Throttle body question
Old Oct 28, 2012 | 02:48 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
I bought a throttle body in which the idle screw hasn't been punched out. My tach is reading around 1,000 in drive. I am not sure if the tach is inaccurate but my previous throttle body was at 750 in drive warm.
My question is, does anyone know if all the preset idle screws (not punched) are the same distance on all the 2.8 throttle body's? and do you think I should leave the new throttle body in place with the higher idle (not punched)? (The throttle body I purchased has been cleaned spotless)
I see the idle is set so the throttle body butteryfly is flush with the little slit above it.
Old Oct 28, 2012 | 03:44 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Throttle body question
playing with it never seem to make any changes for me, the computer idles where it wants.
Old Oct 28, 2012 | 03:54 PM
Axle/Gears: 10 Bolt
really? seems kind of weird.....because even on my old throttle body when I would raise or lower the screw it would 100% change the engine RPMs...that doesn't seem right...if your opening the butterfly it should raise the idle..
As of right now the in car tach says 1000 RPMs warm in drive, and the old throttle body said 750 warm in drive.
Old Oct 28, 2012 | 04:28 PM
project89's Avatar
i just bend the lil tab that hits the screw to set the throttle blades, so much easier then knocking out the cap
Old Oct 28, 2012 | 04:35 PM
Axle/Gears: 10 Bolt
What? Why would I knock out the cap...it's factory stock...I bought it because it was stock. I was just wondering if this sounds normal.
Why would you bend the tab...at that touch the idle screw at all...
I thought you shouldn't need to touch that screw, because if it isn't idling right it is because of something else.
Old Oct 28, 2012 | 04:47 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
same way the engine can rev up and down on its own when its cold, yet no parts of the throttle moves, id perfer a good 1000+rpm warm idle with a stick shift. [what I was trying to acomplish when I played with it.]
Even my motorcycle is like that 1000-1200rpm when warm, to keep the engine as close to possable to min take off speed, so I can be easy on the clutch and gas and not have it fart n die.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
