Another Turbo 2.8 in progress
Old Mar 25, 2014 | 05:17 PM
  #1051
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Re: Another Turbo 2.8 in progress
So I think if I can find a way to run the downpipe on the passenger side I may stick to that. Might take some massaging of the heater lines to get them up onto the frame rail. If I can do that I might have just enough room for the downpipe which is where I want to run it.
So i will probably go a little up and towards the drivers side with the flange, Then all I would need is a smaller belt and I would get rid of the idler pulley.
The less modification the better.
Old Mar 25, 2014 | 10:41 PM
  #1052
project89's Avatar
Originally Posted by AutoRoc
Those new Ninja1000's get great reviews!
I did the same during my build...it was summer...I nabbed a yamaha FZ1.. both are great sport touring rigs.
the bike is great , need to order a set of pipes for it ( its way to quiet ) and need to find somone in the area who can tune it and remove the speed limiter
the rear plate /brakelight/turn signal housing needs to go as well it just doesnt fit the bike looks wise
willie go out and to the passenger side like i did on pilsburys car
Old Mar 26, 2014 | 03:42 PM
  #1053
willexoIX's Avatar
Just get the undertail kit or mod it yourself. Whats the speed limiter set at?
Im gonna try to get it out that side, ill take a pic of whats on the passenger side. The log headers from Chris come out from the head further than Marks log headers did.
I picked up a couple pieces of pipe so I can redo the drivers side rear primary, then ill move the flange a little bit further out and up. For right now I have everything I need but the oil feed line, 3/16 air line ok to use for that? Having a problem finding anything smaller than that.
Got all my fittings and such, im welding a 1/2 bung to the return plate so I can just screw in the 1/2 inch barbs I got. I am also going to tap the oil in plate to fit an adaptor to run the barb I got for it.
Other then that its coming together slowly, but its coming together none the less.
Old Mar 26, 2014 | 03:48 PM
  #1054
willexoIX's Avatar
This is the same size 2 1/2 inch pipe im using for the downpipe. You can see how tight it is and I need to get those heater lines up onto the frame rail in order to fit the downpipe in there, even then its still tight.
Attached Thumbnails Another Turbo 2.8 in progress-forumrunner_20140326_164753.png   Another Turbo 2.8 in progress-forumrunner_20140326_164803.png   Another Turbo 2.8 in progress-forumrunner_20140326_164836.png
Old Mar 26, 2014 | 04:10 PM
  #1055
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I know how tight it can be. That's what kept me from doing that type of route before. But this is a 3 inch down pipe in this pic of my set up now.
There is actually a gap between the v band and the header, but in the right pic its no mounted to the turbo its just laying there so that's why it looks so close and looks like its literly riding on it..lol
Attached Thumbnails Another Turbo 2.8 in progress-new-engine-30.jpg   Another Turbo 2.8 in progress-new-engine-17.jpg   Another Turbo 2.8 in progress-new-engine-32.jpg
Old Mar 26, 2014 | 04:30 PM
  #1056
willexoIX's Avatar
With how far out these log headers are, id probably have to dent them to run a 3 inch downpipe, haha
Old Mar 26, 2014 | 05:26 PM
  #1057
willexoIX's Avatar
Hey Dave, I may have to pass on that hood, i need to buy a waterpump and a couple other things when I scrap that steel my friend is dropping off. Ill let you know in a couple days
Old Mar 27, 2014 | 02:18 PM
  #1058
willexoIX's Avatar
Well gapped the r42s to .026 and got them in. Got the 160 hypertech tstat in. Went out and picked up a couple pieces of 1 1/2 pipe to fix that drivers side rear primary. Just gotta stop being lazy and drill out the bolt holes to the next size so i can see if they will all bolt in. Then cut and weld that mis-matched primary, reposition the flange forward, up and more towards the drivers side to make room for the downpipe 90° off the turbo.
Still trying to figure a way to move those heater hoses. Have to hack up the ac box to do it though. Good thing the heater hoses right there are metal, wont have to worry about them melting with the downpipe right there. Plus the DP will be wrapped in the engine compartment. Any pointers for that ac box without spending money?
Also got that breather filter in the passenger side valve cover; had to hack up the rubber elbow cause the rubber thing on the breather was too small for the hole.
Slow going and not really sure if you could call that progress, lol
Old Mar 27, 2014 | 04:21 PM
  #1059
fasteddi's Avatar
Car: 1991 Camaro RS
I wish I could offer tips on the ac coil/ blower assembly, but as you can see my car has no heat or ac... who needs that?
