Another Turbo 2.8 in progress
Old Mar 2, 2014 | 08:43 PM
  #851
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Another Turbo 2.8 in progress
Originally Posted by willexoIX
Noisy alternator. Its not a bandaid, its a solution. The alternator has less than 1000 miles on it so its pretty much brand new and replacing it is out of the question.
Noise in the 12v line is causing resets, a quality noise suppressor does exactly what the name suggests, which will solve the problem that I am currently having.
I have done some extensive reading on the msextra forums and have concluded that the ms1 processor along with the v3.0 board, when put together are more susceptible to noise than say an ms2 on the 3.0 board, etc...
Everyone who has swapped the ms1 cpu with a ms2 cpu, resets and noise are gone, so my conclusion is that the MS1 processor is HIGHLY sensitive to noise, and i am not quite ready to swap an ms2 cpu yet.
The noise existed with the stock computer and I have never had problems with noise, aside from the whine in the speakers coming from the alternator. Noise is a fact of life for some of these cars, mine has had that whine since I bought it. Replaced the battery and alternator and it didnt go away. Tried just about everything BUT a noise supressor.
Simple fact of the matter is, I bought the suppressor thats sold to do what it does, which so happens to be what I need it for; to call it a bandaid is nonsense, its a fix when all else has been ruled out.
Kinda like saying sunglasses are a bandaid. Whats the fix, stay out of the sun? Get my point? I understand what you are saying but electrical noise is a fact of life, and in some cases no matter what you do, you cant get rid of it.
No, a noise suppressor IS a band aid, you're not addressing the problem, you're putting a band aid on it, plain and simple. I say this as someone who has worked on automotive electrical for well over 20 years. I have NEVER come a cross a car where I have not been able to fix any sort of electrical noise issue, the correct way and not with band aids.
I have installed audio systems for as long and have been able to solve noise in every case, sometimes the repair was to replace defective or damaged product. So the noise you hear, an "audible tachometer" as the industry refers to it as, is indicative of poor grounding, possibly poorly routed wiring, poor condition battery (battery acts like a filter) and/or defective components.
If you don't repair the problem at the source, it's only a matter of time before it gets worse and your "noise suppressors" become in-effective.
The MS issues seems to indicate that the power supply of the MS in-adequate, and should be improved to filter more of the noise out. IIRC the MSII daughter board has an additional power supply section, that would be responsible for additional filtering.
Noise is not a fact of life for any car, that is fact.
Old Mar 3, 2014 | 07:24 PM
  #852
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Valid but moot in my application, its not noise causing resets.
I have gone over every single ground with a fine tooth comb, earlier in the thread I also tried power directly from the battery with no change. Moved the ms grounds from the chassis to the head, separated and isolated the sensor return wire, moved spark plug wires away from everything, new dizzy, wires, coil, plug, etc...
One thing i noticed, when it drops out, the afr goes lean. Never noticed it before because with the bad dizzy when it dropped it went rich. So its a no fuel condition i believe.
I havent tried to drive it with the bypass unplugged but i bet it runs perfect again. Ill update tomorrow.
So far I have 99% of what i need for the turbo install, pics coming tomorrow
Old Mar 3, 2014 | 09:33 PM
  #853
project89's Avatar
what are ur injector settings
Old Mar 4, 2014 | 05:34 PM
  #854
willexoIX's Avatar
sorry for the delay but heres my .msq and a datalog. I realize that the datalog isnt very long, and its mostly in warmup, but it did hiccup once. Then megatune completely locked up and crashed my laptop, so thats why its so short.
File Type: zip
File Type: zip
Old Mar 4, 2014 | 07:32 PM
  #855
willexoIX's Avatar
I have seen a couple threads on the msextra forums where over boost was causing problems. Being Im still NA, wouldnt I set it to 100kpa instead of -14.7?
Old Mar 4, 2014 | 09:02 PM
  #856
willexoIX's Avatar
Lets see if I have this right.
Bypass unplugged, no timing changes, means the rotor phasing is fixed, no miss or resets.
Plug in the bypass, rotor phasing changes with timing, misfires and resets.
If this is correct, then wouldnt it mean the timing controlled by the MS is causing the miss, perhaps firing the wrong cylinder due to the changed rotor phasing?
Is that correct?
Old Mar 6, 2014 | 01:03 PM
  #857
willexoIX's Avatar
Am i right, am i wrong? Anyone have anything?
