92 3.1 v6 firebird oil pressure guage reading very high.
Old May 26, 2012 | 01:39 PM
honeybadger92's Avatar
Hey yall I'm new to the forums been reading around a lot after purchasing my 92 firebird. Got it for 400 bucks with 140k on it. Needed a starter and oil pressure sending unit.
I replaced the opsu and now my oil pressure gauge is reading extremely high like needle.off the hash marks high. Is this normal??
Old May 26, 2012 | 03:43 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: 92 3.1 v6 firebird oil pressure guage reading very high.
Did you get the right sending unit? There are sending units for gauges and different one's for the so called idiot lights.
Old May 26, 2012 | 04:24 PM
Yes its the right one. Matched it up with the old one ect. Just reads very high. But after I shut the engine down the gauge drops as it should. Just seems weird to me.
Old May 28, 2012 | 01:39 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
It can't be the right oil pressure unit. The gauge is telling you that the wire that's supposed to have a variable resistance on it at the end (inside the sender) is open (GM gauges pretty much ALWAYS read high when disconnected from their source). Oil pressure senders are only open when faulty, but the switches for idiot lights are always open until the oil pressure drops too low, at which point the switch closes to ground (which would drop off the gauge to 0 PSI/KPa). Either it's the wrong OPS or it's bad.
Elephantismo
Feb 13, 2019 12:51 AM
Macchinist
Oct 2, 2015 02:55 PM
the_nikfive
Aug 11, 2015 02:46 AM
XxMoLexX
Jan 9, 2001 06:18 PM
JDMZ28
Dec 14, 2000 08:33 PM