Old Mar 27, 2014 | 04:29 PM
  #1060
project89's Avatar
u shouldnt have to hack up the heater/ac box we did pilsburys car and it still has ac/heat we didnt have to do anything but bend one line away from the downpipe
or is it the crossover thats hitting the heater box?
does the ac even work in ur car ? if not a non ac box out of an s10 or g van fitts
Old Mar 27, 2014 | 04:30 PM
  #1061
willexoIX's Avatar
Well i would just get rid of the heat but it would be easier just to move the 2 hard lines. I dont have ac, just the box is left and i need to i guess break the plastic on the bottom to tuck the heater lines under it. Basically i need to move the heater lines from alongside the framerail to the top.
Funny, i live in florida and i ditched the ac and kept the heat, lol. But i can handle the heat and hate the cold, i was born in june lol.
Old Mar 27, 2014 | 04:32 PM
  #1062
project89's Avatar
another thing u can do is bypass the heater control valve , so u have less plumbing to deal with , then u just hook up the heater core to the pump and intake ports
the downside is that u always have hot water/coolant circuating threw the heater core
u can however drill 4 1/8 in holes arounf the t stat , and then put a ball valve in on of the heater core lines to shut off the flow of water to it for the summer
but if u do that u have to have the holes drilled in the t stat so water can circlate a lil bit when the stat is closed
thats what the heater control valve does when u dont have it on heat , it sends the water in a loop past the t stat
Old Mar 27, 2014 | 04:39 PM
  #1063
willexoIX's Avatar
The downpipe will be close to the ac box, but without moving the heater lines they are in the way of the downpipe.
Im gonna bend them up onto the frame rail and thatll make enough room for the downpipe.
I need to pick up another 2 1/2 inch vband for the downpipe so i can take it out and wrap it once its welded, the way it needs to go i would never be able to get it out once its welded.
And no i dont have ac, and ill have limited funds once i scrap that steel. Unless someone wants to donate an ac delete panel, lol. I could probably make one but i want to keep the vents at the least.
Old Mar 27, 2014 | 04:40 PM
  #1064
willexoIX's Avatar
That wouldnt be so bad, the flapper would be closed if it wasnt on hot/heat so it wouldnt be any hotter in the passenger compartment.
Old Mar 27, 2014 | 04:41 PM
  #1065
project89's Avatar
yeah nd then u can run 2 rubber hoses from the pump/manifold over the valve cover right to the heater core and it gets the rest of the stuf fout of the way
Old Mar 27, 2014 | 04:43 PM
  #1066
willexoIX's Avatar
for now do this , pull the heater lines out all of them
then just run a loop from the pump to the intake , and then pull out the heater box compltley, but dont destroy it incase u need to put it back in
junkyards will usually sell u the van or s10 box for 20 bucks with the fan
and then later whn u have mor emoney u can complete the heater stuff , being in fl i dont see u needed the heat much in the comming few months
True, woulda needed this morning though lol.
What do I do with that funky bent hardline just cap it? I did the throttlebody bypass, just route the smaller waterpump outlet to the line coming into the heater bypass?
Old Mar 27, 2014 | 04:45 PM
  #1067
willexoIX's Avatar
Lol more money i dont have. Ill just bend the lines, thats free..
Old Mar 27, 2014 | 04:59 PM
  #1068
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
What is your zip code?
Old Mar 27, 2014 | 05:13 PM
  #1069
willexoIX's Avatar
33597
Old Mar 27, 2014 | 05:40 PM
  #1070
33597
I have one I am not using anymore, just pay shipping and its yours. Comes with the cover, blower motor, resistor, and wiring. You'll retain all four speeds. You'll want a heater/defroster for those chilly track nights and mornings. Here is an old thread I started for it...
https://www.thirdgen.org/forums/fabr...-c-delete.html
Old Mar 27, 2014 | 05:43 PM
  #1071
willexoIX's Avatar
Dude you rock! Ill let you know, pm me the shipping cost when you get a chance
Old Mar 27, 2014 | 05:50 PM
  #1072
No problem, it's honestly just taking up space. I'll PM the shipping...
Old Mar 27, 2014 | 06:43 PM
  #1073
project89's Avatar
rob while ur digging threw all ur old stuff im still in need of a shifter and cable :P
Old Mar 28, 2014 | 08:47 AM
  #1074
willexoIX's Avatar
I would assume the crankshaft is in the way of taking the pan off with the motor in the car? Well and the kmember. Just wondering.