Old Mar 6, 2014 | 01:10 PM
  #858
project89's Avatar
sorry man ive been busy didnt even relized u had been posting , ill look over the tune here tonight when i get out of work and get back to ya
to be sure of rotor phasing pull the cap off and see how the rotor is locatated in relation to the number 1 terminal with the engine set to tdc on #1
Old Mar 6, 2014 | 01:17 PM
  #859
willexoIX's Avatar
No biggie, i know you have other stuff going on, just trying to see if my presumptions on rotor phasing are correct
Old Mar 6, 2014 | 04:10 PM
  #860
RBob's Avatar
Car: check
Engine: check
Transmission: check
Is that correct?
It depends upon the ICM. A properly working ICM will have limp mode advance. This will change the rotor phasing.
RBob.
Old Mar 6, 2014 | 04:26 PM
  #861
willexoIX's Avatar
RBob.
Its a brand new cardone dizzy. I know just because its new, doesnt mean it isnt broken, however first thing i did was take the icm out and have it tested, it passed so i used some arctic silver 5 between the icm and dizzy base.
I think everything is working as it should, because it runs great. But that miss always happens around the same conditions, which as far as I can tell is around 25% throttle, low load. Wont do it with no load, and only if the bypass is plugged in.
If the bypass is unplugged(base timing *10 btdc), it doesnt do it at all. Its gotta be the Megasquirt. Everything else has pretty much been eliminated.
Something to do with the MS controlling timing or some specific setting is amiss. Im at a loss to think its anything else, we have done just about everything.
Old Mar 7, 2014 | 07:35 AM
  #862
RBob's Avatar
Car: check
Engine: check
Transmission: check
You can check for limp mode advance via the timing light. Same as setting the base timing but increase the engine RPM. At some point the timing will suddenly advance.
The RPM at which the timing increases varies from vehicle to vehicle, but it is usually in the 1600 - 2000 RPM range.
RBob.
Old Mar 7, 2014 | 10:25 AM
  #863
willexoIX's Avatar
Anyone think theres a chance that the original faulty icm causing real misfires may have screwed something up on the MS board before it was replaced? I dont think it did and had a look at the board and it was fine. Plus the fact that it runs fine other than that slight miss, which is nothing like the miss I was having with the faulty icm.
The overboost setting has caused resets and misses for other people, but im kinda unsure about that, even though it makes sense. I mean, wouldnt it be set to 100kpa for na instead of -14.7? When it misses im usually cruising trying to maintain speed, which with the throttle blade mostly closed, would result in a higher vacuum right? But if thats the case, then wouldnt it do it idling in gear too? Or is it only limited to happening under load?
Just throwing some thoughts out there cause im about ready to figure this crap out and be done with it. At this rate I'll never get the turbo on.
Old Mar 7, 2014 | 11:01 AM
  #864
willexoIX's Avatar
I can confirm its not the overboost setting, i set it to 23psi and still does it.
Old Mar 7, 2014 | 01:24 PM
  #865
project89's Avatar
looking over ur tune file now
Old Mar 7, 2014 | 01:43 PM
  #866
willexoIX's Avatar
you think maybe changing the injector squirts may make a difference? I have one ground connection that I am about to go out and check, the ground I moved when I moved the battery to the other side of the engine bay.
Also, dont know If I had mentioned this before, but both banks of injectors are getting power from only one injector fuse, the other injector fuse is what I'm using for the MS power.
LOL, on one efi site, they say to put the sensor return with the rest of the MS grounds(how I had it wired originally), on another it says to seperate the return from the ECU grounds(which is how mine are now).
Old Mar 7, 2014 | 01:53 PM
  #867
project89's Avatar
squirts should be 2 squirts alternating
u should prolly seperate the injector power on my car power fro all 6/8 injectors comes form a 40 amp relay
i cant get tuner studio to run on this computer friggen hate windows 7
edit i finally got it to install
Old Mar 7, 2014 | 02:00 PM
  #868
project89's Avatar
pulled up a few errors when i loaded the tune checking them all now
anyways set overboost to 255kpa
Old Mar 7, 2014 | 02:03 PM
  #869
willexoIX's Avatar
Unfortunately I am out of money, any other recommended setups for injector power? Figure I could run the injector power off of both injector fuses and move the MS power elsewhere.
Man these new relays are getting cheesier and cheesier. The original fan relay lasted 22 years, the replacement lasted 2 years, and the one I just swapped out looks like the crappiest case I have ever seen, its almost transparent. If it goes anything like the last one I may get a year out of it, good thing its lifetime replacement.
