2.8 chip
2.8 chip
hello all I have an 87 Camaro with the 2.8 mpfi. It stops revving at 5k. I want to eliminate the rev limiter so that I can use the full potential of what I built my motor for.
Is there anysort of chip or programmer that I can use to increase my rev limit and possibly add a little more power... Im not so good with the computer side of cars so any information is much appreciated.
Thanks in advance
Thanks in advance
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: 2.8 chip
Thanks in advance
Thanks in advance
You would need to buy a chip burner which is 85 bucks. If your really want just the rev limiter taken off. I have a burner, I could just burn your chip for you so you dont have to pay out for a burner for a one time deal.
and also a chip adapter package. You need this adapter and at least one chip. If you buy them seperate you may save a few bucks.
http://www.moates.net/gp1-package-gm....html?cPath=64
Re: 2.8 chip
so how exactly does the chip burner work and what does the adapter do... if i buy a burner how many times does it usually take to get it right. i want to program it to have more power on top of no rev limit. is this what they call eprom programming
Re: 2.8 chip
the 2.8 does not have a rev limiter @ 5k rpms it dosent even have a speed governer.
it does have a fuel cut but i bellive its at 6,600 rpms are u sure ur tach isnt way off?
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 2.8 chip
You've run into the engine's built-in "wall of power". No computer tune is going to help the restrictive intake and heads. Even if you did port them to the max, I'd be willing to bet my stock small-port 3100 heads (untouched other than new valve seals and decarbonized) still flow better (and give me a redline with decent power at about 6K).
Re: 2.8 chip
something else is wrong then its not a revlimiter check ur ignition timing almost sounds like its either not advancing or its extreamly retarded, both of which will caus ethe engine to not rev up or rev up very slowly
Re: 2.8 chip
i can get damn near 200 cfm out of irons +200 if they go on the cnc Re: 2.8 chip
Re: 2.8 chip
a stock 2.8 will rev past 5k pretty easy, are u sure that u installed the timming chain correctly if the cam is off a few degrees it will also cause these symptoms
check the ignition timing first as that is the easiest thing to check, also make sure the cat is not clogged up
Re: 2.8 chip
Re: 2.8 chip
make sur eits set to 10* witht he est bypass wire unplugged.
if u set the timing with the wire pluged in the timing will be severly retarded and that is ur issue
Transmission: 5-speed/T-5
Re: 2.8 chip
I cleaned up the thread, keep it on topic (technical help) or people will be taking vacations from TGO.
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: 2.8 chip
Where did you spend that cash? I ask because some of your parts might not be playing well together....
KO1
16
Oct 15, 2015 05:00 PM