Old Mar 28, 2014 | 10:33 AM
  #1075
project89's Avatar
no its not , if u unbolt the pan and put the crank in the right position the pan will slide out till it hits , then u rotate the crank som emore and it will slide all the way out .
or u can take the 2 engine mount bolts off and put a jack with a block of wood under the crank pulley and jack the engine up a bit , just make sure u take the distributor cap off first or it will hit the firewall
Old Mar 28, 2014 | 10:39 AM
  #1076
willexoIX's Avatar
Good tips Dave, just gotta mark where I want to put that bung before I take it off. Itll be way easier with the pan off.
Old Mar 28, 2014 | 11:10 AM
  #1077
willexoIX's Avatar
Btw, im just gonna delete the heater hoses and bypass for now and just loop the pump outlet to the bypass inlet.
And sorry Chris, im having a very hard time believing you welded these up on heads. I had to drill out the bolt holes to get more than 2 bolts into the head. And with the one port half an inch off, theres no way. I have to modify the hell out of these just to get them to bolt up.
Modifying is the nature of the beast but all you had to say was they may need some modification. Sure moving some stuff around the engine bay is fine, but i was under the impression these were bolt on and go. Not the case.
Old Mar 28, 2014 | 12:53 PM
  #1078
willexoIX's Avatar
In other news, heres how Im gonna fix that primary.
Attached Thumbnails Another Turbo 2.8 in progress-forumrunner_20140328_135319.png
Old Mar 28, 2014 | 02:06 PM
  #1079
project89's Avatar
got a torch to heat it with and bend it ?
Old Mar 28, 2014 | 02:22 PM
  #1080
willexoIX's Avatar
Cut and weld, not gonna risk cracking it. Besides, it still wouldnt line up and i would need 3 gaskets just to close the gap.
Also just found out i was an inch away from losing my power steering bracket. Huge crack across the whole bracket. Either going to weld it, or go pull one from a junkyard. I dont really want to weld it cause its already been welded once.
Old Mar 28, 2014 | 02:23 PM
  #1081
project89's Avatar
do u have an angle grinder , u can cut into the tubing but not all the way threw so u can bend the primary make 2 cuts about an inch apart on oposite sides theis will alow u to bend and stretch the primary into place and then weld it back up
Old Mar 28, 2014 | 02:50 PM
  #1082
fasteddi's Avatar
Car: 1991 Camaro RS
Cut it, add a section of 1 1/2 inch that you know it needs and weld it. So much faster to just reweld the pipe with a new addition then to fill gaps..imo
Old Mar 28, 2014 | 02:59 PM
  #1083
willexoIX's Avatar
Like this? Lol
Attached Thumbnails Another Turbo 2.8 in progress-forumrunner_20140328_155927.png
Old Mar 28, 2014 | 03:00 PM
  #1084
fasteddi's Avatar
Car: 1991 Camaro RS
Perfect
Old Mar 28, 2014 | 03:19 PM
  #1085
willexoIX's Avatar
Done with that part. Next is the flange relocation.
Attached Thumbnails Another Turbo 2.8 in progress-forumrunner_20140328_161935.png
Old Mar 28, 2014 | 04:06 PM
  #1086
willexoIX's Avatar
Almost cant tell, lol. I drilled out the holes on the passenger side and now all those bolts go in. Drivers side im currently running a tap through the head to clean up the threads. Sprayed the drivers side with header coating, once the dries ill wrap it and coat it and make sure the bolts go in, if not ill drill those flanges to the next size.
Making progress, shouldnt be very long now, I estimate hopefully a week for startup. We will see.
Attached Thumbnails Another Turbo 2.8 in progress-forumrunner_20140328_170634.png
Old Mar 28, 2014 | 05:56 PM
  #1087
project89's Avatar
btw the header paint will burn off unless u cure it , they need to be thrown in an oven or slowly heated and let cool somehow
Old Mar 28, 2014 | 06:18 PM
  #1088
willexoIX's Avatar
We have an electric stove we use for powdercoating. The dei spray says to bake at 400 to cure so ill bake them all together when i wrap the passenger side and downpipe. Need to get a 2 1/2 vband for the downpipe though so i can make it removable.
Old Mar 29, 2014 | 04:58 PM
  #1089
Will, PM me your full address...
Dave, lemme see what I have left, cuz I gave Ted a lot of stuff last year...