Old Mar 7, 2014 | 02:05 PM
  #870
willexoIX's Avatar
The setting is for psi so I set it to 25psi and It didnt change.
Old Mar 7, 2014 | 02:07 PM
  #871
project89's Avatar
i think u just have a phasing issue take the cap off mark were the number 1 terminal is and take a pic so i can see were the rotor sits in relation to the #1 terminal
Old Mar 7, 2014 | 02:23 PM
  #872
willexoIX's Avatar
Can I put the balancer timing mark to the *10 btdc mark for tdc on 1? or *0 btdc? is there an easy way to do that or do I have to take the plug out of #1 and find the compression TDC on 1 with a screwdriver?
Old Mar 7, 2014 | 02:26 PM
  #873
project89's Avatar
take number one plug out and put ur finger over the spark plug hole while u turn the engine over u will feel it build compression, and then u will know when u are getting near tdc
set the timing mark to 0* that is tdc
actually set it to 10* btdc so i can see how the reluctor wheel lines up at ur base timing
Old Mar 7, 2014 | 02:33 PM
  #874
project89's Avatar
if this dont fix ur issue , pm me ur shipping adress and ill send u out my ms2 cpu for u to try and see if that clears up the issue , just send it back after u test with it
Old Mar 7, 2014 | 02:40 PM
  #875
willexoIX's Avatar
Sounds good. Ill go out and get those pics now. I might just use my old cap and just cut out the whole center cause its no good anyway. Ill just leave all the outer towers intact.
Old Mar 7, 2014 | 03:18 PM
  #876
willexoIX's Avatar
First 2 at 10°, second 2 at 0°
Attached Thumbnails Another Turbo 2.8 in progress-forumrunner_20140307_161753.png   Another Turbo 2.8 in progress-forumrunner_20140307_161811.png   Another Turbo 2.8 in progress-forumrunner_20140307_161823.png
Old Mar 7, 2014 | 03:19 PM
  #877
willexoIX's Avatar
Heres the 4th
Attached Thumbnails Another Turbo 2.8 in progress-forumrunner_20140307_161941.png
Old Mar 7, 2014 | 03:25 PM
  #878
willexoIX's Avatar
Dont mind the mess, its like that cause i just pulled the old cap off with the wires still on, that looped wire is the ground from the shielding to the dizzy screw.
Old Mar 7, 2014 | 03:28 PM
  #879
project89's Avatar
whats the 3rd and 4th picture at cause the rotor is way to far past #1
Old Mar 7, 2014 | 03:32 PM
  #880
project89's Avatar
u know what just put that cut cap back on , set the engine to 10* btdc and then line up the rotor with #1 , then tighten the dizzy , start the car and see what base timing is at.
we can change the offset/base timing in megatune to make it correct
  #881
willexoIX's Avatar
0 degrees on the timing mark, first 2 pics are at 10
Old Mar 7, 2014 | 03:35 PM
  #882
willexoIX's Avatar
at 10 degrees the rotor is perfectly aligned with the number 1 post...
and I cant start it with the cut cap, I cut the whole center out cause it was bad
Old Mar 7, 2014 | 03:36 PM
  #883
project89's Avatar
ahh ok so the first to are at 10* btdc then never min my previous post
ugh i gota think about the rpotor phasing for a few mins
the reluctor is just past its peak at 10*
iirc rotor phasing is right but like i said i need to think about it for a few mins
on mine at 10* everything is dead on not just past like yours is
looking at it again that is a huge gap between the rotor tip and the terminal though . is the cap seated all the way?
adit again
lift the dizzt till u can spin the rotor and move the rotor back one tooth and drop dizzy back in and retime it i wanna see what it does
Old Mar 7, 2014 | 03:39 PM
  #884
willexoIX's Avatar
it wasnt seated all the way in the first pic, in the 3rd it was. I took the screws out and forgot to hold it down in the first pic
Old Mar 7, 2014 | 03:41 PM
  #885
willexoIX's Avatar
is it supposed to be perfectly aligned at 10 or 0? the rotor that is
Old Mar 7, 2014 | 03:45 PM
  #886
willexoIX's Avatar
adit again
Moving it one tooth would move the reluctor too far.
Old Mar 7, 2014 | 03:48 PM
  #887
willexoIX's Avatar
it runs perfect other than that slight miss and the resets. Only under cruising, more or less throttle and it doesnt do it at all. they never occur at the same time, plus it doesnt happen with the bypass unplugged.
