PaceSetter headers vs. bolt-on SFCs
Old Jun 5, 2013 | 02:42 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Am I the only one here running bolt-on SFCs? I've got the set that runs just inside the side pinch welds. And now I have an issue with the PaceSetter crossover pipe laying right up against the passenger's SFC...
Should I try to get a couple of collector gaskets for the pass side header to act as a shim to at least give me a bit of space between the SFC and the pipe?
Old Jun 5, 2013 | 05:18 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
I'm dumb whats sfc?
Posted from Thirdgen.org App for Android
Old Jun 5, 2013 | 05:46 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: PaceSetter headers vs. bolt-on SFCs
Sub Frame Connectors...
And, also, removing them is not an option... There have been enough useless holes drilled in the floor pan that I've had to fill already.
Not sure if I want to grind on the front end of it or not, and denting a 2.25" pipe is certainly not an option.
Old Jun 6, 2013 | 04:41 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I've got weld on ones, but Ive heard of the bolt ones getting not fitting up right with the exhaust. Hopefully you have room there to shim it. How close is the clearance that you need???
Old Jun 6, 2013 | 10:24 AM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
I'd try shimming. I want to do the pacesetters and bolt on SFC. Let me know what you come up with.
What about header wrap to keep the rattles at bay.
Old Jun 6, 2013 | 10:46 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Hey Dan, could you try grinding in the SFC just a little to get the clearance you need? I would try that or beating on the pipe alittle
Old Jun 6, 2013 | 12:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
cut, weld, mod as needed to make them both play nice, metal is fun that way, unlike wood you can just weld it back on.
only consern I hear over bolt in or weld in, is if you want to do any autox or events, weld ins put you into a pro class automaticaly, even if you don't have the engine for it.
Old Jun 6, 2013 | 02:34 PM
project89's Avatar
cut and weld the y-pipe so u have the clearance u need.
Old Jun 6, 2013 | 03:05 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Well, as I said above, right now, the crossover pipe is laying right tight up against the SFC, and you and I all know it's going to, at the very least, vibrate like nuts.
Anyone know, off the top of their heads, what a good collector gasket would be? I haven't measured it.
I think I'm probably going to shim the collector first to try to gain some space and then go nuts with a grinder on the SFC just to try to get some sort of clearance, even if it's 1/8" or so. If it ever stops raining.
Old Jun 6, 2013 | 05:21 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I had cut the end off my Y long ago to shoot the exhaust down the right side in that valley, instead of the center of the car like stock........
Rousseau92maro
Feb 1, 2016 05:12 PM
92projectcamaro
Jan 18, 2016 08:00 AM
redformula88
Oct 14, 2015 06:08 PM
luvofjah
Sep 26, 2015 08:28 PM
Chad Speier
Sep 24, 2015 12:32 PM
