Door alignment
Old Mar 30, 2012 | 08:23 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
Door alignment
The body line going from the fender to the driver side door doesn't align. The door is like a 1/2" dropped from the body line on the bottom of the fender. It seems as though the back of the door is almost aligned with the rear panel in front of the rear wheel as if the body line on the door is going diagonal. What generally causes this?
Old Mar 30, 2012 | 08:30 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Door alignment
You'll have more luck asking in the Body section of TGO rather than in the V6 Engine section.
Old Mar 30, 2012 | 08:34 PM
Axle/Gears: 10 Bolt
Re: Door alignment
Lol..forgot I was in the V6 section sorry! should add a move button.
Old Mar 31, 2012 | 06:21 AM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Re: Door alignment
Your door is probably sagging
Check the bushing on the roller detent by the hinges, usually that is all you need to replace if your door still opens and closes easily
Old Mar 31, 2012 | 04:51 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: Door alignment
Either that or you have a non-GM front fender (aftermarket fenders could have wrong body lines).
Old Mar 31, 2012 | 05:09 PM
Axle/Gears: 10 Bolt
Re: Door alignment
Upon closer inspection the rear of the front fender seems to have been jacked up improperly and it caused the fender to push up and out...How can I fix this?
The shop the previous owner took the car too must of did this...
Old Mar 31, 2012 | 06:04 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Door alignment
your saying someone used a pinch weld jack to change a tire and jacked up the fender???
Old Mar 31, 2012 | 06:07 PM
Axle/Gears: 10 Bolt
Re: Door alignment
some type of jack was used. The bottom flange is bent completely up. The fender seems to be bent up and out from its original position. I am comparing it to my passenger side door and fender. I will post a picture.
See the bottom flange is completely bent up...I believe someone used a jack here and bent the fender up and out so now the body line is completely off along with the molding.
Passenger side (kinda hard to see its dark out) see the bolt on the bottom? seems as though no jack was used on it.
Veaceonee
Sep 29, 2016 08:15 PM
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
89 formula TPI
Sep 20, 2015 10:54 AM
Buggy Disaster
Sep 17, 2015 05:12 PM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