Im somewhat hesitant to move the dizzy, its dead on AFAIK. The only thing bothering me is the reluctor not completely lining up at 10*
Old Mar 7, 2014 | 03:51 PM
  #888
willexoIX's Avatar
Also the base timing may or may not be closer to either 9 or 11*, that might just account for the reluctor being slightly off.
Can I put the balancer mark at 10*, then loosen the dizzy and turn it till the reluctor lines up properly?
Old Mar 7, 2014 | 04:04 PM
  #889
project89's Avatar
yes then see were the rotor falls
Old Mar 7, 2014 | 04:14 PM
  #890
willexoIX's Avatar
This is after moving the dizzy to make the reluctor line up. Balancer mark centered on 10°. I noticed that the dizzy shaft has a tiny bit of up and down play, but not enough that it would have lined up the reluctor. that little bit of play may line up the rotor though
Attached Thumbnails Another Turbo 2.8 in progress-forumrunner_20140307_171425.png   Another Turbo 2.8 in progress-forumrunner_20140307_171443.png
Old Mar 7, 2014 | 04:17 PM
  #891
willexoIX's Avatar
Looking at the reluctor, it almost seems like its not seated properly on the dizzy shaft. Possible I got a bad dizzy? Then again that doesnt make sense cause it did it before on the old dizzy too..
Old Mar 7, 2014 | 05:01 PM
  #892
project89's Avatar
that rotor looks like pos , how much of a gap between the end of the rotor and the terminal is there?
now what i want you to do is moove the timing marks so the the engine is at 35* btdc and take a picture of the cap/rotor again
Old Mar 7, 2014 | 05:06 PM
  #893
willexoIX's Avatar
About a playing card or 2. That little bit I turned the dizzy moved the timing from 10 to 0. The most confusing part? NO RESETS. What the hell???????
It still missed, but it didnt reset at all and had extreme lack of power.
I guess cardone isnt as good as they used to be, thats the rotor that came with the dizzy.
Old Mar 7, 2014 | 05:12 PM
  #894
willexoIX's Avatar
For the hell of it, i took a datalog.
File Type: zip
Old Mar 7, 2014 | 05:15 PM
  #895
project89's Avatar
leave the distributor were its set then and go into the tunr and change the base angle from 10 to 0 and try again
whats happening is before the rotor tip was to far away from the terminal the spark had to jump a massive air gap before getting to the spark plug gap causing a missfire
Old Mar 7, 2014 | 05:23 PM
  #896
willexoIX's Avatar
Ill give that a shot. I know it missed, I felt it and heard it, but now its not even showing up on the log now. All the inputs used to go crazy before when it did it, now I cant even tell where it did it.
Ill take another log and blip the throttle right after it misses.
Old Mar 7, 2014 | 05:41 PM
  #897
willexoIX's Avatar
Now if I can just get megatune to stop locking up. Started a datalog, recorded for a minute, then locked up. Pulled over and tried to restart megatune and it wouldnt work at all.
AFAIK(cause I cant tell unless megatune is connected) No resets and the misfire is gone.
Can I run the car at 0* as long as the MS compensates and leave it there?
Old Mar 7, 2014 | 05:47 PM
  #898
project89's Avatar
yes u can leave the base timing there since u reset the base timing to 0 in megatune the megasquirts compensates for it
all that was wrong was the rotor phasing setting base timing to 0* fixed it for the most part , it might still not be perfect but its close enough for now
the missfire or the arc inside the cap was causing the noise and resets
normally on a conversion like urs u do not need to check rotor phasing since its usually right with the stock ecm to begin with , but one out of 25 may have the issue u had
Old Mar 7, 2014 | 05:56 PM
  #899
willexoIX's Avatar
I was starting to lose my mind trying to figure it out. So I am assuming that the dizzy was off from the factory then?
Glad to be done with that for now. Now I gotta tune it I guess, wonder how long itll take me to finish that. Im about to say F the NA tune and just move on to the turbo install cause this wasted way more time than I expected.
Old Mar 7, 2014 | 06:00 PM
  #900
project89's Avatar
out the turbo on man, the tune u have now is good enough to drive.
the boosted sections of the map should prolly get u 10.5 afrs to start so it should be safe to jump right in and tune the whole thing as u go
btw even if u tune n/a now the tune will be off once the turbo goes on , cause backpresure and ex flow changes, on a speed density system this has a big impact on fueling
