seafoam question
Old May 11, 2012 | 03:18 PM
thatoneguy5x's Avatar
Car: camaro
Engine: 3.1
Transmission: auto
seafoam question
is smoke supposed to pour out of the EGR valve? its a 92 camaro so it has an electrical one.
Old May 11, 2012 | 03:42 PM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Re: seafoam question
your gonna see smoke come out of weird places, all that smoke build up and nasty stuff burning out, has to come out somewhere.
Old May 11, 2012 | 03:53 PM
Car: camaro
Engine: 3.1
Transmission: auto
kinda caught me off guard. i knew it was supposed to smoke but the egr valve was pouring it out as i was pouring it in so i cut the engine sadly i didnt commit and only did about 1/5 can in the vacuum and about 1/3 can in the gas tank. i can feel a big difference in the throttle tho, even tho i didnt do a full third. would it hurt the engine if i poured the other part in the vacuum line even after i already did the 1/5 and cleared the smoke?
Old May 11, 2012 | 04:00 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
im not sure, but i would just pour it into the oil to clean up the system real good.
Old May 11, 2012 | 04:03 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I did mine (91 3.1) just putting it in the gas. It took maybe 3 or 4 cans in tankfuls of gas but it was easy and there was no smoke. I could feel a small improvement each time I drove. When I got the car it would hardly pull 3k rpm and now it'll run easily to 5500 with more if I let it. My experience with it has been great.
Old May 11, 2012 | 04:29 PM
project89's Avatar
sound slike ur egr valve is leaking, the only place the smoke should come put of is the tail pipes, anyplace else and u have a leak/bad gasket
Old May 11, 2012 | 06:19 PM
Car: camaro
Engine: 3.1
Transmission: auto
damn noooooo!!!!! and that can't be replaced right? or was that only for the older ones
Old May 11, 2012 | 06:42 PM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
does seafom really work? im afraid it will break up my seals on my engine.... 175k miles so im sure theres carbon in there... any thoughts? thanks
LO3 TBI
Old May 11, 2012 | 07:02 PM
project89's Avatar
depends on were it wa sleaking from, was it leaking from the bottom were the gasket is or out of the egr diapram etc
LO3 TBI
seafoam is one of the few cleaners in a can that actually work,well worth the 7-10bucks a can
Old May 11, 2012 | 07:58 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
If you took care of your car for that 175K you should be able to use seafoam without it damaging your seals. Just follow the instructions, don't put it into an almost empty gas tank either.
Old May 15, 2012 | 04:31 PM
Car: camaro
Engine: 3.1
Transmission: auto
I'm not to sure of where is was comming out from. it was just comming out of the bottom of it, I'm guessing the diaphragm. is wasn't really coming out when I turned the car back on just when I was pouring it in. I was kinda guessing the EGR was going, the service engine light comes on when I go about 85-90 on the freeway but when I slow down again it goes away. haven't tried pulling codes yet
Old May 15, 2012 | 04:50 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
how is your 02 Sensor? still in tact?
Old May 15, 2012 | 09:39 PM
Car: camaro
Engine: 3.1
Transmission: auto
from the looks of it. no real problems. does run a bit rich. ill be replacing plugs, wires, and sensor soon tho. still trying to log my avg MPG. slowly but surely getting it to run better and better
Old May 15, 2012 | 09:49 PM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
If you pour the Seafoam in the Gas tank or in The Oil then you should change the oil right away within 100 miles and burn off the gas tank and pour in new Gasoline
Old May 15, 2012 | 10:55 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I can tell you in the motorcycle world, people use half a can to a full tank of gas [3-4gal] and go out for long hard rides and it fixes so many funky running problems, that its almost like magic how it works so well. Where other snake oil do not.
now when it comes to adding it to the oil, you follow the direction to the letter.
Old May 16, 2012 | 02:36 AM
Car: camaro
Engine: 3.1
Transmission: auto
I only did it in the vacuum line and gas tank. I might be changing lots of parts, mostly filters and sensors
Old May 16, 2012 | 07:47 AM
pvr007's Avatar
Engine: 305 TBI
i think i broke my exhaust manifold
Old May 17, 2012 | 01:17 AM
Car: camaro
Engine: 3.1
Transmission: auto
with seafoam?
Old May 17, 2012 | 04:42 AM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
with seafoam?
Old May 18, 2012 | 02:25 AM
Car: camaro
Engine: 3.1
Transmission: auto
Old May 18, 2012 | 02:27 AM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
i didnt think that was possible but.. anything is possible i guess, i doubt you did though, whats happening or what/
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
