel press reg. or larger ones if I plan to run more boost thats forsure!
File Type: zip
Old Apr 21, 2012 | 05:55 PM
  #1386
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Turbo Install
Try getting that wobble at 120+ MPH...
A friend of mine that has a car that runs 8s says that he had the worst shake when using the Drag Radials at high MPH, he said he just had to drive through it.
Old Apr 21, 2012 | 06:53 PM
  #1387
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
Yea 100Mph for me is floating enough but I sorta got use to it after about 3 runs.
I couldn't imagin 120Mph+ and having the rear end wana float(wobble)
Old Apr 22, 2012 | 07:17 AM
  #1388
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
Ok I really want posi in the rear... would this work for my application??
http://www.ebay.com/itm/Auburn-Posi-...69385d&vxp=mtr
Im on a budget but this is in my range forsure! So ill keep looking arround for something that I can afford. Those new ones are 400-500 bucks plus
And I know a good amount of racers, so would I need help to install it or is it something I could do on my own.
Thanks for any help!!
Old Apr 22, 2012 | 12:31 PM
  #1389
project89's Avatar
Re: Turbo Install
auburn = fail
used auburn = double fail
how many amps is ur welder ? u could do what i did and weld the rear, or buy a mini spool
Old Apr 22, 2012 | 12:38 PM
  #1390
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
auburn = fail
LOL im not welding the gears.. I use to do that on demo cars
I though mini or full spools will tear up the axles on the highway?
Old Apr 22, 2012 | 12:42 PM
  #1391
project89's Avatar
Re: Turbo Install
mini spool or welding the axles may cause u to bend an axle over time, i had a welded rear for 3 years before i bent an axle and mine was a daily driver
Old Apr 22, 2012 | 12:45 PM
  #1392
project89's Avatar
Re: Turbo Install
u will need a 28 spline mini spool, just looked on ebay and for some reason they are 30-40 bucks more then a 26 spline unit
http://www.ebay.com/itm/7-5-GM-7-625...item3374ee346f
summit racing may actually have them cheaper
Old Apr 22, 2012 | 12:47 PM
  #1393
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
Few questions
1. how hard is it to install
2. will the tires sqeel arround turns and such??
3. Is it noticibly different driving arround town? In a bad way?
  #1394
project89's Avatar
Re: Turbo Install
http://www.summitracing.com/parts/MGR-MS75-28/
id get the summit unit its brand name unit and the ebay unit apears to be a knockoff so im sure its made oout of crap metal
Old Apr 22, 2012 | 12:52 PM
  #1395
project89's Avatar
Re: Turbo Install
Few questions
#1 remove the rear cover, remove tires and brakes ,,remove crosspin in the rear, pull out c-clips and slide axles out of about 6 inches, pull out spinder gears , replace spider gears with mini spool side gears, line up slots in side geras and inset the inserts then bolt crossbar back in .
slide acles back in and reinstall c-clips ,brakes ,wheels, install rear cover and fill with fluid and ur done
#2 low speed driving like parking lots and making right or left turns froma stop sign will make the tires chrip a lil and or the back of the car to hop slightly , at higher speeds u wont even notice its there unless its raining out or snowing
#3 u get used to it, it does cut down ur turning radius a bit when ur at low speeds and it makes it easy to get the car sideways when its wet out or snowing
mini spoo is the same thing as wleding the spider gears in an open diff
Old Apr 22, 2012 | 01:05 PM
  #1396
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: Turbo Install
get one of these! http://www.ebay.com/itm/New-GM-10-Bo...27ba74&vxp=mtr
that's what i'm running. I like it.
Old Apr 22, 2012 | 01:11 PM
  #1397
project89's Avatar
Re: Turbo Install
he will break it eventually,i have about 50 of those back home in nj from pullouts we did in the 4thgens, most of them are locked up or broken in some way or another.
thats why i never installed on in my car turbo v6 makes way to much tq
Old Apr 22, 2012 | 02:55 PM
  #1398
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
I think im going to have to entertain the idea for a bit. This is still a street car to me and I really think a LSD would be more usable, even though I cant even get close to affording one at the time.
Old Apr 22, 2012 | 02:58 PM
  #1399
project89's Avatar
Re: Turbo Install
get a mini spool for now, u can resell it down the road for about the same thing u bought it for. also u can swap the minispool in and out in about 30 minutes once u get the hang of it.
so u could install it the day before the track or even at the track , and then put the stock spider gears back in once u are done racing.
lsd/posi upgrades for the 7.5 rear are a waste of money, the only good posi unit is the eaton unit and that is 400$ i would not spend 400 bucks on a 7.5 inch rear
aubruns are much cheaper but they are junk stock l98 cars burn them up in no time and are not rebuildable the eaton is atleast rebuildable but it still comes down to being a 7.5 inch rear that u may or may not break
the only thing swaping back and forth from the mini spool to the stock spider gears will cost u is tubes of black rtv for taking the cover on and off
best advice here is to do it as cheap as possible , thats why i welded my gears if i broke the rear i could get new gears for 125$'s or of it trashed the rear completly i could get a whole new rear from the bone yard for 100-150 bucks
Old Apr 22, 2012 | 08:21 PM
  #1400
fasteddi's Avatar
Car: 1991 Camaro RS
Re: Turbo Install
Man, I wish I had more $$$
Hey dave I was also doing some research on AFPR so that I can retain my injectors and add some boost. Any thoughts on which ones are good?? There is so many out there, I really wish I could just mod my stock one.
You think that my thread was ok?? I was thinking mabey that it could be a sticky or something in the future. IDK if the information I said even made sence but it was worth a try.
