Plz help!!!! 1991 Camaro 3.1L
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Axle/Gears: Stock
My car is sputtering, no aceleration, keeps dying. Rough idle
New ECM, injectors,fuel pump and strainer,MAP sensor,full tune up. Idk what to do about this problem. I also have a new cat on it
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Plz help!!!! 1991 Camaro 3.1L
Does it seem like its running rich ? Have you hacked up a scanner to look at the tps and cts readings ? Or have you performed aco press ion test ? With the tuneup was the timing checked ?
Engine: V6 3.1L
Axle/Gears: Stock
What is a aco press ion test and cts ? What should the tps show?
Engine: V6 3.1L
Axle/Gears: Stock
I got another fuel pressure test done and it said 10 PSI. This will be my third fuel pump and strainer on the car. I don't know what do with it.
Car: check
Engine: check
Transmission: check
Engine: V6 3.1L
Axle/Gears: Stock
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Car: 1992 Firebird
Engine: 3.1L
Transmission: Manual T5
Axle/Gears: Stock
I had similar symptoms on my '92 3.1. It was the fuel pressure regulator. It is a small part, but costs $70-$80. I found the best price at Rock Auto. However, a clogged up fuel filter can also reduce fuel pressure. If your filter is fairly new, then I'd try replacing the FPR.
Good luck. Hope you get it running soon.
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Another thing to check is your return line. I was having a vapor lock like issue after driving my car for 20+ if my car got below half a tank because my return line was clogged and wasn't cooling the pump and it eventually killed my pump.
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
Bro. also. I went through this same **** with 7 pumps. Make sure. MAKE SURE THE PUMP IS RATED AT LEAST 35 psi. I had napa give me 6 pumps all for the v8s even though I told them v6 and confirmed my vin. Morons forreal. But it happens. just double check it.
Posted from Thirdgen.org App for Android
I vote for the Fuel Pressure Regulator.. Your pressure should be closer to 40psi on the V6. But, check your tank. If the fuel tank vent valve (not the one on the fuel canister, the one back in front of the differential) is plugged in might not allow air into the tank when the fuel pump runs. That would tend to create suction pressure in the tank working against the fuel pump..
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
