hELP! o2 Location on 2.8
Old May 23, 2012 | 10:58 AM
Coffee_Roaster's Avatar
Car: Dakota 4.7 4x4, Camaro RS puky 2.8
Engine: 4.7,2.8
Transmission: 5speed, auto, auto
I have a 2.8 1988 RS, and I was replacing the o2 sensor. I disconnected what i thought was the connection, but it was dark. I removed the old 02 and screwed in the new one. Now I can't find the location/wire to reconnect, and I'm wondering if the o2 was just taped up in the harness. My check engine lige has been on and the old o2 look all carboned up. I need to know how where to connect the o2 on the 2.8
Help
Old May 23, 2012 | 01:09 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: hELP! o2 Location on 2.8
it comes down the passenger side of the trans tunnel. not exactly sure where since i had to lengthen mine years ago to accomodate headers, but its somewhere up in that area.
Old May 23, 2012 | 09:12 PM
Engine: 4.7,2.8
Thank you, I'll search in the morning
I'll just start reaching around the tunnel and stuff......or, just run rich till I swap.
Old May 24, 2012 | 04:42 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
The connection is beween the starter and the firewall, just look in that area for the clip connection.
Have to made sure it was the o2 sensor causeing the check engine light?? Have you did the paperclip trick to see what code is poping up?
Old May 24, 2012 | 11:49 AM
Engine: 4.7,2.8
HI Eddi, thank you so much for replying. I watched your youtube and I'm super impressed.
My 88rs has just under 70k, and you could say I'm a newbe, but technically competent. So far I do all my own work on my 4.7 dodge, and the RS is just new to me. Pardon my ignorance: " Paper clip" ? I'll do a forum search....or you could just post it back for me
Old May 24, 2012 | 07:03 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Thanks for checking out my videos, that lil camaro I have is a fun car. Took me a lot of time to get it to run good like that.
Theres a better link but I dont know where its at so heres some help. Read up as its easy as cake to do.
http://www.austinthirdgen.org/index.php?pid=27#28LMFI
Old May 26, 2012 | 06:33 PM
Engine: 4.7,2.8
Three short falshes.....is that 21?
TPS voltage was above 2.5 volts for 2 seconds when the MAP sensor signal showed manifold vacuum to be 15 pounds or more under 1800 RPM.,
And ifsi what shall do? Replace the TPS?
Old May 26, 2012 | 08:43 PM
Engine: 4.7,2.8
Re: hELP! o2 Location on 2.8 AND MORE
So I replaced the TPS, no change and still ran rough checked paperclip code and it was a 2 quick flashes, Hmm, and when I do get it running using throttle it ran rough. So I removed the spark plug wires suspect that I missed [laced on when replacing plugs and wires. I removed all of them. So is it correct that I need to remove the plug for cyl#1 find TDC, remove dizzy cover, reference rotor( should I replace it too) set wire 1 and cyl1......does this sound "right"?
Old May 26, 2012 | 09:04 PM
Engine: 4.7,2.8
O.K got the plugs back in order, I used this:
Engine: 4.7,2.8
86maro_252
Oct 10, 2015 06:52 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
tonys91rs
Sep 2, 2015 07:07 PM
