fuel line replacement
Old Mar 2, 2012 | 02:02 PM
hokiefanatic93's Avatar
Car: 1987 Camaro
Engine: V6
my car randomly started lacking a ton of power then got to a point where it wouldn't start. i found a fuel leak in the hose as pictured below. i have check online for these hoses and can't find them. my question is are these hoses just a rubber tube and you attach the metal connectors to the ends or where would you buy these?
Old Mar 2, 2012 | 02:12 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: fuel line replacement
May be able to find some in the JY. Be sure to get them from a '90-'92 car as the earlier years had a recall due to leaking at the crimp.
The other thing to do is to use AN line & fittings.
I mention the above as I don't know if they are available new elsewhere.
RBob.
Old Mar 2, 2012 | 02:14 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I replaced mine a few years back and just got them at the local GM dealer. They already had the ends attatched, so all you had to do is take the old off(carfull of the connectors) and put the new on.
Old Mar 2, 2012 | 02:19 PM
Car: 1987 Camaro
Engine: V6
RBob.
ok, i can get one from a parts Camaro my friend has, but that Camaro is a 86 and who knows the condition of the hose in that car. a new one would be preferred so i know it will last a long time. i may just take my friends until i can get another.
Old Mar 2, 2012 | 02:23 PM
Car: 1987 Camaro
Engine: V6
i'll give my GM dealer a visit. thanks.
Old Mar 2, 2012 | 03:27 PM
Car: 1987 Camaro
Engine: V6
My GM has discontinued the hose i need. so i need to find one at a junk yard. i'll probably take the one from my friends 86 Camaro till i can get a hose from a 90's thirdgen.
Old Mar 2, 2012 | 03:38 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Look at thirdgenranch. or if you ever get on facebook, look for virtualjunkyard. Its in Indiana and they have tons and tons of thirdgen stuff.
Old Mar 2, 2012 | 04:22 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
in a pinch you can cut the crimp off with a cutoff wheel, remove the old hose and use new hose rated for fuel injection pressure.. just make sure to use the correct fuel injection type clamps and it'll be fine.
Old Mar 3, 2012 | 09:38 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Just a heads up, there is an o-ring at each connection. Be careful to not double them up or lose them.
RBob.
Old Mar 3, 2012 | 09:51 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I have a spare set off of a '92 3.1 Camaro if you need them....
Old Mar 3, 2012 | 01:52 PM
Car: 1987 Camaro
Engine: V6
i'm going to use my friends for now. But if if i decide to get a newer hose that isn't under a recall to be safer, i will message you in April because i'm heading down to VA and drive through NJ. thanks
Old Mar 5, 2012 | 07:41 AM
i'm going to use my friends for now. But if if i decide to get a newer hose that isn't under a recall to be safer, i will message you in April because i'm heading down to VA and drive through NJ. thanks...
No problem, just let me know a few days in advance if you need them...
Old Mar 7, 2012 | 03:20 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
Can't you just buy the fuel line replacement kits they sell and rig up some lines yourself?
Old Mar 11, 2012 | 04:23 PM
Joecat's Avatar
Engine: 2.8L V6
Transmission: 7004r
I replaced my lines and just used a few feet of 3/8' fuel injection hose and the appropriate fittings. literally ANY auto parts store will have what you need.
mind you youre seems to have some sort of factory stock connectors, if you can remove them all together you can just slide on new hoses
Old Aug 9, 2012 | 08:26 AM
13reedtd's Avatar
i got a question about the fuel lines them self's. ive been restoring a 1982 Camaro it dint have a motor in it so i bought a parts car with good v6 2.8l motor but don't know witch gas line is the vacuum and witch one is for the fuel ......Please help
Old Aug 9, 2012 | 11:56 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I'm not sure which is which. However, if they are different sizes the fuel feed line is usually larger then the others.
RBob.
Old Aug 20, 2012 | 03:18 PM
13reedtd's Avatar
how do i test my fuel pump ????
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