Old Mar 29, 2014 | 06:59 PM
  #1090
willexoIX's Avatar
Pm sent
Old Apr 2, 2014 | 06:49 PM
  #1091
willexoIX's Avatar
Well at this point Im waiting on funds to pick up some 2 1/2 inch or 2 3/4 pipe for the downpipe. I dont want to go 3 inch just yet. The exhaust pipe I had wasnt 2 1/2 inch, it was a hair under 2 1/4 OD. So it will work for fixing the flange position on the log headers, but thats about it.
So we wait, shouldnt be long. Ill get started on that flange soon.
Old Apr 3, 2014 | 09:33 PM
  #1092
willexoIX's Avatar
Lol. Got a speeding ticket tonight. In the honda, 73 in a 55. And I am putting a turbo on my car; great, lol.
First speeding ticket in 4 years.
Thankfully I just got calls to change shocks and struts in my friends truck, and just got a small job. Removable Ipad in a 91 suburban dash. Thinking about glassing in a dock/mount, and wiring it up switched with a trickle charge, though he wont really need it. That and wiring it into the head unit for audio/video.
Shouldnt be too bad. Itll pay the speeding ticket and give me the funds to finish up the turbo install.
Old Apr 5, 2014 | 12:41 PM
  #1093
willexoIX's Avatar
Couple teaser pics. Working on relocating the flange, got lucky and started blind cutting angles and got 2 pieces with a perfect fit. They put the flange right where I wanted it. Better angle on the oil drain and higher location for the turbo. Also leaves more room for the downpipe. So that solves that I just gotta tac them, make sure its right, weld, coat, wrap, coat and cure and I can install the headers fully and the turbo.
Once thats taken care of I can pretty much do everything but the downpipe till I get funds for more pipe.
Also got the heater valve bypass issue solved by reusing the hose that goes from the water pump to the hard heater line.
Attached Thumbnails Another Turbo 2.8 in progress-forumrunner_20140405_133727.png   Another Turbo 2.8 in progress-forumrunner_20140405_133735.png   Another Turbo 2.8 in progress-forumrunner_20140405_133750.png
Old Apr 5, 2014 | 01:03 PM
  #1094
project89's Avatar
to clean that up a lil bit u can remove the fitting from the manifold and screw a regular pipe fitting in its place so u dont have to have that huge loop in the hose
Old Apr 6, 2014 | 09:37 AM
  #1095
willexoIX's Avatar
Well its shorter than the stock loop! Lol. Ill dig around my shop to see if I have one.
Old Apr 10, 2014 | 01:28 PM
  #1096
willexoIX's Avatar
Finally got started on the relocation of the t3 flange. Placement of the turbo is about as good as it can get. The way it sits allows me to route everything the way I wanted to without having to relocate stuff. Need to pick up a different top rad hose as its in the way of the outlet.
More to come
Old Apr 10, 2014 | 01:33 PM
  #1097
willexoIX's Avatar
Stupid f-ing internet
Attached Thumbnails Another Turbo 2.8 in progress-forumrunner_20140410_143305.png   Another Turbo 2.8 in progress-forumrunner_20140410_143312.png   Another Turbo 2.8 in progress-forumrunner_20140410_143319.png
Old Apr 10, 2014 | 02:21 PM
  #1098
project89's Avatar
wow that turbo looks so friggen tiny , prolly the same size as the engine in the toyota tercell i ust bought.
i can rev the thing to redline and dump the clutch in 1st and it wont even chirp the tires.
but with it getting killer gas milage i dont mind
Old Apr 10, 2014 | 02:23 PM
  #1099
willexoIX's Avatar
1 more, welded and coated.
The mobile app is being retarded, so dont mind the 3 of the same pics
Attached Thumbnails Another Turbo 2.8 in progress-forumrunner_20140410_151942.png   Another Turbo 2.8 in progress-forumrunner_20140410_152021.png   Another Turbo 2.8 in progress-forumrunner_20140410_152234.png
Old Apr 10, 2014 | 03:20 PM
  #1100
fasteddi's Avatar
Car: 1991 Camaro RS
Cool looking good. Turbo does seem tiny... nothing like a t25 though.lol Heres a t25 when i was fabbing up my system for the first time about 2 1/2 years ago. It was just for the piping placement as I was poor and couldnt even afford the real turbo yet that i was going to use..lmao That lil t25 was just a metal blow dryer..lol That what I think of those little guys...
Attached Thumbnails Another Turbo 2.8 in progress-xxxxxxxxxxxxxx-elcheepo.jpg   Another Turbo 2.8 in progress-xxxxxxxxxxxxxxxxxx-elcheepo2.jpg
